4" Deck Plate mod question
Does it matter what side of the air box the deck plate goes. I would think on the front so that you get the cooler air coming directly in. If mounted on the engine side of the air box it seems logical that it will draw in the warm air from the engine and kind of defeat the purpose of the deck plate wouldn't it? I am planning on doing the deck plate mod in a few days, let me know what you guys think. I have the 2.7L 02 Taco 4x4. As always- A MILLION THANKS- Mike
Also make sure the hole is in front of the filter as best you can.
Originally Posted by MTL_4runner
It should always be facing forward not on the side as you had suggested.
Yes, in the front.
You will be glad you did it. I don't use mine nowadays, since I installed the SuperCharger, but before then, it was very helpful. The reason I don't use it now is because my Sherpa pings pretty badly at times. I don't want any more air than necessary getting in there until I can do the URD fuel kit upgrade.
-Scott
Originally Posted by tylus
where can I get a deck plate? I went to Home Depot and couldn't find one. Are they called anything else.
Deck Plate
TransAmBandit
Jul 28, 2015 11:30 PM
