the dragons 88 runner buildup/rebuild
Old Jul 21, 2014 | 11:08 PM
  #1041
Cyberhorn The Dragon's Avatar
an boy did they come in the pulley an its mounting bolt nut an spacers still had the slow pack mule hair from florida i know it was from there as it was funky colors an smelled of sea salt
and my score of the year a NOS 1988 K&N airfilter fit like a glove! for 18 bucks still in original box faded an bit scuffed
SO with pulley in hand we set to work on the AC system had a leak in the low side line from compressor to firewall gona hve to replace it eventually not sure what pin head CUT it in half an put on hose clamps...
got that handed got the system purged oil filled added freon an kept adding freon (134) whistling waiting for the ac clutch to click when it had enough pressure to trip..but no...we finally had to rev the engine up over 1k rpm an then it started to work got the prescribed Oz of freon in
double checking fuses (i didnt remember ac an heat were accessible via the removal of the glove box
showing my fog light switch i didnt like the feel of reaching for it on the right side so left behind the headlights it went
an finally grill back on grill guard decided to be difficult had to bend the leg a bit ...okOK i adjusted the bumper with the slide hammer as things settled it got tight an then i had to grind a bit off the guard that sat on the bumper bolts an finally wrestled it into place
ugh! but looks awesome
Old Jul 21, 2014 | 11:22 PM
  #1042
ok question for those who know the black VSV is related to the ac idle up which isnt doing it it shares fittings on the valve with the power steering idle up
we messed round with the hoses making sure we didnt have um reversed or something but nothing hear air hissing from the vsv when lines were reversed intentionally
anyone good with ac? right now it cools long as the engine rpm's stay up over 1k if it idles which mine does at 8-900 the clutch kicks out an no ac like sitting at a stop light
Old Jul 21, 2014 | 11:31 PM
  #1043
some night shots to also show the brightness of the halogen headlights on their new relay activated harness an the LED fogs/floods
Low beam
LOW & LED fogs
High beam
Old Jul 23, 2014 | 12:26 PM
  #1044
dont do much for performance but does give the truck added good looks
LOL
Old Jul 24, 2014 | 06:44 PM
  #1045
jason in tn's Avatar
Very cool buddy.
Old Jul 25, 2014 | 01:15 AM
  #1046
Terrys87's Avatar
Just talked to you on the phone, but looking at your truck and from where it was to what it is now, it is looking great. What a tansformation it has gone thru.
Old Jul 26, 2014 | 03:25 PM
  #1047
so my shift boot has seen better days in its life the flaking an ugly so i found A.O. enterprises they had auctions on ebay for other shift boots an found they had the paired ones for our dual sticks i was WOOT and they do gray black red plether
http://www.ebay.com/usr/aoenterprise...84.m1497.l2754
my console has the 11.5" boot length which on their auction you just tell them an they will ship the larger size came all inside a padded envelope so put it out in the sun to warm an relax the material
the edge has an elastic cord to help but id recommend thread an a needle and or glue to hold it to the metal frame you must recover from your old boot so here we go
old boot um...yeah seen better days
old boot removed from metal frame easy cut the old threads an remove (i cleaned mine up with a bit of scotch brite to make the glue hold better)
all warmed an relaxed started installation an gluing clamps ahhh the clamps!!
ooh lookin good already
glue all set off to install in my plastic console
an there it is all installed easy stuff but makes it look a LOT better
sorry bit blurry at the knobs
they also do the center console arm rests but they dont have a pattern for the 1st gen 4runner well been talking a bit with them will be sending mine which is all ripped an not even the right color to them to make a new one
Old Jul 27, 2014 | 04:10 PM
  #1048
Nervo19's Avatar
Big improvement! Your old one looked like it had a skin disease! I just got a leather console cover from topgaiters on eBay. They have the pattern for 84-89 4Runners and newer 4Runners and trucks. I pm'd them and they made me a gray leather one that matches the boot I got about 3 years ago. It fits like a glove and arrived in less than a week.
http://www.ebay.com/itm/FITS-TOYOTA-4-RUNNER-PICK-UPS-HILUX-ARMREST-COVER-1984-1988-/231159942657?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item35d234ce01
Old Jul 27, 2014 | 07:05 PM
  #1049
Fits Toyota 4 Runner Pick UPS Hilux Armrest Cover 1984 1988 | eBay
nervo could they provide the foam as well? mines all decayed
Old Jul 28, 2014 | 01:12 AM
  #1050
Terrys87's Avatar
Every factory original boot cover I have seen has been in bad shape. Some do look scary.
