OEM mini header install for 2.7L*(Pics)*
Old Mar 25, 2011 | 12:30 PM
  #121
99 sas runner's Avatar
Originally Posted by DeathCougar
2RZ and 3RZ use the same manifolds. But the manifolds are JUNK.
Shoot me a PM or call me when you want to upgrade to the header conversion. No more cracked headers, no more burned valves, no more cracked heads
If you ever talk to someone fixing a head issue on a 2RZ/3RZ, they are always repairing Cyls 2 or 3.
i meant header. i found one off a 03 taco locally for 80$
here is my head # 2 cyl
Old Mar 25, 2011 | 12:55 PM
  #122
will a 2003 2rz header work?
Old Mar 25, 2011 | 02:25 PM
  #123
DeathCougar's Avatar
Yea, that should work just fine.
Do yourself a favor and order my "Hardware only" kit, which is all new studs, nuts, and gaskets. You will thank yourself when you try and install the new header.
Old Mar 25, 2011 | 02:42 PM
  #124
how much?
Old Mar 27, 2011 | 07:17 AM
  #125
Many Toyotas's Avatar
Question OEM mini header install
Anyone ever try to use a calif. hedder on any federal 4 cyl. , looks nice, but only one large exhaust outlet, and also no provision for heat tube ???
Old Aug 23, 2011 | 06:00 PM
  #126
superswamper003's Avatar
I bet it sounds beefy!
Old Oct 7, 2011 | 08:52 AM
  #127
rkpyota's Avatar
After reading this segment then finding out I had a cracked manifold as well. I started looking. I found one in a salvage that they say is a different part number than what I have seen. its a 1714175090 instead of the 5080. Do you guys know if this will fit a 99 4runner 2.7L.
Thanks
Old Oct 7, 2011 | 09:48 AM
  #128
Thanks
17141-75090 is a 2WD 2RZ header.
I cannot confirm that the 2RZ part will work on a 3RZ motor. The header kits I sell use the 17141-75080 Mini-header.
Old Oct 22, 2011 | 09:45 PM
  #129
Joelh82's Avatar
Just did this install today myself. Definitely soak all the bolts down with some good penatrsiting oil. Also you will need to swap over the studs for the erg tube and exhaust flange, the correct sockets will save you a lot of trouble. Was an easy install, didn't even remove the intake to do it. Performance wise not really any difference but I would say it is quieter than the stock manifold with no cracks.
Old Oct 22, 2011 | 09:48 PM
  #130
Joelh82's Avatar
And anyone wondering about the 2.4 vs 2.7 manifold, it's the same part. I used the 2.4 manifold on my 2.7 engine. I got it from a local wrecking yard.
Old Dec 16, 2011 | 07:25 AM
  #131
mister_dmac's Avatar
I'm convinced this manifold leak is limited my fuel economy. So Cougar, I'm gonna ring you the next few days to order one of these puppies. What I wanted to know from you guys is, are people having any appreciable gains performance/MPG wise? Sound different? Won't stop me from getting it, since I don't really mod for performance, I work toward longevity and fuel efficiency...at least until I get a truck with fewer than 195 K miles on it.
Old Dec 16, 2011 | 07:28 AM
  #132
I have had people report everything from a noticable difference, to no difference at all. The big gain is no more cracked manifold, which gets spendy over time.
Old Feb 4, 2012 | 05:46 PM
  #133
RB4runner's Avatar
I wish I would of ordered these instead. The LCE headers arent fitting right... It is hitting my sway bar mount.
Old Feb 4, 2012 | 06:44 PM
  #134
TacomaG's Avatar
Thanks yotatech!
Hi folks,
Just wanted to express appreciation to all contributors to this thread...
Also, wanted to give a tip to folks doing this in the future: the down-pipe does not need to be disconnected from the tranny bell housing, nor do the exhaust hangers (just downstream of the cat) need to be disconnected...if the following can be done:
1. Remove the six (6) E10 studs from the engine block (comes out super easy, but lots of threads/rotations)
2. Remove the three (3) E8 studs from the exhaust manifold that is to be changed out. These hold the header to the down-pipe. If you can sum up about 18" - 24" of extensions using ratchet extensions, deep sockets, etc, this is a cinch.
3. Leave the two (2) E7 studs to the EGR line in the manifold, and the exhaust manifold will pull right out.
Installation is equal and opposite. Some folks will probably find that lowering the exhaust is easier...I didn't because I've got a small stainless steel plate welded under my catalytic converter with spikes on it to protect it from theft!
Old Feb 5, 2012 | 08:51 AM
  #135
Only thing I would do different is not remove the studs from the head. Reason being, I have seen many studs pull out the threads in the head itself. Then you have to helicoil the head.
Old Feb 5, 2012 | 09:20 AM
  #136
Moonfish's Avatar
All I noticed was the exhaust sound moved from the front more to the rear.
Old Feb 5, 2012 | 04:47 PM
  #137
TacomaG's Avatar
After mini-header install: water drip on cold start up
DC, I think you're right, I'd try it w/o taking the studs out of the block first also.
One thing is for sure: the EGR studs seem to be impossible to remove while the old manifold is installed b/c of a lack of clearance & the threads seem to smashed down inside the manifold by design.
Insight requested:
I just changed to a good condition/used mini-header w/ all new gaskets/hardware from DC.
I noticed two water condensation drops drip down from my exhaust manifold upon cold start up. The two drops of water fell from somewhere behind my modified heat shield (where the mini-header bolts to the block). The water dripped down to just in front of my right inner tie-rod bellows.
I'm sure it's water b/c I soaked it up w/ a napkin.
I torqued all 14 mm bolts to 37 ft-lb.
I torqued the EGR's 12 mm bolts to something around 30 ft-lb.
Do the 2 drops of water mean that I have a small exhaust leak from somewhere on my new mini-header/gaskets?
Note: the old, cracked, cast iron manifold leaked exhaust smells into the engine bay, but the freshly installed mini-header does not.
My gas mileage on a 200 mi drive at 70 mph is 25.5 mpg, about 1 mpg better than before and engine runs smooth as silk.
Thanks for any insights!
Old Feb 26, 2012 | 03:48 PM
  #138
livetoskate's Avatar
Thumbs up
Very Helpful Thanks
Old Feb 26, 2012 | 03:52 PM
  #139
jmfranc's Avatar
I just did this mini header install and had a couple questions for you all:
1. I decided to paint mine with the same high temperature paint - 2 coats - and after getting everything back together and got her started the header started smoking a lot where it meets the main exhaust (the three bolt piece) and wondering if it was burning off the paint or some of the oil from when the header was made. It had a sweet smell - almost caramel-like. It seemed to stop after driving it for 15 minutes - but it got dark out and maybe I didn't see it
2. how important is it to get a heat shield for this one? I'm thinking its not a big deal but I do live in the South and it gets way hot here in the summer. Never had a problem before but wanted some input
Old Mar 13, 2012 | 06:37 PM
  #140
Tacoma in Tacoma's Avatar
So, much thanks to all of the posters in this thread. It's been a great help! So, my 1995 Tacoma 3RZ (2.7l) cast iron header is badly cracked. I researched on this thread, and thought the consensus was that a 2001-2004 2RZ (2.4l) mini header would bolt right on my engine. I found one in a junkyard, and had it mailed to me. Upon inspection, it has a different (triangular) flange, and only one opening. Mine, and all the other ones I saw online, had two openings, and used two donut gaskets.
How did I screw up? Did I get a CALI header, which is somehow different than a federal header? Are they not actually interchangeable? Any advice would be greatly appreciated. Thanks!
My newly purchased header:
