magnet18 1986 build thread
Old Aug 11, 2019 | 01:47 PM
  #321
magnet18's Avatar
Finally did new brake shoes and springs this weekend, cheap quick and easy! I ended up with an extra spring.hardware kit if anyone wants it, ordered 2 when I only needed 1
Also swapped in a new MOOG SSD89 steering stabilizer, "used" on amazon so I got it for $9.97 (new, just damaged packaging)
Did the first oil change and got the break in oil out, took a sample to send to blackstone
On a side note, I need to paint my chassis :/
Old Aug 11, 2019 | 02:37 PM
  #322
magnet18's Avatar
Leaks:
1. Lost a band on the half axle, looks like that's allowing stuff to leak out. Not sure if I can just replace the band or if I should replace the whole half axle
2. Tranny was wet :/ will have to keep an eye on it. Could be one of the seals I replaced.
3. Might have a bit of leaking from the front oil pan bolts, or could be weeping from a different bolt or seal. (note the oil on the pulley is just from me spilling during the oil change)
4. PS pump looks to be leaking, added to the to-do list
Old Aug 15, 2019 | 08:11 AM
  #323
magnet18's Avatar
Update after driving a few days, that stabilizer makes a huge difference
I have a bulkier idler arm I plan to put on soon as well, there is a tiny amount of vibration in the wheel and I wonder if that'll help
Old Aug 28, 2019 | 07:59 AM
  #324
magnet18's Avatar
Got the oil report from Blackstone labs for the first oil change, so far so good!
Old Aug 28, 2019 | 11:07 AM
  #325
old87yota's Avatar
Nice!
Looking good!
Old Aug 28, 2019 | 07:09 PM
  #326
Melrose 4r's Avatar
5 Year Member
Very cool to see that report.
Old Mar 14, 2020 | 06:05 PM
  #327
magnet18's Avatar
Pleased to say the engine has been running great, didn't drive during the winter, started driving this spring and (now that I have a shop I'm parking in!) I'm seeing I've got a rear main issue of some sort to address
So I got a transmission jack! Guess I'll have to pull it and figure out what's up. Sleeved and replaced the seal, guess I'll find out what I botched
Old Mar 15, 2020 | 04:17 AM
  #328
coryc85's Avatar
Are you sure it is not gear oil? Either way you gotta drop that tranny. I had a significant leak there that turned out to be tranny input seal.
Old Mar 15, 2020 | 05:40 AM
  #329
magnet18's Avatar
Yea, tranny fluid was still pretty new and red in color, this is definitely oil
I replaced both engine output and tranny input seals, so either way I botched something
Old May 15, 2020 | 06:59 PM
  #330
magnet18's Avatar
Finally, an update! Been stupid busy since all these lockdowns began
Weather got nice so I finally started working on the truck again. First up is the revving at stoplights, need to adjust the TPS position as I learned during my rebuild.
Well I popped the hood and low and behold I'm missing two valve cover acorn nuts! Also some oil in the throttle body. Thoughts on if those are related? Or if it's just from excessive blowby during break-in?
Anyway, proceeded to clean up and adjust the throttle body. Put her back together and she runs good as ever. I'll take her for a test drive tomorrow and verify that fixed the issue
Old May 15, 2020 | 07:00 PM
  #331
magnet18's Avatar
Valve cover
Old May 15, 2020 | 07:06 PM
  #332
magnet18's Avatar
Planning on taking the truck for a 3 week road trip out west in July!
Preliminary list of things to do before then-
Rebuild ps pump
Fix oil leak
Ilder and pitman arms
Brake master cylinder+ service fronts
Fix electrical issue where high beams cut out randomly
get spare tire
Bonus- install cruise control
Outfit back for camping
Old May 18, 2020 | 07:59 AM
  #333
magnet18's Avatar
Put the Throttle body back together, ran around in the truck for a couple days, have confirmed that the engine revving at stoplights is finally fixed!!
Old May 18, 2020 | 06:35 PM
  #334
magnet18's Avatar
Ordered oem Toyota power steering pump rebuild kit for $45 shipped
Part no 04446-20031 - NOTE FROM THE FUTURE, WRONG KIT
And, cautiously optimistic that my 'rear main' issue is fixed. Looks like it might've just been leaking from the valve cover!
Old Jun 5, 2020 | 04:13 AM
  #335
magnet18's Avatar
Ordered a driveshaft parking brake kit!
https://allprooffroad.com/ap-feature...1a-t-case.html
now, to figure out what I need to do to get good brake performance before heading into the mountains
Old Jun 23, 2020 | 05:53 PM
  #336
magnet18's Avatar
Nothing like a deadline, eh. Trying to get a bunch of stuff knocked off the list before the July trip.
Rebuilt the power steering pump following this thread (and the FSM) https://www.yotatech.com/forums/f116...g-pump-250677/
The kit part number is 349030
Disassembled the combination switch and (hopefully) fixed the high beam issue following the 4crawler writeup
https://www.4crawler.com/4x4/CheapTr...eadlight_Combo
Also replaced the horn contact, thereby fixing the horn (part number 84312-20011)
On the way are:
- ball joints, tie rods, pitman arm, (already have an idler arm) and linkages for a full steering rebuild
- all 3 brake drop hoses
- Dorman C93740 parking brake cable. Hopefully it fits. That will be the last thing I need to wrap up my Trail Gear All-Pro T-case driveline parking brake
Still to do, the plain old oil change, a spare wheel and tire
Maybe to do - hunt down the rattle from my cabin air blower fan, install some good speakers (which I already have), and we'll see what the weather is like... may decide to stop by an AC shop on the way out of town and cut a check to get the system switched over to the new stuff.
Old Jun 23, 2020 | 05:56 PM
  #337
magnet18's Avatar
A side note - ryobi 18V electric impact wrench... amazing, I don't think I'll ever have a reason to buy an air powered one
Old Jun 23, 2020 | 05:59 PM
  #338
magnet18's Avatar
Another aside - just discovered this, didn't know they were doing these writeups, kinda cool
https://www.yotatech.com/articles/yo...4runner-build/
Old Jun 25, 2020 | 05:19 PM
  #339
magnet18's Avatar
Got the tie rods swapped... Not without breaking 3 different tools
(Harbor freight wasn't exactly up to the task)
Old Jun 25, 2020 | 08:09 PM
  #340
RAD4Runner's Avatar
LOL And you never knew they were talking about you?
