Turbo 4runner start up, almost done
Old May 11, 2012 | 04:46 PM
  #301
Clownmeat's Avatar
One waterproof, high flow, inline, lifetime, washable, heavy duty air filter.
Old May 11, 2012 | 05:01 PM
  #302
Texas_Ace's Avatar
Interesting setup, should work nicely, surprised there were not any pre-made versions of this.
Old May 11, 2012 | 05:53 PM
  #303
Clownmeat's Avatar
Me too. I did find two, one was way to small and the other was almost $300.
Old May 12, 2012 | 03:01 PM
  #304
Clownmeat's Avatar
I'm all snorkeled up now. Ran out of neoprene hose and had to finish the snorkel to filter bit with some flex aluminum.
Old filter compared to the new one.
Old May 12, 2012 | 03:04 PM
  #305
BMcEL's Avatar
Looks good. Any worries about the turbo cracking if you submerge it in water?
Old May 12, 2012 | 05:07 PM
  #306
Clownmeat's Avatar
Nope.
Old May 12, 2012 | 05:30 PM
  #307
Texas_Ace's Avatar
Notice any performance difference?
Old May 12, 2012 | 06:18 PM
  #308
Clownmeat's Avatar
I started drinking before I finished it so I haven't had a chance to drive it yet.
Old May 13, 2012 | 06:46 PM
  #309
ETRNL's Avatar
This question is directed to clownmeat and Ace. How did you guys disable the atrac? An ABS switch? Locking the center diff? I am not looking to do burn outs but I do belive that the engine cutting out under boosted power could potentialy be very bad. I have been trolling both your threads from the get go. I am planning and buying parts to do a combo of both of what Yall have done.
Old May 13, 2012 | 07:36 PM
  #310
Texas_Ace's Avatar
Not sure about clown but that was never a problem for me as the 2000 does not have any kind of traction control. Only your right foot.
Old May 16, 2012 | 09:33 PM
  #311
ETRNL's Avatar
Good to know. Found a fix for me, andymod 2.0.
Old May 17, 2012 | 07:40 AM
  #312
cpizzle42's Avatar
Clown you should put a condom of some sort over your air chuck on your frame. I had mine in a similar spot before I tore my on board air set up off and it would always be jammed up with rocks, dirt, etc. Just an idea.
For your filter cansister, did you look what Cummins had to offer? My dad has a nice Cummins filter housing on his Razor 800.
Old Jul 30, 2012 | 08:22 PM
  #313
Clownmeat's Avatar
Home made turbo is still going strong, has been completely submerged, no complaints.
Old Jul 31, 2012 | 06:14 AM
  #314
5runner's Avatar
so awesome thats some good fab work on all the part!!!
Old Sep 13, 2012 | 06:18 AM
  #315
faisal216's Avatar
hello
what do you have for ignition retard...? or is it safe at 4-5 psi ?
i have a toyota prado year 2000 planing to do a remote turbo for it....
Old Sep 13, 2012 | 10:52 AM
  #316
Clownmeat's Avatar
Originally Posted by faisal216
hello
Stock ignition and fuel system at 7psi, runs great.
Old Dec 23, 2012 | 05:17 PM
  #317
Clownmeat's Avatar
It has been almost a year but I finally had something on the turbo system fail. Went out wheeling last weekend and started to smell burning oil, got out and looked under the truck to see oil dripping from the turbo area. Turned around and got it home in time without the oil light coming on. By the time I got home it wasn't dripping but spraying oil. After towing it to work and looking at it I found the solid steel oil feed line from the engine to the turbo finally cracked from shaking around. We talked about putting in a couple feet of braided flex before the turbo but I totally forgot about it and never got around to doing it. So I re-flared it for now, added 3 quarts of oil and ordered a flex turbo feed hose. Could have been a lot worse I guess, I shouldn't have overlooked one of the most important components of the system.
Old Oct 10, 2013 | 05:28 AM
  #318
t100 noob's Avatar
wild idea... 5vzfe... toyota truck.... t100 1/2ton 8ft bed single cab.... 7lbs boost whatcha think?
Old Oct 10, 2013 | 06:51 AM
  #319
Texas_Ace's Avatar
Sounds like fun. With the new CX racing turbo kit that just came out : https://www.yotatech.com/forums/f2/3...bo-kit-272568/
Turboing the 5vz is more practical then ever.
You will need fuel mods as well.
Old Oct 10, 2013 | 09:41 AM
  #320
t100 noob's Avatar
that kit looks like garbage though haha, whatre you setting me up for ta? lol i like the remote turbo idea because of the truck size i have soo much room to work with..
