Redeth's 1989 4Runner Resurrection
Old May 7, 2013 | 06:22 PM
  #1441
Redeth005's Avatar
All Pro Leaf Springs
Hey guys! News just keeps getting better and better..... shhhh please don't jinks me. Things have been going way too good for something to go bad. lol
My All Pro Off-road order finally came in today. Took long enough but i finally got it. Apparently All Pro was having some issues with their fabricator or whatever company makes the springs and that is what delayed my shipping.
Front & Rear 4" Lift leaf springs.
One thing i got in the package that i didnt understand was this:
My Receipt states that this piece is a "Spring Pad(Driver's Side)"
Do Any of you know why this piece was included or what for? I know it fits on the bottom side of the leaf spring(the circle piece) but i don't understand why i would only have one.
I dunno. I can just call All-Pro tomorrow and find out for myself but i guess i'm just impatient lol
So that's the update for today guys. We might get to installing the leaf springs this weekend on Saturday. and possibly even getting the sliders installed too. I'm just happy because the truck is finally going to be at the correct height it should have been from the very beginning. And happy that i'll finally be able to use the other pair of 12" travel Walker Evan's shocks! The Rig felt smooth as it sat already so i can only imagine how much better its gonna ride once i remove the cheapie RANCHO shocks and get those in.
Old May 7, 2013 | 06:49 PM
  #1442
kornhuskerwizard's Avatar
I guess i didnt know you had the wrong springs?? U have to switch everything out in the front?
Old May 7, 2013 | 06:56 PM
  #1443
Redeth005's Avatar
It was supposed to be a 4" lift to begin with. At least that's what the previous owner told me but it wasnt. So I bought shocks meant for a 4" lift which are 12" travel for the front and 10" for the rear. But when we finally installed everything we found that i really only had about a 2 or 3" lift. So i was only able to use the shorter(rear) set of shocks and i had to use them in the front. i used my original 8" travel rancho shocks in the rear still.
Check out pages 69-70 on my thread. I show pictures of what i meant. I didnt have to switch anything major out; only the shocks. And that was just temporary till this order came in.
https://www.yotatech.com/forums/f199...6/index70.html
I'm just happy that my problem will now be fixed thanks to these correct leaf springs. YAY! lol
Old May 7, 2013 | 07:00 PM
  #1444
Sounds like you have it goin your way!! Good deal!!
Old May 7, 2013 | 08:00 PM
  #1445
Cyberhorn The Dragon's Avatar
lookin forward to more pictures
Old May 7, 2013 | 09:34 PM
  #1446
rustED's Avatar
Congrats on getting your new springs! The part you are un sure of ( driverside spring pad) is to level out the front so you don't have that lean that is typical with the straight axel Toyotas. If you take a look at the spring perches on your front axel, the passenger side is actually about a 1/4" taller than the driverside. When I did my SAS I made my own spring pad and just welded it on top of the driverside spring perch.
Look forward to seeing more pics of your new improved lift when it's done!
Old May 7, 2013 | 10:56 PM
  #1447
ChefYota4x4's Avatar
Whaaaaat? No text????? Oh hellllllz no! Hahahaha..... jk, and right on! Gonna be sick. ..... shouldn't take but a couple hours, woohooie! ;-)
Old May 8, 2013 | 12:39 AM
  #1448
Terrys87's Avatar
You are getting all kinds of goodies in the mail. I hear you when everything is going right, that you dont want to jink it. It is nice when things do go that way for you. Will be looking forward to more pics when done.
Old May 8, 2013 | 09:00 AM
  #1449
ToyoTech559's Avatar
Like rustedyota said. That pad is for the driver side spring perch. Toyota oem springs are different left to right in the front. Aftermarket companies didnt want to make two different types of springs for left and right so the pad was invented
Old May 8, 2013 | 08:53 PM
  #1450
jred151's Avatar
Congrats man!
Old May 9, 2013 | 05:13 AM
  #1451
Gizler00's Avatar
Good deal on the parts. I think that spring pad is because one of the pads is a little shorter than the other if I remember right.
