Z's Confederate Toy's 1987 Pickup Build-Up Thread
Old Oct 12, 2010 | 09:11 PM
  #201
Z's Confederate Toy's Avatar
There was an article in an issue of 4wd Toyota Owner about importing an Aussie truck. I will have to look thru my issues and let ya know about it
Old Oct 12, 2010 | 09:18 PM
  #202
1981 yota's Avatar
this sounds like a fun motor
15B-FTE
The 15B-FTE is a 4.1 L (4104 cc) inline 4 sixteen valve OHV direct injection turbo intercooled diesel engine. Bore is 108 mm and stroke is 112 mm, with a compression ratio of 17.8:1. Output is 153 hp (114 kW) at 3200 rpm with 282 ft·lbf (382 N·m) of torque at 1800 rpm.
Old Oct 13, 2010 | 05:19 AM
  #203
irab88's Avatar
15B-FTE
but will it fit? lol
Old Oct 13, 2010 | 09:41 AM
  #204
1981 yota's Avatar
i highly dout it lol
Old Oct 18, 2010 | 01:15 PM
  #205
I think I have found a diesel to put in the truck: Cummins 4BT!!!!! Itll be sick!! I am chewin ont the idea of doing a Commie Camo on the truck. So it would be red, white, primer grey, and black. And I am also thinkin about changing the cluster lights to either a blue led or a UV blacklight led. Im leanin toward the blacklight but im not sure if itll be bright enough.
Old Oct 18, 2010 | 08:35 PM
  #206
irab88's Avatar
uv would look cool. anything white would glow bright blue, so plenty of brightness (i think...)
Old Oct 19, 2010 | 07:11 AM
  #207
Yeah, I was thinking the same thing. I ordered a test bulb lastnight to see howit would be.
Old Oct 20, 2010 | 07:59 PM
  #208
I did a few things to the truck today. Got bored of the same ol same ol. Looks like I have some incoming cash ole so I can do some more serious mods.
Took the rear bumper cuz i annhilated it on the last wheelin trip I was out on.
Then I painted the whip springs flat black cuz they were rusting.
Old Oct 20, 2010 | 08:27 PM
  #209
irab88's Avatar
how much does the antenna hit the cab? i wanna make a mount, but don't want it to hit my camper shell
Old Oct 20, 2010 | 09:26 PM
  #210
Suprisingly, not too much at all. Unless the antenna is bent way over by a low branch. They are offset just enough that the cab doesn't really get in the way.
Old Oct 21, 2010 | 05:15 AM
  #211
irab88's Avatar
sweet. now to update my "to-do" list
Old Oct 21, 2010 | 07:38 PM
  #212
Most definitly lol. Its not a hard mod. My set up cost $20 for the ball mount, $20 for the spring, and $20 for the antenna itself. So, $60 per side/
I got the LED bulbs for my dash today. They arent bright enough so I am going to upgrade to 6 or 8 diode bulbs. The blue seems the way to go, the blacklight was too dark although I may try to paint the cluster white to get more glow out of it. I will have some pics up in a little while.
Old Oct 21, 2010 | 08:24 PM
  #213
irab88's Avatar
which ones did you order? i wanna make sure i don't order dim ones. also, are they dim-able?
Old Oct 21, 2010 | 08:51 PM
  #214
I ordered the T3-1/4 4 diode. They are the direct replacement for the #194/#168 bulbs. They are bright enough but I want brighter, so im gonna get the 6 diode bulbs. They are NOT dimmable though. Heres a pic, eventhough the camera does not do justice to how cool it looks. The green on the left is the original and the blue is the new.
Old Oct 22, 2010 | 05:02 AM
  #215
irab88's Avatar
oh wow. that looks cool! where is the rheostat set to? (all the way up/down, or somewhere in the middle) and what do you mean by non-dimmable?
Old Oct 22, 2010 | 08:00 AM
  #216
I think its all the way up, but they dont dim. Its either on or off as far as I can tell.
Old Oct 22, 2010 | 08:25 AM
  #217
irab88's Avatar
hmmm... to make it dim, you might need to convert to pwm for dimming. not too hard to do, but not "simple" either
Old Oct 22, 2010 | 09:15 AM
  #218
Im not too worried about the dimmer. I usually dont dim them anyway, just turn it off if anything. But if you do the same swap and convert it I may do the same thing just so that they do dim.
Old Oct 24, 2010 | 08:00 PM
  #219
Small update. I have decided to tear into the engine. I havnt started yet but its coming soon. Before we commence to tear down, the tranny in the old mans Bronco needs a tune up, so we have a DD while my truck is down. I think while Im doing the engine I am gonna do a SAS, sliders and bumpers, and prolly a rear locker but all of that depends on my income. Get ready for some and
Old Oct 28, 2010 | 09:14 PM
  #220
I finished the cluster LEDs. They look killer!
I did a small huntin trip today. Snapped a few pics and then got stuck in a snow drift.
