the dragons 88 runner buildup/rebuild
Old Apr 9, 2014 | 09:55 AM
  #1001
Cyberhorn The Dragon's Avatar
hey terry, the frame holes were not the same it was like the hoist was for a different frame had to make new holes it also wouldent fit into the guide pipe in the frame so we made things work
stopped by exhaust shop an he said its an easy fix so hat lined up on the 18th
so new holes drilled we had to adjust their side to side width a bit to get the hoist in the channel got wirewheeled an painted prior to the hoist being bolted in final time
quickly found out that the hoist wasnt going to just fit though an we added a hose clamp to the end to hold the hoist end when it goes through the pipe binds a little but it works
bit of rust removal an cleaning then hit with paint
modifications to bumper for the hoist handle
Old Apr 9, 2014 | 12:14 PM
  #1002
ChefYota4x4's Avatar
Nice work, as always, dragon!
Old Apr 9, 2014 | 03:39 PM
  #1003
meh i try but this was so-so if id thought ahead id drilled two holes in the bumper to keyhole the crank instead of notch the darn thing
Old Apr 17, 2014 | 04:58 PM
  #1004
well got a couple chips fixed in my windsheild (gravel for ice)
the lady (quite nice an very friendly) fixed the chips an part of the service cleaned all the glass an even supposed to vacuum the runner i was nahh ill do the vacuuming
then i got the clean bug so gave her first bath of the year an then got the buffer had to make a bonnet for it an some compound then wax an polished her up a bit
even with the ripples the rustolium holds up an took a shine an so smooth couldnt set phone on it slid right off LOL
now dragon hurts waiting for ibuprofin to kick in ow...
Old Apr 17, 2014 | 05:14 PM
  #1005
rattlewagon's Avatar
Trucks looking good as always!
Old Apr 17, 2014 | 05:44 PM
  #1006
thank you, eventually will get the steel to fix the rear quarters then can do the insulating an such to make her quieter an temp stable like terry an mark have done
Old Apr 17, 2014 | 10:00 PM
  #1007
jason in tn's Avatar
Hey dragon I bet you thought I forgot about you, well I haven't I've just been slammed with life stuffs, the sheet metal I told you about months ago was way rougher than he gave the impretion of and truly was worth cutting out but alas I have found another one and as soon as I get some free time I will do my absolute best to keep my word buddy, sorry for dropping the ball and not staying in contact with ya. Hope all is well and the ibuprofen is kicked in.
Old Apr 18, 2014 | 01:43 AM
  #1008
Terrys87's Avatar
Dang!!! Your truck is looking good and has come along way. You have done great bringing it back. Great Job!!!
Old Apr 18, 2014 | 09:35 AM
  #1009
its ok jason i knew life was hitting ya all around the place ya didnt drop the ball so no worry
thanks terry
Old Apr 24, 2014 | 03:23 PM
  #1010
some pictures an some experiments
got a picture of the fixed exhaust from last week
got tired of the dark gray stains an corrosion so decided to see what i could do about it did some emery cloth for the really bad pitting on the lower 1/4 of the rim that didnt do so hot fixing things
then wire brush meh
chrome polish nope
annoyed a bit i got the can of easy off (the last dregs of it) sprayed it on
ok not bad trying more got pictures of it so you can see what went on cleaning a bit more easy off then hitting it with a wire brush to scrub it
before
oven cleaner applied
yes i know the easy off takes the clear coat off...isnt much of a problem they arent in the greatest shape right now
after
likely to take a sanding sponge an then start polishing things a bit hit it with clear after degreaseing
Old Apr 24, 2014 | 03:29 PM
  #1011
Those look great dragon, I've always wondered how oven cleaner would work.
Old Apr 24, 2014 | 03:40 PM
  #1012
well its 3/4 of a rim didnt have enough to finish lol
Old Apr 25, 2014 | 05:25 AM
  #1013
Terrys87's Avatar
Easy Off cleaned them up nice. I will give that a try on Mistys rims. Hers are in bad enough shape it wont hurt them any.
Old May 3, 2014 | 03:23 PM
  #1014
today after much drama around the house i got on a minor project thats bugged me for awhile my rear wiper arm found the parts in the side compartment the mount still on the pivot on the top
so work area after 3 searches of our screws an nuts not a single one would fit to replace the missing one and the nearly stripped one barely holding the ramp on the arm
so trip to the bolt store 50 cents each two alen headed metric cap screws in a thread we have a tap for the arms 2 screws are some funky 5mm not a standard thread either
drilled out an retapping threads had to drill out the blades mounts just a bit the ramp the bolts were perfect size sanded things a bit as i went to get rid of corrosion an such
assembled but bolts are too long so grinding down
all fixed! ugh what i had to go through to fix this
painted
now i have to reconnect the switch in my center console
Old May 3, 2014 | 04:18 PM
  #1015
installed need new blade but its finally installed after all the time ive had it
Old May 4, 2014 | 07:30 AM
  #1016
Gizler00's Avatar
Very nice. I just replaced mine a few weeks ago as well. There was some other kind on there from the day I picked up my runner. It just never worked right and had 1 screw that would hold the blade on.
Plus it would always get stuck on the window and not fully retract.
Old May 5, 2014 | 05:25 AM
  #1017
i dont know if mine will retract yet, need the new blade an to get the switch plugged back in
Old May 5, 2014 | 11:53 PM
  #1018
Terrys87's Avatar
Once you take them off they are a pain to get them where they retract right. It has it sweet spot that it just likes. One spline off either way and it seems to make a difference.
Old May 6, 2014 | 05:30 AM
  #1019
nod the wipers on the old 79 hylux was the same an the arms were wore out from slipping snagged a pair off an old mazada which worked pretty good
Old Jun 14, 2014 | 02:18 PM
  #1020
finally bought the headlight harness upgrade for my ol girl an got more frameless wiper blades my current ones getting a bit streaky
in other news i want to enjoy my runner this summer likely gona be the last i do dr's want to do or i should say they are recommending...
a below the knee amputation of my right foot due to the long term non healing wound