Old May 9, 2013 | 09:37 PM
  #1452
Redeth005's Avatar
Thanks for the replies guys. Now that I know about the plate now I know how to Install it.
Today was a rainy day. So I worked indoors. I decided to try working on my power windows/mirrors again. I kinda gave up on it a few months ago because I couldn't get any movement out of anything with these damn wires. I always wanted to try to get it figured out but wiring isn't my strongest skill. So I abandoned the project with hopes of eventually comong back to it.
Well today was that day. I getto rigged the wires to be powered off a 12v battery for both power and ground. I hooked everything up as well as I could from memory on the last time I played with this spaghetti soup of wires. After everything was connected. I found that I had been wiring a few thibgs wrong in the previous months I worked on it. I finally got stuff wired right and I managed to get ny mirrors to work perfectly! But as far as the windows went I still couldn't get anything to work. Then I remembered I have 2 extra master relay boxes for the windows that I pulled off of junk yard trucks just in case mine was bad. And luckily for me I did that because I concluded that the original is toast. It doesn't work at all. Once I swapped the relay box I was able to move both the power windows down (only down. Not up) by using the main driver control buttons. And then the passenger side would work both up and down when I'd use the passenger button.
Once figuring the mirrors semi figuring out the window switches I moved on and tried working with a group of loose wires that I couldn't get to work correctly. Its a pair of wires. Both solid black with red dots only one has a white line through it. Both sets of those same colora run from the power windows. And one wire alone solid black red dotted runs to the relay making it 5 wires total. This Is the bunch that I can not figure out.
I know this sounds like a bunch of jibberish when reading so I made a video to better explain myself.
Video is already uploaded. It's just in the processing stage... ill upload as soon as its done.
Old May 9, 2013 | 09:45 PM
  #1453
sounds like the drivers side control isnt making a connection the passenger side is as for the mirror wires no clue id have to be looking at it to help more redeth
Old May 9, 2013 | 10:03 PM
  #1454
Redeth005's Avatar
Here we go. Video uploaded
I'm apolgizing ahead of time. The living room carpet that I'm working on isn't the best work floor to be on when you have multiple colored wires on it trying to explain stuff. It blends in a lot lol.
Old May 9, 2013 | 10:45 PM
  #1455
no worries try havin 2 kids 7 cats an 2 dogs 1 bird in the house talk to me about mess an terrible carpet LOL
is the control for the mirror illuminated? that could be the extra wire at the mirror switch
also looking at the schematic for the 88 the L-W wire and L-Y work the down FROM the master switch the L-R wire feeds power to the passenger switch which is working it by passes the main switch SO trace the down wires from the drivers motor it should go to the down side of the switch
the pass side the wires go to the pass switch then to the master switch the schematic doesn't show any diodes inline
Old May 9, 2013 | 11:52 PM
  #1456
Co_94_PU's Avatar
Well you managed the impossible and got me to fuss with my tempermental computer to get at the toyota books
I can't make out the plug/object when you asked about diodes. But the are only two diodes in the system, one for each of the door "courtesy" switches. No reason for those to be connected in your "test rig" at this point, they are both on pin 9 of the control relay..
I'd start with testing the master switch to make sure it's conducting in the up position. You would/should have conductivity for..
Drivers side UP: power from pin 1 to pin 10, and ground from pin 4 to pin 5.
Passenger side UP: power from pin 1 to pin 9, and ground from pin 4 to 6.
Next is the other sides switch. I'm pretty sure this side is fine from it working up and down already. With the switch centered you should have connections on 1-2 and 3-4. In the up position you get power from pin 5 to 1, and down you get 5 to 4.
For the questionable wires *shrug* need to know where they start at. white black is almost always direct to ground.
Some if not all of these switches are illuminated. "Power window lock s/w" ties into the "Rear power window s/w", these are G-L and R-B on the "H1" harness plug, and a blue 4 pin plug somewhere between the harness and master switch pin 1 power pin 3 ground thru the dimmer control(rheostat).
