Rear springs...
Old Dec 19, 2003 | 02:11 PM
4RUNR's Avatar
Guest
Rear springs...
I've searched, but maybe you folks can make the solution more concise.
What I'm trying to do, in order of priority:
#1 Be able to have 500lbs in the back without too much sag
#2 Get better handling when empty, it feels very loose and bouncy now in the back
#3 Get a small lift out of the process
#4 Offroading is not a priority
Old Dec 19, 2003 | 02:50 PM
MTL_4runner's Avatar
Performance Products coils for 1" of lift.
Old Man Emu HD coils (881/891) for 2.5" of lift
Your call.
Old Dec 19, 2003 | 03:08 PM
4RUNR's Avatar
Guest
What are the average prices for either one retail and used market?
Also I assume with the +2.5" coils stock shocks will go kaput pretty quick?
Old Dec 20, 2003 | 06:29 AM
Unhappy99's Avatar
Air bags inside the coils and good shocks like Bilstein. Pump them up when you need them, let them down when you don't. Doesn't change ride height when deflated, adds about 1.5 inches when fully inflated and unloaded.
Mine will take 35psi max which adds 700lbs or so of carry capacity. I usually run 10 psi when unloaded as I like the firmer ride.
Old Dec 20, 2003 | 07:04 AM
4RUNR's Avatar
Guest
And no need to take apart the strut and everything else?
That would be ideal!
Are there any good FAQs on bags?
I just got done driving about 1450lb of tile evenly distributed in the back with seats down and the stock springs left only about 3" between the tire and the fender
Old Dec 20, 2003 | 07:59 AM
Unhappy99's Avatar
Air bags actually go inside the coils. Basically, you disconnect the rear antisway, jack up the truck with two jacks, one under each spring seat, then lower one jack. The lowered side spring just pops out and you install the airbag. Depending on model year, the axle bump stop has to be cut per the instructions which came with the airbags. It's not a difficult job, took about 1.5 hours (I work slow) to get the airbags in, and another hour to route the hoses. Just behind the rear mudflaps are holes in the bumper, a most convenient place for the air valves.
Mine are TRD (Firestone) air helper springs from RomaniaToyotaParts.com
Old Dec 20, 2003 | 08:03 AM
The airbags will only help the rear of the vehicle, it does nothing for the front.
New springs are a more longterm solution but for price you can't beat the airbags.
Old Dec 20, 2003 | 08:21 AM
Unhappy99's Avatar
I debated going to different springs as well. What I really wanted was a stiffer spring with unchanged ride height. Couldn't find any, so I took the airbag and HD Bilstein shock route. Been working for 2 years, and I like them.
Old Dec 20, 2003 | 08:22 AM
Unhappy99's Avatar
inline
Old Dec 20, 2003 | 08:49 AM
4RUNR's Avatar
Guest
Ordered them. thats a good price
http://www.wheelersoffroad.com/trd.htm
Should I get a pair of "Bilstein Yellow Rear Shocks, TRD Tundra: 71.90/pr" too while I'm in the wheel well? 84k miles on originals I think.
Toyota parts are almost free in comparison to German
Old Dec 20, 2003 | 09:09 AM
Unhappy99's Avatar
84K on original shocks???? No wonder it bounces back there. Toyota shocks were crap when new. Mine would never settle in a turn until I put on Bilsteins.
My Yellows came from a local Autozone for $65 each or so. ICBW, but my understanding is that TRD Bilsteins are softer valved than normal HD Bilsteins. I went with the normal HDs. Can also get them from Shox.com.
Fronts install easily. Rears are a pita. There is a write up here somewhere.
Old Dec 20, 2003 | 08:03 PM
4RUNR's Avatar
Guest
Ohh man. I ordered some 265/75/16 Revos too while I have the card out :cry:
Btw, how often do 4Runners need an alignment?
Old Dec 21, 2003 | 07:42 PM
Unhappy99's Avatar
Anytime it steers strangely or you see tires cupping. They are pretty good about holding an alignment, takes a significant whack to knock them out.
Old Dec 31, 2003 | 07:55 AM
4RUNR's Avatar
Guest
YES! I got them in without dropping the car on myself
Unhappy, in your professional opinion how long would these things last? Given they are made by Firestone in a TRD box So far by the feel of them they are exactly what I wanted.
The manual recommends 5-35psi. Think 35 has a built in safety buffer? I tried 20psi and the walls don't seem that thick.
Old Dec 31, 2003 | 10:08 AM
Well, I decided to order a pair as well until I can upgrade to OMEs.
I am not sure if they will fit my 1996 or not but at $50 I can afford to try.
The price on them is just amazing.
Thanks for the install pics too!
Old Dec 31, 2003 | 10:19 AM
4RUNR's Avatar
Guest
I got a 7/8" lift by the way at only 10psi, which feels just right when empty.
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
