Turbo 4runner start up, almost done
Old Jan 5, 2014 | 05:53 AM
  #341
Robb235's Avatar
Originally Posted by Texas_Ace
Nope, no problem. The meth injection should be reading the pressure from the intake manifold, with the throttle closed there is no boost in there.
Got it.
For some reason I was thinking the water/meth referenced boost pre-throttlebody.
Old Jan 5, 2014 | 06:20 AM
  #342
Texas_Ace's Avatar
Originally Posted by hrt4me
Texas_Ace, I'm also in the DFW area; would you be willing to get together sometime to help walk me through this stuff?
Well my truck is down right now so might be better off just PM'ing me any questions you have or better yet post a thread and I will post in there. I much prefer to help people in threads for the most part as it leaves the info around for others to use.
Old Jan 5, 2014 | 06:29 AM
  #343
Robb235's Avatar
Working on your turbo build?
Old Jan 5, 2014 | 06:39 AM
  #344
Texas_Ace's Avatar
Well that was the plan until my balljoint broke last year. That put it on jackstands until I can afford to fix it. Luckily it is fixable, sadly it is not in the budget for some time.
Old Jan 5, 2014 | 09:13 AM
  #345
vasinvictor's Avatar
I don't run a BOV. But, TA got to it before me. When my my throttle plates shut, the boost goes instantly to vacuum. It doesn't slowly loose boost. Thus, meth injection won't be a problem at all. Timely post, I'm wanting to go meth injection now also...
Old Jan 9, 2014 | 07:27 AM
  #346
Robb235's Avatar
Buying a kit? Building your own? Running washer fluid, straight methanol?
Old Jan 9, 2014 | 08:16 AM
  #347
Definitely building a kit. Probably a simple setup with a boost pressure switch. No plans for straight methanol yet. I need to work on my valve body before I go straight meth and crank up the boost. I just want to be able to run 7-8psi without worrying about EGTs. I'm staying at 5psi until I get a wideband. I'll update my build thread https://www.yotatech.com/forums/f2/v...-setup-274414/ when I make any changes.
Old Jan 9, 2014 | 08:31 AM
  #348
Texas_Ace's Avatar
Straight meth really won't effect anything, if you have access to it, run it. I always get better performance with it.
Old Jan 9, 2014 | 08:33 AM
  #349
That will be the problem. I'll have to try to find a drum somewhere because I live 30 miles from anywhere rural Arkansas. Windshield washer fluid or water will be much easier to come by.
/edit: it appear my "local" race track is one of two places in Arkansas to get methanol.
Old Jan 9, 2014 | 08:41 AM
  #350
Texas_Ace's Avatar
lol, year race tracks generally have it. If the price for a drum is under $200 then I would dot that. Otherwise the coldest blue washer fluid you can get will work as well.
Old Nov 19, 2016 | 08:27 PM
  #351
Clownmeat's Avatar
Been some years but still going strong.
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
williemon
Jun 21, 2002 01:32 PM
