irab88's 1993 PickUp Build-Up Thread
Old May 31, 2013 | 11:10 AM
  #2301
RBX's Avatar
RBX
I would say downtime will be almost the same, price...is another story.
And let me just qualify what I am about to write with the fact that i have never done an SAS before, infact untill a few months ago, I have never even touch a SFA. I'm just telling you what I know so far.
The IFS frame clean-up is a time killer, no matter what you choose.
I have 6 brackets to weld to my frame: panhard/bumpstop, shock towers & lower link frame brackets. Leaf setup needs are similar: bumpstops, front leaf hanger, rear leaf shackle mounts and shock towers.
The advantage leaves have over links in downtime would be that fact you can get the axle with perches already installed, where-as, links need brackets installed (3 in my case).
I'm not trying to say that my junk is better, I'm just giving my rationale for spending the extra $$. Either one is a good amount of work.
BTW, I actually bought my kit from a guy that was getting a divorce and needed to sell the kit that was never installed, that was dumb luck at almost 1/2 the original price.
Old May 31, 2013 | 12:24 PM
  #2302
irab88's Avatar
damn, good find!
good points, as well. i just think the "cheaper" route is a little better for me right now. though when the time comes to move up to links, i'll be picking your brain a bit
and i came across these. i might put them all around to give me a lower stance:
not too bad on price, and it'd keep my front end down by a good 3 inches
http://www.liquidironindustries.com/...e=0&featured=Y
Old May 31, 2013 | 12:40 PM
  #2303
RBX's Avatar
RBX
Seen those before,pretty cool. They safe for street use? Lateral force on the nylon slider...
I thought the reason for lift on a leaf setup was arch so the histeer will clear?
Old May 31, 2013 | 04:36 PM
  #2304
irab88's Avatar
i'll make the steering work, even if i hafta notch the frame a wee bit. and i'm sure they're fine for on-street use. i mean, leaf bushings take a good beating, and they hold up fine, so i don't think there'll be any issue. i can throw a fender washer on if need-be.
here's the thread i was looking at earlier:
http://www.pirate4x4.com/forum/gener...kle-boxes.html
Old May 31, 2013 | 05:12 PM
  #2305
RBX's Avatar
RBX
You bring up a good point about the bushings, but bushings absorb vibrations. I'm just thinkin out loud since I have no FHE. I'll check the link thx
Old Jun 15, 2013 | 11:13 PM
  #2306
CAdot's Avatar
Old Jun 16, 2013 | 05:53 AM
  #2307
irab88's Avatar
about the same. i'm getting ~18-22 mpg (city-highway)
Old Jun 16, 2013 | 10:22 AM
  #2308
ChefYota4x4's Avatar
Gotta hit u up on something: Cant remember, sorry... but did u go Marlin for ur dual case set up? I'm sitting on 2 cases, including my current.... trying to decide on either single 4.7 box or 4.7/2.8 combo.... I might be ok with just the one for a bit... but dont wanna toss cabbage in the disposal by later needing stuff I could have saved doing it all in the firsr place, should I later want to go with dual. Hmmmm. Lol.
I just wanna do as much as possible while I'm at the SAS.....but now have a leaky gear box added to the cabbage harvest overhead cost percentage! Hehe
Old Jun 16, 2013 | 11:56 AM
  #2309
irab88's Avatar
i didn't actually set it up, but i can give you the run-down. it's got 2.28/4.70 with a marlin adapter. one of the cases is an advanced adapter housing. i haven't driven off-road with the new setup, but so far i like having the option for low, double low, or 8x low (roughly). a 2.28/2.28 could work well, 4.70/4.70 is waaaaay too low, and a single 2.28 was too high for me sometimes. if you're worried about tunnel modifications, talk with rory from radesigns. he should be able to help you move all the levers forward (like mine)
hope that helps!
Old Jun 16, 2013 | 03:00 PM
  #2310
Red Wagon's Avatar
What page is the photos of your interior levers? I'm interested in seeing that.
Old Jun 16, 2013 | 03:40 PM
  #2311
Redeth005's Avatar
Is doing dual cases the same exact thing on a truck with the 22re and the 3vze? I'm good with what I have now. But I'm interested in reading up on that mod as well due to there being so many 2nd gen 4Runners out hrre in our junk yards with the 3vze.
If it's something that'll be cheap then maybe I won't mind getting something like that further down the road.
Old Jun 16, 2013 | 03:45 PM
  #2312
Red Wagon's Avatar
The 3VZE has a chain driven T-case. Not sure if you can pair them?
Old Jun 16, 2013 | 03:47 PM
  #2313
Redeth005's Avatar
Aww... darn you 22re guys with your awesone mods. :cry:
Old Jun 16, 2013 | 03:52 PM
  #2314
Red Wagon's Avatar
Find a gear driven one and swap it in.
I have one just waiting to get done on the new build. Find a 22RE parts rig.
Old Jun 16, 2013 | 04:02 PM
  #2315
irab88's Avatar
it all starts here:
https://www.yotatech.com/forums/f199...l#post51941082
and inside, so far
Old Jun 16, 2013 | 08:04 PM
  #2316
Red Wagon's Avatar
Wow, looks confusing.
I want!
Old Jun 16, 2013 | 09:17 PM
  #2317
hope that helps!
Helps much, thanx! I have two 2.8'ers right now.... I need to figure out if I just want to go for the 4.7 now and stack it up against the 2.8 I just got. I definitely have some bearing noise in my tranny now, hoping its not also in the transfer case... It never has let me down and seems to ride really nice off road, never really having much of a problem keeping up... But man, I don't think I've ever heard one bad thing about dual cases from someone that has them. I suppose I could just get the adapter and slap these two together... Then I suppose I would definitely have to think of the shifter aspect, under and in the cab. I saw one guy that modified his standard bezel for twin sticks... It was a really sweet setup but I can't find the dang thread anymore! Grrrr! Lol.
I can't wait for some action shots! love the shots of your camper as well... Always look forward to those
Old Jun 16, 2013 | 09:19 PM
  #2318
Btw, that pic/set up is SICK! LOVE how you kept the plastic bezel!
Old Jun 20, 2013 | 07:24 AM
  #2319
bbrideau's Avatar
I need to stop reading yours and chefs build threads, I'm going to be broke! Trucks looking good
Old Jun 20, 2013 | 08:09 AM
  #2320
irab88's Avatar
i haven't even taken the ifs off yet... this thread is gonna get a lot more expensive sometime in the next year