Essentially since it rolls down it's hooked up right. Which just leaves a broken or dirty master switch. Which unless something broke likely just needs cleaned if you can get it apart
Old May 10, 2013 | 12:05 AM
  #1457
Co_94_PU's Avatar
EDIT/PS:
You mentioned you ran direct power from the battery to the master switch in the video around 5:44. This is wired wrong.
Power is supplied from the control relay on pin 12, this splices to the master switch pin 1 and the passenger switch pin 5.
You might need to alter the wireing you have hooked up on the control relay to get the power out on pin 12(L-R) you need power input to pin 8(B-Y, IGN fuse) and ground on pin 10(W-B), also power input to pin 5(W-R, Power wnd CB). This energizes the relay and flows power from pin 5 to pin 12.
Sounds like you've essentially by-passed the relay, which isn't really a problem as long as you get the power to the switchs from the circuit breaker..
The purpose of the control relay is to allow you to roll up the windows after the ignition has been switched off for one minute or untill you open a door.
Also small note the pin numbers in the above schematic are listed as the "Turbo SR5" ones in the EWD I've linked before which is of course a handy book for identifing plugs and pinouts. Link is in Dakota's thread or someone else might have the link, pretty sure it's in chef's also.
Old May 10, 2013 | 06:11 AM
  #1458
Grego92's Avatar
Thank God you came back to those window switches! I thought you abandoned the project, and after all that time and work getting the system out in the RAIN, would've been a complete waste of time.
Glad you almost got it working at this point....the finish line is just a few more steps away.
Old May 10, 2013 | 08:53 AM
  #1459
Richard, just put the doohickey together with the thingy and the thing a ma Bob and that should do the trick! I hope this was helpful... Hahahahaha... just kidding, I just thought I would bring some levity really quick as I know that this wiring realm can cause some of our eyes to pop out of our head! Lol ... Really excited for you man!
Old May 10, 2013 | 10:37 AM
  #1460
Redeth005's Avatar
Holy cow that's a lot of cats! As for illuminating.... i am not sure. I think it is meant to illuminate but ive enever had power mirrors so idk if it sjould or should not. As far as i know Its just buttons n stuff. The loose wires aren't going to the power mirrors though. Well acutally I don't know for sure lol but those black wires are on both the driver and passenger sides. I'm sure if it was meant to illuminate the button then it would only be 2 wires instead of 5 and only on the driver side where the control switch would be right?
Thanks for the schematic. Looks like the one I've got in rhe haynes manual and the one that RadRunner gave me from his FSM. I gotta re familiarize myself with the color code of the wires again. I pretty nuch have planned to do what you said. That's how I got my mirrors to work in the first place amd also the down switch. I'm gonna need to reopen my main driver side control buttons. To see if I missed something in the cleaning process last tome I worked on it.
Umm.... you're welcome... For getting your mind going? Lol
I'm gonna try to check that master control switch some time today. I think thevlast time I checked something wasn't making the right contactm gonna have to pull out the multimeter again lol
EDIT/PS:
You might need to alter the wiring you have hooked up on the control relay to get the power out on pin 12(L-R) you need power input to pin 8(B-Y, IGN fuse) and ground on pin 10(W-B), also power input to pin 5(W-R, Power wnd CB). This energizes the relay and flows power from pin 5 to pin 12.
I am not running the switches directly to the power. I have the battery connected to the wires that start at the 2 breakers and then branch out to all the smaller wires. Dang dude I seriously wish I would have brought my wires to work today. I hace absolutley nothing to do what a boring day. I would have loved to spend the whole day checking the pins and switches. I might not have time to work on it today but I will try to get on it sometime this weekend. Might be installing the new leafs so dunno how long that will take us to do.
As for the schematic I have the one that Ray gave me on the computer.
Grego I never abandoned the job. I'd never let that money I spent on this stuff go to waste lol. I just took an extra long break. And what made it longer was when I was prepping everything for sas and then the actual sas. So that's what held me back some. But i most definitely never planned to abandon this lol and you're right its just a few steps away from being done.
Lol that cracked me up. Thabks for the laugh. Its been a slow day at work today so I needed it. And yes loads of wires make me feel helpless too lol
