the dragons 88 runner buildup/rebuild
Old Sep 8, 2012 | 02:18 PM
  #161
Cyberhorn The Dragon's Avatar
***quiz time!*** i hope all you mechanically inclined an reclined types out there have been paying attention!!
what happens when a door latch internally fails and the electrical lock fails as well? you cant get the door open an working on the latch requires the door open what do you do?
looks at clock hmming to myself watching for any use of google on smart phones
please pens pencils down the answer is you sit on yer tush an half to quarter of an inch of travel on a hacksaw blade you cut the U bolt off to open the door. case in point my friends 93 dodge intrepid rear door removed to get access to the passenger front door jam
this is what ive done today.... my fingers hurt now..
Old Sep 9, 2012 | 03:46 AM
  #162
Terrys87's Avatar
Looks like you have been busy. You were lucky that you were even able to get at the door latch and it wasnt behind some metal that a formed over it blocking access to get to it. That would be a work out and about the only I would know of gettting to it.
Old Sep 9, 2012 | 09:42 AM
  #163
yup it was still around a corner got 2 hacksaw blades with a curve to them now. but it feels SO good to do something someone else thinks is impossible kris was going on "my car door is forever broken!!" cussing an cursing i told him patience just give me a bit
Old Sep 9, 2012 | 11:14 PM
  #164
well got a pair of black magic coils coming for the rear end, used but still in great shape great price too thank you Utah4Runner86
will have to fab up a retainer as PO removed the bump stops but thats not a major issue
also pulled the center cross member for derusting its not too bad just the ends where they were up inside the frame mounts (its gona get sanded an painted no need for the tank) the bolts though rusty as all heck
cleaned the Diff aluminum cover an prepped the pumpkin for paint then went after the passenger side frame an engine mount got called inside though guest arrived so more tomorrow, cleaned an started painting the condenser coils the end brackets rusty an not possible for me to disassemble to cook clean. sprayed rubberized undercoat in the passenger fenderwell an half of the drivers side over the repairs now well sealed with primer seam sealer an paint also fiberglassed the 3inch long half an inch wide hole in the well near the drivers left foot
cooking in the tank is the fan blade the metal ring that mounts to the fan clutch is rusty so it gets the cooking also cooking a bracket for the AIS muffler an the spare tire hanger the spare is currently being held up by a bolt an a bracket from a wall mount meant for a flat screen tv... sigh...
found treasures in the side compartments a set of brake pad pins an M clips new in bags also a ratcheting cargo strap and the spare tire hanger some sun glasses (daughter will like those) and some clear fuel line for something likely a mower or chain saw
Old Sep 10, 2012 | 11:45 PM
  #165
Terrys87's Avatar
Not sure why they removed the bump stops, but looks like you are getting alot cleaned up. I got most of my cooker things that I need. I am going to get a different battery charger to use for a power supply as the one I have now has a lot of safety devices on it and cant use it.
Old Sep 11, 2012 | 09:39 AM
  #166
Hey terry!
well you can hook a battery up to the part an the charger to that ive seen that work as well
i suspect they pulled the bump stops to get any kind of travel out of it but thats okay its fixable
ANNND new fender arrived got the cup holder yesterday cupholder is very well made! nice thick ABS plasticspring loaded adjusters to fit cups in place snugly (finger is bending one)
the mounting flange on the fender is a bit bent but its fixable the important part, the side, is smooth an unblemished!
Old Sep 11, 2012 | 09:49 AM
  #167
finger is on the repair i had to make in the drivers fender well with duraglass
did a tiny bit of reassembly last night
Old Sep 11, 2012 | 08:02 PM
  #168
well found out my block had to be heli-coiled the threads were just too messed up in that one hole good news it didnt need to be decked so only charged me 50 for the coil an boil applied a black primer to it just to keep her from rusting
got a used junk yard steering box for 65 a bargain! no leaks it gets sand blasted an paint next (gotta pull the pitman arm off mines in great shape so got a spare)
the fender fits took some massaging, the mounting flange had to be fixed first then flattened in places (front end an back near the firewall) to mirror the other side an mount flat the drip edge is bigger along the inner fender by over a 1/4 inch it had to be hammered down a bit to sit right one bolt hole i have to open up a bit as its not quite aligned
then had to put a file through the square insert holes for the side marker i expected this it is a taiwan copy but did finally get a good reveal an depth after adjusting things around
then we had to use a disk cutter on the door edge as it wasnt straight along the door gap like the passenger side the metal was just bigger at the point an thus catching on the fender ill have to smooth the cut round it with a file rub a bit of duraglass along the edge prime&paint
Old Sep 11, 2012 | 11:32 PM
  #169
ChefYota4x4's Avatar
Wow, fender looks great.. You'll suss up the imperfections, no doubt! Great find on the box... I think Redeth, on that day we pulled that one, paid 45$ .... It's a steering box-good deal week for Yotetch Brethren! lol.
