Turbo 4runner start up, almost done
Old Apr 9, 2012 | 05:52 PM
  #281
Clownmeat's Avatar
Originally Posted by yotasavg
Ah thanks BMcEL, I totally missed that.
Clownmeat, does it just cross directly across the rear by the crossmember? like where the rear tire used to mount? Any completed under pics that show the whole system?
It's not completely piped yet but when it is I will get some pics up. I just got the high temp neoprene flex hose today.
Old Apr 10, 2012 | 02:09 PM
  #282
Clownmeat's Avatar
Here is the air duct hose, good to 350 degrees ,I can't smash it by squeezing it with my hand, doesn't kink when it's bent tight, should do the job.
Old Apr 10, 2012 | 02:10 PM
  #283
yotasavg's Avatar
Wow that looks pretty sturdy. Is that for intake or exhaust or both?
  #284
Texas_Ace's Avatar
Looks a lot like the stuff that comes with the STS kits.
Old Apr 10, 2012 | 08:33 PM
  #285
Clownmeat's Avatar
Just the intake, exhaust temps can get around 1500 degrees and glow red, this stuff is good to 350 which is fine for the cold side.
Old Apr 10, 2012 | 08:36 PM
  #286
Clownmeat's Avatar
Yes it does, only thing I came across that does what I want it too at the moment.
Old Apr 12, 2012 | 06:52 PM
  #287
Clownmeat's Avatar
So on a cfm calculator a turbocharged 3400cc motor can suck up to 720 cfm at 6000 rpm. The inline filters I have found only do about 450 cfm like this one.
Maybe I need to biuld a big sealed airbox full of foam so it doesn't hinder performance.
Old Apr 13, 2012 | 06:50 AM
  #288
Texas_Ace's Avatar
Those calculators are not real accurate, the numbers vary wildly depending on what motor you are talking about since some flow much better then others.
Though you will still be on the restrictive side with that filter I bet.
Old Apr 19, 2012 | 03:42 PM
  #289
ETRNL's Avatar
So I read through this post and didn't see anything about modification to the engine management. So are you running the stock computer and engine with boost? No engine work needed to lower compression? More air means more fuel. Compensating with meth?
Old Apr 19, 2012 | 06:22 PM
  #290
Clownmeat's Avatar
Screwed in some colder plugs and run premium fuel, it's good. It can get a bit lean at times and could benefit from more fuel but doesn't knock or cause a problem so it's good.
Also there is this bit of info from TRD,
Installation Instructions for 3.4-liter V6 Supercharger Kit
1996 and newer 4Runner, 1997-1998 T-100,
1997 and newer Tacoma, 2000 and newer Tundra
Supercharger Instruction FAQ’s
1. Would it be a good idea to install a fuel
pressure regulator along with the supercharger?
No. After extensive testing, TRD has learned that the fuel system has sufficient capacity to deliver the additional fuel to match the additional air induced by the supercharger.
Old Apr 19, 2012 | 06:32 PM
  #291
Texas_Ace's Avatar
TRD lies, it has been proven time and again that the stock fuel system is not near enough.
Think it was speedy that logged the EGT's and AFR's. They SKYROCKETED with stock fuel system in place.
Lucky for us the 5vz is a very stout motor and has good knock control so it doesn't usually damage things quickly but don't be fooled into thinking that it is ok, far from it.
Old Apr 19, 2012 | 06:37 PM
  #292
ETRNL's Avatar
So with colder plugs and meth injection this setup will perform correctly and be safe for our motors without any engine mods?
Old Apr 19, 2012 | 07:19 PM
  #293
Texas_Ace's Avatar
With meth injection (preferably with pure methanol) you will be fine. It both adds the fuel you need and makes it FAR less knock prone. Also lowers EGT's.
I was running more timing with meth injection and 12psi of boost as it runs stock NA.
Old Apr 19, 2012 | 07:36 PM
  #294
Clownmeat's Avatar
I'm not using meth yet just stock stuff, it isn't perfect but it's fine at 7psi. I have seen them go 220k miles supercharged with the stock fuel system, good enough for me. Also being turbocharged my intake air temps peek at 130 degrees which is way lower than supercharged ones.
Old Apr 21, 2012 | 01:53 PM
  #295
ETRNL's Avatar
So can you inject meth into the boost tube or do you need to inject into the intake through the turbo?
Old Apr 21, 2012 | 01:55 PM
  #296
Texas_Ace's Avatar
Best place to inject it would be at the turbo exit in his setup, give the most time for the meth to atomize and be absorbed.
Also want to try to keep droplets from hitting the MAF sensor if possible.
Old Apr 21, 2012 | 04:42 PM
  #297
ETRNL's Avatar
So with meth and pre-intercooler piping intake temps should be well below ambiant temps right?
Old Apr 21, 2012 | 05:18 PM
  #298
Texas_Ace's Avatar
Depends how much meth was being injected but that is possible for sure.
How much the meth cools the charge is directly related to how much you inject, you can calculate it if you have enough data actually.
Old Apr 26, 2012 | 03:51 PM
  #299
Clownmeat's Avatar
Found a suitable filter 12" long 6.5" diameter and a 3" radial seal, just need to build a housing.
Old May 10, 2012 | 07:38 PM
  #300
Clownmeat's Avatar
Got most of the stuff, should have time Saturday to fab it up and install it.
