Z's Confederate Toy's 1987 Pickup Build-Up Thread
#202
this sounds like a fun motor
15B-FTE
The 15B-FTE is a 4.1 L (4104 cc) inline 4 sixteen valve OHV direct injection turbo intercooled diesel engine. Bore is 108 mm and stroke is 112 mm, with a compression ratio of 17.8:1. Output is 153 hp (114 kW) at 3200 rpm with 282 ft·lbf (382 N·m) of torque at 1800 rpm.
15B-FTE
#203
15B-FTE
15B-FTE
#205
I think I have found a diesel to put in the truck: Cummins 4BT!!!!! Itll be sick!! I am chewin ont the idea of doing a Commie Camo on the truck. So it would be red, white, primer grey, and black. And I am also thinkin about changing the cluster lights to either a blue led or a UV blacklight led. Im leanin toward the blacklight but im not sure if itll be bright enough.
#207
#208
I did a few things to the truck today. Got bored of the same ol same ol. Looks like I have some incoming cash ole so I can do some more serious mods.
Took the rear bumper cuz i annhilated it on the last wheelin trip I was out on.
Then I painted the whip springs flat black cuz they were rusting.
#212
Most definitly lol. Its not a hard mod. My set up cost $20 for the ball mount, $20 for the spring, and $20 for the antenna itself. So, $60 per side/
I got the LED bulbs for my dash today. They arent bright enough so I am going to upgrade to 6 or 8 diode bulbs. The blue seems the way to go, the blacklight was too dark although I may try to paint the cluster white to get more glow out of it. I will have some pics up in a little while.
#214
I ordered the T3-1/4 4 diode. They are the direct replacement for the #194/#168 bulbs. They are bright enough but I want brighter, so im gonna get the 6 diode bulbs. They are NOT dimmable though. Heres a pic, eventhough the camera does not do justice to how cool it looks. The green on the left is the original and the blue is the new.
#218
Im not too worried about the dimmer. I usually dont dim them anyway, just turn it off if anything. But if you do the same swap and convert it I may do the same thing just so that they do dim.
#219
Small update. I have decided to tear into the engine. I havnt started yet but its coming soon. Before we commence to tear down, the tranny in the old mans Bronco needs a tune up, so we have a DD while my truck is down. I think while Im doing the engine I am gonna do a SAS, sliders and bumpers, and prolly a rear locker but all of that depends on my income. Get ready for some
