AndyMod 2.0. ABS Remains Active.
Old Sep 7, 2019 | 03:27 PM
  #61
iknownothing's Avatar
Originally Posted by aowRS
I’m the ‘Andy’ behind the AndyMod. My 4Runner is a 2001 SR5 4WD auto.
Andreas
Thanks, aowRS. I appreciate the quick response. Now I can move forward with confidence.
Old Sep 9, 2019 | 06:03 AM
  #62
liftedorlowered's Avatar
“One week” later...
Originally Posted by liftedorlowered
I know this thread is long dead, but there's such a need for this mod (VSC and TRAC sucks on my wife's T4R), so I'm posting to it for posterity. It's my wife's car, she doesn't mind VSC and TRAC, and it regularly almost kills me. I'm sure that I'll turn it off when I drive it, then my wife will get in it and be pissed off at me when she has to toggle the switch and then restart her car. My thinking is that (since it requires a restart to re-enable the traction control), I can install a momentary switch that defaults to closed circuit and then opens when you press it. I'm thinking if you push it in and hold it, it'll disconnect that circuit long enough to kill the VSC and TRAC and then when my wife goes to drive it, it'll be stock again. Ordered the switch, I'll update this thread when I get it done (shouldn't be more than a week or so).
Haha, so 3 years later... I did this as I described shortly after my above post, and it works like a charm. We’ve been using this mod for years now, and it’s great.
Old Mar 30, 2020 | 12:37 PM
  #63
Brandoneh336's Avatar
where is the wire that isnt conncted to the V18-3 pin going?
Old Apr 29, 2020 | 09:43 PM
  #64
varocketry's Avatar
Any Sequoia owners here doing AndyMod 2.0
This popped up again for me as high interest. Although I've had the Stealership replace most of the ABS systems' under hood components, my 2001 Sequoia is at the age where wheel sensors and center console located YAW sensor are throwing errors intermittently and sometimes causing rough and potentially dangerous driving as they shake and shutter.
I never did the AndyMod focused on the connectors at the Master Brake cylinder because the 2001 Sequoia Master Cylinder doesn't look like the MBC used in the T4R solutions.
Is there a cross-walk solution tested and working for the early Sequoias? Any Sequoia owners here?
Old Oct 19, 2020 | 08:57 AM
  #65
552jrider's Avatar
I know this is an old thread but I just did this to my 02 and I can't seem to get the vsc or trac to turn off, no dash lights with the switch in either position or it unplugged all together. Any ideas?
Old Dec 29, 2021 | 04:04 PM
  #66
D0rkmatt3r's Avatar
Will a rocker switch work just as well
My question is will the ABS remain active in the 2.0 mod if a rocker switch is used and left in the off position...?
Old Jan 17, 2022 | 04:47 AM
  #67
Brentmia2018's Avatar
Wiring color for 2wd
Originally Posted by Rock Slide
I’m putting this updated information out there to better reach the masses. YT member aowRS created the AndyMod. YT member Beto recently discovered an update to it; Thus, I'm passing that updated information along. Beto also created his own version of the AndyMod, better known as the “Bagel Mod”. (For more information on that mod, view his thread here: https://www.yotatech.com/forums/f2/n...switch-195040/.)
In this 2nd version of the AndyMod, ABS remains active. Granted, you will still have to kill the engine to regain VSC & TRAC just as before, but the good news is, ABS remains active throughout the entire process (it was disabled in the 1st version). Plus, there’s no need to run a pair of wires thru the firewall as previously done. All the connections are now made under the dash. You decide which version of the Andymod you prefer.
Here's a link to the original AndyMod: Click Me
AndyMod 2.0:
Locate the VSC computer under the dash near the driver’s kick panel. The connector you are interested in is the 2nd one from the top (V18). Pull this connector out and locate Terminal V18-3. It’s a Red wire with Black Tracer. (EDIT: Note that the pin diagram below is as you look at the back of the connector - where the wires go into the connector.) Thanks Beto for the photo.
Skid Control (VSC) ECU Under Dash:
Attachment 185607
I cut this red wire with black tracer and crimped a pair of new wiring to the cut ends. (Feel free to solder these connections if you'd rather):
Attachment 185608
Ran the pair of wires up to my dash mounted fog light switch:
Attachment 185609
Fog Light Switch Installed (on the right). Toyota switch Part#: PT297-89013-SW:
Attachment 185610
TRAC ON/OFF Decal Added:
Attachment 185611
I purchased the above decal from YT member Justdoitmikey. For more information on these decals, visit his thread here: https://www.yotatech.com/forums/f109...ticker-162624/
Once the switch is installed, you’re done. Simply activate the switch in either 2WD or 4WD with the vehicle on or off. Wait a few seconds and you’ll notice both the VSC and TRAC OFF lights appear to let you know they have been disabled. Flip the toggle switch back and restart your vehicle to regain VSC and TRAC.
hey so I own a 2001 2wd the wire colors are not the same as this I was wondering if someone knew the VSC/TRAC wire color for the 2wd models
Old Jan 19, 2022 | 05:35 PM
  #68
Jsyzf450's Avatar
Cannot get lights off
So when I bout my 01 SR5 from a guy, he had the Andy mod installed. I was able to get lights on and off at first and they got kicked back on again. And it's been too long and I don't recall the sequence in pressing switches etc. It's a simple fog light switch, I thought he originally told me I had to press the transfer case button and then toggle the fog light switch but no matter what I try after restarting the truck they always come back on. The only thing I can do is get the ABS to come on and off. Help!
AndyMod 2.0:
Attachment 185607
Attachment 185608
Attachment 185609
Attachment 185610
Attachment 185611
Old May 25, 2024 | 12:26 PM
  #69
pindrums's Avatar
Can't find the switch!
[QUOTE=Rock Slide;51367537]I’m putting this updated information out there to better reach the masses. YT member aowRS created the AndyMod. YT member Beto recently discovered an update to it; Thus, I'm passing that updated information along. Beto also created his own version of the AndyMod, better known as the “Bagel Mod”. (For more information on that mod, view his thread here: https://www.yotatech.com/forums/f2/n...switch-195040/.)
AndyMod 2.0:
Attachment 185607
Attachment 185608
Attachment 185609
Attachment 185610
Attachment 185611
Old May 25, 2024 | 12:27 PM
  #70
pindrums's Avatar
Cannot find the switch PT297-89013-SW anywhere so I can start this process!
Old Apr 23, 2025 | 05:21 AM
  #71
LimitLess01's Avatar
2001 Limited issues
My truck has only 72K original miles on it. I have decent new tires (Nokian Outpost) that it came with. When driving in winter, there are times when it refuses to get traction on a flat surface in 4WD.
Traction control seems to jump in when it isn't necessary. I also have an undiagnosed parasitic drain (appointment to diagnose tomorrow) and
I am wondering if the TC could be to blame. Also, sometimes (not on slippery or wet roads) the truck will refuse to start up from a stop when accelerator is pressed,
such as at a stop sign, but after a few seconds it will go. Could this be related to TC or VSC?
blcktpgsr
48
May 24, 2019 05:09 PM
Gargoyle_Runner
Jan 27, 2015 08:09 PM
BC4Lyphe
19
May 1, 2013 09:05 PM
OutlawMike
Sep 13, 2011 06:38 PM
garrett1478
18
May 14, 2010 06:48 PM
