which disconnects should i get?
Old May 22, 2005 | 01:05 PM
byron4's Avatar
i want to get the NWOR swaybar disconnects because they are on sale at the moment for $45. but my question is is that i plan to lift the 4runner with OME coils and 1.5" ball joint spacers in the very near future. should i get the ones for the 0"-2" lift or go with the 3"-4" lift sway bar disconnects.
Old May 22, 2005 | 01:14 PM
jimbo74's Avatar
probably get the 3-4" ones unless the coils are only going to give you .5" of lift...
Old May 22, 2005 | 05:24 PM
byron4's Avatar
i dont see why coils would matter since they are in the rear. i am getting the sway bar disconnects for the front of my 1993 4runner and i want to know if the 0"-2" lift discos are long enough or should i go with the 3"-4" lift ones. i wont be putting these on until i have the ball joint spacers installed. will the ball joint spacers even effect the length of the sway bar?
Old May 22, 2005 | 05:56 PM
4Crawler's Avatar
Yes, any sort of lift will affect the sway bar end link length. Ideally, you want the ends of the sway bar to remain in their stock orientation, typically parallel to the ground. If you lift the front end, the ends of the bar would drop downwards. With that you get uneven forces on each side in a turn. So best to match the end link length to the lift in order to restore the sway bar ends to the stock position.
Old May 22, 2005 | 06:19 PM
byron4's Avatar
so you think i should get teh 0" to 2" lift ones?
Old May 22, 2005 | 06:43 PM
4rnr's Avatar
I used turn buckles.
I cut the eyes off of the studs, and welded them to the 1/2 in of swaybar link that I left on top and bottom after I cut them.
Then I just thread the actual turnbuckle on to the studs and walla It holds even if I pick up a wheel. And it disconnect faster than regular discos and when you upgrade the lift you just buy a longer turnbuckle link.
it cost me like 5 bucks and 30 min.
If you want I can post pics....
And yes they are proven strong!!!
Old May 22, 2005 | 06:59 PM
byron4's Avatar
give me as many pics as you can $5 is a lot better the $45
Old May 22, 2005 | 07:03 PM
4rnr's Avatar
k ill try to get them up tomarro night
Old May 22, 2005 | 07:09 PM
jimbo74's Avatar
ah ok.... get the 2" ones then, didtn realize the coils were for the rear.... i was thinking they were up front.... out back, my truck has leaves
Old May 22, 2005 | 09:51 PM
Jake94's Avatar
"It's often better to sit in silence and be thought a fool, than to open ones mouth and remove all doubt".....Mark Twain.
4Crawler is spot on, as your sway bar will work best if the ends are parallel to the ground. Not a big deal when lifting up to 2", but if you are going for the disco's why not get them in the proper length.
Your best bet is to do the BJ spacers 1st. While installing them you could get the actual measurements and then order the length you need from 4Crawler. Buy once, cry once. You can run the stock end links until you can order the discos with out any problems.
You'll probably find that the discos only need to be ~3/4" longer than stock. When adding BJ spacers for lift, what you are actually doing is pushing the knuckle and lower A arm down. The A arm is pushes down 1 1/2" at the outboard end. The sway bar link is half way between the A arm pivot and the ball joint. So the point at which it attaches is only pushed down ~1/2 half the distance as the ball joint. (this is not exact just a good rule of thumb).
Order from 4Crawler, you won't be sorry. If you must order from NWOR let me be the 1st to say "I told you so"
Jake.
Old May 22, 2005 | 09:58 PM
Tofer's Avatar
Sponsor
just take the sway bar off... thats what i did. i took it off to build discos and then never got around to building them or putting it back on.
Old May 23, 2005 | 11:05 AM
4rnr's Avatar
Also a good option
[quote]"It's often better to sit in silence and be thought a fool, than to open ones mouth and remove all doubt".....Mark Twain.
Jake.
WOW your smart
Old May 25, 2005 | 07:23 PM
4rnr's Avatar
heres the pics of my discos. I used a nut as a sleeve to join the stud with the link (its what I had laying around, I did this when I was board one day, I didnt even know if it would work.) I supose a piece of small tubing would work better...
Old May 25, 2005 | 08:14 PM
4Crawler's Avatar
Actually the NWOR disconnects are fairly decent, look very similar to what I make. I think they use plated steel and smaller dia. pins than mine do, mine are mostly s/s and aluminum. They are all copies of the old Drew Persson s/s disconnects:
http://www.off-road.com/toyota/revie...dis/index.html
At that $45 sale price, hard to beat that deal, that is less than what the parts cost is for mine.
Gone Fission
Oct 7, 2015 12:42 PM
dbollier123
Sep 29, 2015 05:23 PM
tazman1972
11
Sep 28, 2015 10:32 PM
JamesDINAN
Sep 22, 2015 05:37 AM
SCZIG
Sep 20, 2015 09:00 AM
