Do I have a 4cyl diff in my V6 4Runner?
Old May 21, 2005 | 11:39 AM
skdave's Avatar
The axle code on the placard for my 88 V6 4Runner indicates it has a 2 pinion diff. The V6 8" is suppose to have 4 pinions. Does this mean it has the 4cyl diff? I've read that some V6 4Runners did come with the 4cyl diff. The code reads as follows: 138JF11G292A340H. G292 is the axle code. G for 8", 29 for 4.1 gears, 2 for two pinion.
I'm wanting to put in a lunchbox locker so I need to know which diff I have. According to the literature for the Detroit EZ Locker there is a 2 pinion V6 diff that was used in 2X4 pickups. It uses the same model EZ Locker as the 4 pinion V6 diff. The 4cyl diff uses a different model.
Anyone have a clue about which diff it is?
Thanks,
SKDAVE
Old May 21, 2005 | 11:50 AM
jimbo74's Avatar
conflicting info.... bust it open and find out, honestly thats the only way to figure it out.... i have a 4cyl 8" with a 2 pinion on my 4x2.... most 4x2s came with the 7.5" my vin plate says i have a 4 speed, but my truck has 5 speeds....
Old May 21, 2005 | 01:54 PM
Glenn's Avatar
Not all the V6 thirds are 4 pinion. Some are two.
Old May 21, 2005 | 02:58 PM
ZUK's Avatar
ZUK
Dave---you have the V6 diff if you have 4 ribs on the outside....if you don't know what I mean then post a snapshot(using the flash) of the diff.
Old May 21, 2005 | 04:29 PM
skdave's Avatar
ZUK,
The third does have 4 ribs on each side. So it must be a V6.
Thanks all!!!
Old May 21, 2005 | 05:50 PM
jimbo74's Avatar
the amount of ribs on the outside of the diff case does not determine what its inside pinions/spider gears are..... all you can tell from the outside is if it is a 8" or a 7.5"
Old May 21, 2005 | 06:47 PM
skdave's Avatar
I ordered a V6 EZ Locker for it. So I'll find out for sure when I open up the diff to install it. If it turns out to be a 4cyl diff I'll return the EZ Locker and get a 4cyl Aussie Locker.
Old May 21, 2005 | 08:21 PM
jimbo74's Avatar
i dont quite understand this.... there are 4 or 2 pinion setups of side gears for both a v6 and a 4 cyl... i dont see why or how you are saying its a 4cyl if it has a 2 pinion.....
Old May 25, 2005 | 08:50 PM
mtnfreak's Avatar
Look here for some good info. My plate says I have the 4cyl diff, but the case matches the 6cyl version. I've yet to crack it open and count the pinions.
Badlander
Oct 10, 2015 08:05 PM
toyotasaurus
Sep 24, 2015 03:30 PM
mordell
Sep 12, 2015 10:13 AM
zz_denis
Sep 6, 2015 03:43 PM
