OEM mini header install for 2.7L*(Pics)*
Old Jun 7, 2009 | 02:31 PM
  #81
DeathCougar's Avatar
http://www.tankota.net/repair/Repair...c2r/torspe.pdf
This is the closest I think you will get
Old Jun 7, 2009 | 05:49 PM
  #82
dport's Avatar
Guest
Thanks a lot. I ended up just cinching em down a bit, and torqueing the nuts to 36 ft lbs. It's all together now and running great. I'll have to load a pic of my busted manifold later.
Old Jun 10, 2009 | 07:01 PM
  #83
gornish_hick's Avatar
looks good man.
is the manifold crackin like that a common problem with the 2.7?
Old Jun 10, 2009 | 08:58 PM
  #84
Very very common. In fact, I have found that its not a "will it happen" issue, its a WHEN will it happen issue.
Old Jun 11, 2009 | 09:18 AM
  #85
dport's Avatar
Guest
Mine lacked about 1 1/4 inch before becoming two pieces with only 148K on the truck.
Old Jul 3, 2009 | 07:07 AM
  #86
tonythebullet's Avatar
Sorry for bumping an old thread and asking a question that might have been asked before. But I think it might help others in the same situation as myself.
I have a 98 4Runner with the 3RZ. I am looking to do the OEM mini-header install as a precaution. I have found a manifold off a 2003 Tacoma with a 2.4L motor. I am pretty sure that the manifolds are interchangeable between the 2RZ and 3RZ. I was hoping that one of the experts can kindly confirm if this is in fact true. Should I be concerned with the flange size (3.75" vs the 4.25")?
Thank you very much.
Old Jul 3, 2009 | 07:16 AM
  #87
Manifolds have different part numbers according to Toyota. Not really sure why.
Old Jul 3, 2009 | 08:57 AM
  #88
I think the part numbers are different because the heat shield mounting bolt locations are different on the cast iron vs tubular manifolds. Both manifolds use the same gasket to mount to the block so there shouldn’t be any problems in that aspect. I mostly have doubts over the downpipe flange - the part numbers for that particular gasket are different. Its taken me 2 months of rigorous hunting to get a great deal on the manifold locally so hopefully I won't have to pass up on it.
Old Sep 17, 2009 | 08:04 PM
  #89
ChildrenOfBodom's Avatar
I replaced mine with LCE headers when I bought it. It had a giant crack. I ripped it in two just for giggles with my bare hands (have the video, if anyones interested ill put it on youtube).
Attached Thumbnails OEM mini header install for 2.7L*(Pics)*-p5260616.jpg   OEM mini header install for 2.7L*(Pics)*-p5260618.jpg
Old Dec 1, 2009 | 01:40 PM
  #90
ltgvolsrock1's Avatar
ok i found a mini header at a local junk yard. its off a 02 tacoma. im wanting to drive up there and get it in a few weeks. i plan on putting it on a 99 tacoma.. do i need to just get the 99 exhaust gaskets from local autoparts store or do i need the 02 gaskets???? will i need to get all of this i found on DEATH COUGAR page
Head pipe studs
Head pipe nuts
Header attachment nuts
EGR Pipe studs
EGR pipe nuts
sorry for the dumb questions i just want to make sure i get every thing i need before i start. thanks
Old Dec 1, 2009 | 03:53 PM
  #91
Do you HAVE to? No. Would it make life 400x easier? Yes for sure.
Old Dec 1, 2009 | 05:14 PM
  #92
CDUFF7's Avatar
damn, I still need to do this!!!
Old Dec 1, 2009 | 06:22 PM
  #93
I do still offer these kits for sale
Old Jan 10, 2010 | 02:14 PM
  #94
herdnerd's Avatar
I finished my mini header install several weeks ago. The old manifold was in pretty bad shape. Someone had tried to weld it.
I used 1300 degree stove pipe spray paint to cover the mini header.
I had been getting a P0420 code every so often before the swap. Its been about a thousand miles since then and haven't seen the MIL yet. I have read that exhaust leaks can cause that code so I don't know if it was the crack or a leak at one of the gaskets. Hopefully it won't be back.
I checked prices at several of the online toyota parts retailers. I asked my local dealer if they could beat their price with shipping and they said they would so I bought it locally instead of online. Plus, it was at the dealership the next day rather than waiting several days.
Thanks for everyones help posting part numbers.
Old Jan 10, 2010 | 02:37 PM
  #95
MuddfreaksOffroad's Avatar
i need to replace the exhaust manifold on my truck too how much did that one cost? I have a 20r tho ill prob just get another 20r exhaust manifold if i cant get a header!
Old Jan 16, 2010 | 07:11 AM
  #96
norms96's Avatar
Great thread, this needs to be a stickie.
Old Feb 22, 2010 | 09:52 AM
  #97
96redtoy's Avatar
Little update on mine--
Its still awesome, no leaks or anything bad yet.
The paint still looks perfect which is amazing to me because all other exhaust paint i have ever use looks like crap after a month.
DC's kit looks very complete and I wish it was avialable when I did mine would have been a lot easier.
Still no heat sheild and no melted wires
I have put close to 20,000 miles on the mini with no issues
Please pm me if you have any questions I would be more then happy to answer them for you.
Old Apr 30, 2010 | 03:11 PM
  #98
tombourn's Avatar
Can anyone give me the part number for the mini header? My best friend is a business manager at a Toyota/Scion Dealership and can getitfor me at cost/
Thanks
Old Apr 30, 2010 | 03:48 PM
  #99
If he is the business manager, have him talk to the parts manager and get it that way!?
Old May 17, 2010 | 09:32 PM
  #100
NwRunner's Avatar
picked up mine today. no more leaky manifold!
thanks DC
