Z's Confederate Toy's 1987 Pickup Build-Up Thread
Old Jul 27, 2011 | 09:23 PM
  #781
ChefYota4x4's Avatar
Aint that fresh Aluminum sexy? lol. GET'EM'ZACH! lol. Any other news?
Old Jul 27, 2011 | 10:36 PM
  #782
Z's Confederate Toy's Avatar
It sure is!! Other good news: Colorado Toyota Jambo is this weekend. I am gonna knock out the timing cover tomorrow and see it that does it for me. If not I will be rolling in the Ol Man's 85. Hopin I get to take mine though.
Old Jul 28, 2011 | 04:46 PM
  #783
twistedyota's Avatar
good luck
Old Jul 28, 2011 | 07:10 PM
  #784
KILL IT, WOOD! hehhehee.
Old Jul 28, 2011 | 09:21 PM
  #785
csuviper's Avatar
Nice build. Wish I could make it to the Jamboree this weekend. Busy with other stuff and not done with the truck yet.
BTW: I like the hood pins. Might have to do that to mine, even though the hood latch still works.
Old Aug 1, 2011 | 01:43 PM
  #786
Thanks! The pins rock. I jus need to figure out how to keep the hood secured so ppl dont have direct access to the engine bay. I gots some expensive stuffs under there.
I didnt get the truck goin for the Jambo so I took the 85. No big deal tho, I hitched rides mostly anyway. It was a kickass time. Great turn out too. I got a chance to talk in person with some of they guys down there about my engine probs and they all were sayin that it is almost undoubtedly the timing cover causing the water leak. I will get to doin it here soon. Gonna give the breaker bar/starter method to get the crank pulley bolt off, since the heat/impact method didnt work.
Old Aug 1, 2011 | 02:21 PM
  #787
csuviper's Avatar
I wish I could have made it still. Missing out on alot this year with my truck still in the works. No time to work on it though.
Yea I think i just used a long cheater bar and some quick tugs to get it loose.
Do you know the ins and outs of the vacuum lines? I have a few diagrams but they don't show exact routing in places. Maybe a video of your vacuum setup would help me???
The RE is probably different though.
Old Aug 2, 2011 | 11:06 AM
  #788
Mine isnt a RE its carbed. I will get you some pics while I am doing the new timing cover today.
Old Aug 2, 2011 | 11:18 AM
  #789
csuviper's Avatar
Oops, should have just looked at the engine pics.
That would be very cool of you to send some pics. I only have the valve cover, exhaust and vacuum/filter housing to put back together to reserect the engine.
Old Aug 2, 2011 | 11:28 AM
  #790
csuviper's Avatar
Ah hah. I see why I thought it was a 22RE. I just ignored that the carb was right there too.
Old Aug 2, 2011 | 02:07 PM
  #791
I used this for my vac lines, http://www.bluebassdesign.com/boonin/carb_faq/. It seemed to help. I will still send you some pics to give you some more to look at.
Goin back out to finish it up after makin a parts run. Got another head gasket and some RTV.
Old Aug 2, 2011 | 02:13 PM
  #792
csuviper's Avatar
That diagram is much better than the ones I have been looking at. Thanks.
Old Aug 2, 2011 | 03:37 PM
  #793
No problem. Here are some pics of mine. Might add to the diagrams if you have any doubts.
Heres what the old timing cover looked like
And how the engine is sitting as of right now.
I have some stuff to check out before I slap it back together. Tryin to find out if there are oiler holes in some of the head bolt holes (in block) or if its cracked through. There seems to be some of that milkshake down in there.
Old Aug 2, 2011 | 08:52 PM
  #794
csuviper's Avatar
I really appreciate the pics. Its going to be next weekend before I can get to it now, out of town for work this weekend through probably wed.
My engine was at that point not long ago. Kept the same timing cover but replaced the water and oil pump.
Old Aug 2, 2011 | 08:56 PM
  #795
irab88's Avatar
wow, it looks exactly like when i did my repair
good work!
Old Aug 2, 2011 | 09:05 PM
  #796
Nice cant wait to see it runnin
good work!
Thanks. I decided to pull the whole thing and go rebuild. I saw some things that I didnt really like on the block, ie: worn cylinder walls
Old Aug 3, 2011 | 06:56 AM
  #797
irab88's Avatar
are you going to replace the chain guide with a metal-backed one?
Old Aug 3, 2011 | 08:12 AM
  #798
I will switch to a metal backed one to prevent the gouging again.
Old Aug 3, 2011 | 08:27 AM
  #799
irab88's Avatar
excellent. you'll be good to go for another 200k, then!
Old Aug 3, 2011 | 10:16 AM
  #800
I decided since I was already so far in tear down that I might as well tear out. Thankfully I did cuz those main bearings and rod bearings were awefully worn. There also was that nasty smell of burnt oil in there . I hate that smell. Crank looks pretty decent except for the ridges on the rear main.
Mains. The rods looked the same way
Pistons n rods out
Block to be used