Old Jul 28, 2014 | 01:54 AM
  #1051
mine sure did i got the replacement for under 20 bucks an it looks great
Old Jul 28, 2014 | 07:53 AM
  #1052
kornhuskerwizard's Avatar
As far as the idle with the ac on have you tried adjusting the white plastic knob by the upper intake??also isn't there a adjustment knob behind the glove box??I thought this was for adjustment of the idle with the ac on.lights look great!!
Old Jul 28, 2014 | 09:24 AM
  #1053
we turned that knob on the intake in all the way an out all the way with no change of idle i thought it was for that adjustment as well
i tried fiddling with the knob behind the glove box but again no change
Old Jul 28, 2014 | 11:47 AM
  #1054
Nervo19's Avatar
They don't offer it. My foam seems okay but it needs a little padding, like a layer of quilting fill. For foam go to Family Dollar or Walmart with a critical eye. Find the cheapest pillow that seems to be made from it and kill the pillow for its foam. I'm pretty sure there are lots of "firm" bed pillows made with foam on the inside. It'll be a lot cheaper than having a piece of foam cut for you at Joanne Fabrics. Joanne sells marine vinyl and headliner material BTW. Foam cuts really easily with a razor knife or an electric carving knife. My console project just got delayed due to not finding SEM paint locally and vacation starts Thursday.
Old Aug 11, 2014 | 01:30 AM
  #1055
Terrys87's Avatar
Just checking in and seeing how things are going for you. AC is getting moved up the priority list this winter. Last year of doing without it. It is miserable without it. Just got to buy some compressors.
Joanns has some great things, Hobby Lobby is starting to be one of my favorite places as well. I am ready for a vacation. They go so quick.
Old Aug 11, 2014 | 02:18 AM
  #1056
hey terry yeah my ac is dead again that suction line has to be the cause so i need that replaced
i found an arm rest slip over on ebay im gona play with it an the plate that screws to the console cover see if i ca make it my new arm rest not just as a slip over but fully screwed an glued to the factory plate
bought seat covers for her so least they will last longer they're black an gray the arm rest is the same so it all should work well
i need to find that wiring picture that shows where to install a switch in the back so if your back there you can roll the window down ive got a stout SPDT switch which will work great for it then some other electrical work i want to do in the back red led strips under the dash an front seats also over the cargo area (sight saving) an white LED strips i can turn on instead of the tiny side cargo light which i need to fix that so flick the switch it comes on NOT with the running lights on as well kinda dumb that have to turn on the running lights to turn on the cargo area light... dur should be just flick it on!
Old Aug 26, 2014 | 06:19 PM
  #1057
installed the seat covers ugh my coughing didnt help things along but i went into being a bit tight reared about it i took the carpet off the back of the rear seats to make it look good then installing the bottom seat covers i broke a strap on a sharp edge of the hinge overall they look excellent had to cut a slot for the rear seat pull strap an headrest holes the pull knobs to drop the seat backs ...
id say they look great an now ya just slip into the seat lol still waiting for my armrest from china
Old Aug 26, 2014 | 07:27 PM
  #1058
Terrys87's Avatar
I like the looks of the red and black. That switch for the rear, Mark has it toward the rear of his Ruby truck build. If I recall right, he had just done it before rolling it.
Old Aug 29, 2014 | 08:31 PM
  #1059
well the armrest pad arrived an i went right to work on it
some side by side pictures top them bottom (with the elastic straps that will be coming off)
removed old cover an powder foam core literally powdered YUCK wire brushed the internal plate
checking for alignment straps removed
holes to be made for screws
using a hot soldering iron to melt the holes fusing threads an such so they dont tear or fray
plate inserted cover attached whoohoo
will get a couple pictures tomorrow of the inside with seat covers
Old Aug 29, 2014 | 10:20 PM
  #1060
Terrys87's Avatar
Wow!!! You did a great job on that. Looks excellent.