I dug a bit into 'engine bay lamps'.... just can't seem to find the one I have, that one in my video? Would like to get a cover for it and paint it up/call it a day/slap it in... But I'll have to settle for painting it up and slapping it in without a cover for a bit, I suppose, lol. BUT, I'm starting to think I'd like to have some on the hood itself, ya know? Lighting up the whole engine bay when I open the hood? Meh, can't make up my mind.... But at least I have this one for now, lol
GREAT WORK, man! Can't wait for more!
Old Sep 12, 2012 | 12:37 AM
  #170
Terrys87's Avatar
Having your motor out is going to make getting your gear box in easyyy. It isnt bad with a motor. You are making some great progress on the bodywork and fenders. Starting to look like a 4Runner. Once you get the motor back, you will have this thing in a whole lot better shape then when you got it. Great job.
Old Sep 12, 2012 | 10:12 AM
  #171
i couldnt pass it up kris was at the junk yard getting another electric lock for his intrepid which the drivers side was acting up when the passenger side failed he asked the guy at the counter if he had any newer T100 he had JUST got in a 93 which is where that steering box came from cut kris a deal since the electric lock he'd bought failed
Old Sep 12, 2012 | 10:31 AM
  #172
LOL well a bedframe maytag washer 4runner LOL
block is back (i need to wipe her insides with oil) but have to wait for the head till next month i have to get the re ring kit to get the valve stem seals he disassembles the head an reassembles after tanking an such all for the same price so might as well let him install the seals
the steering box will be going back in after painting i need to finish the derusting of the frame an suspension get kris to do the welding
still waiting on the sr5 cluster coming from alaska, upgraded master cylinder should be here today springs are on the way
Old Sep 12, 2012 | 10:43 AM
  #173
Hey CHD in the place to BE! lol.....
I got my stuff's from AZEK$%#+! a while ago. Maybe it got held up in transit? My box is 12x14x16 or so.... Can't imagine yours would be much bigger...... He sent me a confirmation number and what not, and 3 days later, on my doorstep. He shipped it within 48 Hours of speaking to him(we spoke that night til around 12:30am).....
Maybe you have a postal carrier issue?
Old Sep 12, 2012 | 01:14 PM
  #174
gawd i hope not its hard enough to get sr5 gauges
i did get my springs for the rear just came in the mail via a it fits it ships box thanks Utah4Runner86
Old Sep 12, 2012 | 01:18 PM
  #175
Springs? as in leaf pack mod? Whatchutalkinbout Willis?
Old Sep 12, 2012 | 01:25 PM
  #176
Zuk mod springs Chef you been sniffing to much sage? oh dont tell me youve been hitting the cloves! LOL
sent your video link to kris my room mate so he can see what were gona have to do
Old Sep 12, 2012 | 01:28 PM
  #177
OHhhh, sorry man... Ok, yeah.
So, ..... you're doing a "no cut" spring? Or the way I did it?
Old Sep 12, 2012 | 01:30 PM
  #178
Wait, .... hush-hush.... You got some cloves homie? hahahahaha.
Nope, not a puff or even drink, actually, in 8 years. Still serve plenty o drinks... just no drinky myself, lol.
Old Sep 12, 2012 | 01:31 PM
  #179
oh im cutting just have to figure out how to keep um in as the PO removed the bump stops
Old Sep 12, 2012 | 01:33 PM
  #180
i had a single beer oh 2 weeks ago? just not a drinker any more ice tea an coke zero any more
