magnet18 1986 build thread
Old Apr 6, 2019 | 04:46 PM
  #281
magnet18's Avatar
Old Apr 6, 2019 | 04:47 PM
  #282
magnet18's Avatar
Old Apr 6, 2019 | 11:38 PM
  #283
old87yota's Avatar
Looks good!
Old Apr 7, 2019 | 12:56 PM
  #284
magnet18's Avatar
Thanks!
It's in!... Almost anyway, the only thing I can't figure out is where the squarer part on the double connector goes... Is it an EGR connection?
(Also I didn't photograph the ground connections, dumb me)
Old Apr 7, 2019 | 04:45 PM
  #285
Melrose 4r's Avatar
5 Year Member
Could the square one be your cold start injector connection?
Old Apr 8, 2019 | 03:55 AM
  #286
magnet18's Avatar
P
Nope, CSI is already hooked up. I was up down and around everything from every angle I could with a flashlight, couldn't find it's mate
The square on it's own, and the circle on it's own both found their home, the circle in the double connector went to the transmission, just can't figure out the square part of the double.
The good news, it cranks!
I left the plugs out and tried cranking for about 30 seconds in two bursts of 15, the oil pressure light didn't go out though. That felt like a long time, how long would you expect it to take?
Old Apr 26, 2019 | 02:47 PM
  #287
magnet18's Avatar
Cranked it till the oil pressure light went away
Old Apr 26, 2019 | 05:43 PM
  #288
Melrose 4r's Avatar
5 Year Member
Okay! What’s keft?
Old Apr 26, 2019 | 06:12 PM
  #289
magnet18's Avatar
Originally Posted by Melrose 4r
Okay! What’s keft?
Installed the radiator, filled it, triple checked everything, and it fired right up!!
No check engine lights, purrs like a kitten!!
Tomorrow I need to set timing and do the valves while hot
... Anything I'm forgetting?
Old Apr 26, 2019 | 08:34 PM
  #290
old87yota's Avatar
Yay!
Old Apr 27, 2019 | 04:14 AM
  #291
magnet18's Avatar
So my list for today is from the LCE suggestions
1. 4crawlers TPS check
2. Run it for 15 minutes at 1500-2000 rpm to break in the cam
3. Set the timing
Then do I need to adjust the valves? Or is that like a first oil change type thing after they're broken in? LCE doesn't mention it in their start up and break in page. I did the cold settings while building, if I can skip doing the hot adjustment today I'm all for that
Old Apr 27, 2019 | 03:41 PM
  #292
magnet18's Avatar
It ruuuuuuns
TPS could use adjustment as it switches to idle very, very close to the hard stop, but it'll have to wait till I replace the thermostat as I can't get to the screws as is
Broke in the cam
Set the timing
Took it around the block and all is good!!
The only issue is the throttle now doesn't want to return to closed, maybe new spring, maybe new bushings?
Old Apr 27, 2019 | 05:23 PM
  #293
Melrose 4r's Avatar
5 Year Member
Dashpot adjusted correctly?
Old Apr 27, 2019 | 09:15 PM
  #294
magnet18's Avatar
Think so, will look up the procedure for that
When off it returns all the way to closed, when running I have to push it back by hand or it sticks partially open
Picture time!
Old Apr 28, 2019 | 12:21 PM
  #295
magnet18's Avatar
Rest of the pics I meant to post last night
Old Apr 28, 2019 | 04:08 PM
  #296
Melrose 4r's Avatar
5 Year Member
Ive got that same wacky heater hose clamp setup. Must be factory.
Is the screwdriver only temporary?
(just kidding)
Old Apr 28, 2019 | 05:14 PM
  #297
magnet18's Avatar
(just kidding)
Lol, yes, I replaced it with bolt and nut that are the same size as the screwdriver... those may or may not be temporary
I need to order a few different bolts, I must've lost a plastic baggie somewhere
Pic 1, the wacky hose clamp is my only leak (it's very slow). Tightening it isn't helping I'll figure it out sometime.
Pic 2, (ignoring the screwdriver)
1. it kinda smells like gas down there, but I don't see any leaks
2. Where does the fuel line bracket thing go? I can't see it going anywhere reasonable, unless I bent it badly during removal/install
Pic 3, I replaced that spring with a stronger one which helped a lot, drive-able now. LCE has a bushing (shaft seal) kit here
https://www.lceperformance.com/22RE-...-p/1061048.htm
but I don't need the set screw, I'll shop around to see if I can get just the bushings cheaper somewhere but I didn't see them in a quick search
I also need to:
clean the grounds (I was lazy at best doing them this time)
get a new windshield fluid bottle and motor
get new battery terminals
rebuild the steering
etc...
Old Apr 29, 2019 | 08:07 AM
  #298
magnet18's Avatar
Other than the nits I need to pick in the post above, I'm very happy. Put about 50 miles on it and while it's still a dog, it always was and always will be, it's much better than before + the rings aren't yet seated.
And I'm now reminded how bad the steering was
Steering/front end will get a rebuild now, then I'll hook it up for towing.
For a steering overhaul, most people seem to recommend just replacing everything as parts are cheap and they all have 200k on them
Steering damper
4 Ball joints
Inner tie rod ends
Outer tie rod ends
Pitman arm
Idler arm
Relay rod
QUESTION;
Do I need new knuckle arms?
Are the control arm bushings recommended as well? (Are they a PITA?)
What about axle half shafts?
Any other parts known for wearing out that I should do?
Old Apr 29, 2019 | 08:16 AM
  #299
Melrose 4r's Avatar
5 Year Member
I did 4ball joints, 4 tierod ends, checked the damper, replaced the idler arm and swapped the steering box, got it aligned, adjusted the backlash on the box multiple times and I'm still not happy with it. I was blowing around on the highway today on the drive to work. I plan to investigate further and actually rebuild the box.
My dad had a brand new 1986 SR5 extra cab 4x4 in '86 and I remember driving it vividly. The steering felt great. That's what I'm trying to duplicate.
Do you plan to rebuild your steering box? Have you done one before?
Old Apr 29, 2019 | 08:36 AM
  #300
magnet18's Avatar
Drats, I was hoping to leave the steering box alone since the backlash was within spec
I haven't done anything with steering boxes before
I assume you replaced with a rebuilt unit?
Also, was the SR5 you remember totally stock, and are you stock now?
I'm pretty sure the lifting and big wheels puts these steering systems through more hell than people realize.
I toy with the idea of removing the body lift and going back to stock tires... But the tires are brand new... And it does look *really* good
