Build for a buddy. 2wd SAS 84/1st gen truck
Old Dec 2, 2014 | 06:36 PM
  #301
Gizler00's Avatar
I believe you can just replace the bearing on the tensioner rather than the entire thing...
Yep. That's what I did with mine a few months back. I have the part number in my build thread. Just need to go back and look.
Old Dec 3, 2014 | 10:03 AM
  #302
Gizler00's Avatar
Update 12-3-14
Forgot to add a picture of the bearing pressed out of the pulley
Picked up the new bearing today that they will press back in and install on the engine tomorrow.
Also making progress with the wiring. We decided to pull the entire cab harness out of the 88 2wd donor truck that I have and swap it over to the 84 cab. Everything on this 84 cab is pretty hacked up as far as wiring goes and its hard to decipher what is going on. So if we can make it easier on ourselves then thats what we are going to do.
Started pulling the harness on the 88
This is where we stopped today.
We were also dealing with this 89 supra at the moment. It is kicking out butts a little. We tore into the tranny for a clutch replacement and its being difficult.
The supra does not have the 7MGTE but rather a swapped in 1JZ twin Turbo. Now the goofy part is that the R154 trans will work but with a different bellhousing. Our problem is that the tranny does not want to drop down and clear the tunnel enough to come out. So tomorrow we are going to either slightly drop the cradle, or try and loosen the motor mounts while the crane is attached and lower it the 2" we need to get it out.
I started reading around on the forums and there are a lot of people who do not like these supras because they are a pain to work on. Im starting to see why. Haha.
Old Dec 3, 2014 | 10:10 AM
  #303
Terrys87's Avatar
Pulling the harness is a big job. Looking forward to your results. Here is a thread that might help if you get in a bind>>> https://www.yotatech.com/forums/f116...4-88-a-278925/
Old Dec 3, 2014 | 10:45 AM
  #304
Gizler00's Avatar
Thanks for the Link Terry!! We are going to have to most likely modify the harness in some areas to accommodate a few things along the way. Its not going too bad thus far but tomorrow could be a different story.
Old Dec 4, 2014 | 06:40 AM
  #305
Terrys87's Avatar
Here is where I got the stove kit.>> http://www.orschelnfarmhome.com/sing...si5188967/cl1/
Eventually I want to do this>>> http://www.orschelnfarmhome.com/doub...si5188970/cl1/
I eventually want to get this for a back up for cooking if we ever lost power again. I have gas heat in the house, but my cooking stove is electric. When we lost power a few years ago, this would of been handy to have http://www.orschelnfarmhome.com/barr...si6449904/cl1/
Old Dec 4, 2014 | 09:58 AM
  #306
Gizler00's Avatar
I need to get one of those kits! Thanks for the link Terry
Old Dec 13, 2014 | 11:58 AM
  #307
chosenchange's Avatar
wow fantastic build and some great info. I learned about the toyota bible which was a cool score and I also learned how happy I am that the pacific Northwest or even Southern Oregon area is fantastic for having old vehicles with little to no rust. That sure makes life easier well that is if you can find a older toyota haha. Thanks for having the patience to teach the newest toyota loving generation. Awesome stuff for sure!!
Old Dec 15, 2014 | 07:59 AM
  #308
Gizler00's Avatar
Thanks for the words of encouragement! I wish we could have rust free vehicles over here in the rust belt!!
Its nice when some of the students want to stay focused and get work done. Some days are more challenging than others.
Old Dec 15, 2014 | 05:18 PM
  #309
well for being kids that not to bad. I am an adult and ave found it is hard to keep me on track sometimes. Not only because some times I can't afford to stay on track and sometimes life does not allow it. Ill be checking in to see how you guys come along. I am in the process of doing the 2wd swap right now too. I have only two hands working on it and a limited budget per month so it is fairly slow going but very rewarding. I did not have the luck of having auto shop in high school which I would have been very good at I feel. I now have missed the train and am reduced to being a back yard mechanic now. Keep up the good work!!
Old Dec 15, 2014 | 05:51 PM
  #310
kornhuskerwizard's Avatar
Nice work man!!that supra has a twin turbo swap??!!sweet!!
Old Jan 8, 2015 | 07:22 AM
  #311
Gizler00's Avatar
Yes IJZ swap with Twin Turbo setup. Pretty Fast.
Old Jan 8, 2015 | 07:23 AM
  #312
Gizler00's Avatar
Still here guys. Just have been busy with the holiday and a house full of sick kids at home.
We still need to get the shock hoops welded in, get shocks, wiring harness swap, and get it running. Hopefully we will have time next week. Just wanted to give you an update.
Old Jan 8, 2015 | 11:44 AM
  #313
rustED's Avatar
I hear ya on the sick kids, it's like a vicious, neverending circle of getting each other sick, lol. They finally get over one thing and a week later it's something else!...
Look forward to seeing some pics in your next update!
Old Jan 8, 2015 | 05:45 PM
  #314
Gizler00's Avatar
Hey ED! You hit the nail on the head with that one. Totally passing the sickness around till its all gassed out.
Im hoping to get some pictures up tomorrow.
I was asked by a former students dad to look at his 92 reg cab 4x4. I just discovered a badly rusted frame on the passenger side near the tank. I called him on my way home from work to inform him of this and see if he wanted to come down and asses the situation. It really stinks because the rest of the truck is fairly solid and looks pretty good.
Ill try and get a picture up of that one tomorrow also.
Old Jan 9, 2015 | 02:14 PM
  #315
Terrys87's Avatar
Mud get trapped right next to the tank is the biggest problem. Maybe it can be plated. I would check all the way to the tail gate. Sometimes it goes all the way to the tail gate.
Old Jan 15, 2015 | 10:22 AM
  #316
Gizler00's Avatar
Thanks for the advice Terry. You are right, This one is bad and all the way back like you said. He wants to nurse it along until the summer time then maybe have me fix it then.
Old Jan 15, 2015 | 10:23 AM
  #317
Gizler00's Avatar
I promise to make some updates soon. Been super busy and swamped at work and home.
Old Feb 5, 2015 | 06:38 AM
  #318
Gizler00's Avatar
Update: 2/5/2015
Sorry for the lack of updates on this project. Unfortunately there is not anything substantial to report. I have been dealing with quite a few troubled students. Attendance is horrible at best. Some have 15 days missed out of the 42 that we have been in session this trimester. The rest of them have missed around 10. It it very frustrating as these are the top level kids in my program.
I send them to the local GMC dealership to intern and earn a college credit. But lately, they have been leaving to go to job shadowing and conveniently disappear somewhere along the way. Then i get a call from the service manager wanting to know where they are at.
Then when they do show up, I only have two kids that will actually work. It is a battle with the rest of them to get anything done. I end up doing everything because it has to get done regardless.
Old Feb 5, 2015 | 09:16 AM
  #319
Terrys87's Avatar
I feel your frustrations with these kids. Probably a good reason as I was able to retire from the guards as I was losing patience with these kids now a days. I am sure I was a screw up when I was younger but not this bad anyways. I really feel the kids now have more oppurtunity then we had when they were younger. Now they can earn college credits for their studies. That was not available to use when we were younger and then the chance to work for a dealer? That was just unheard of. I had three family members that worked in the school system and they have the same story.
Old Feb 20, 2015 | 04:50 AM
  #320
Gizler00's Avatar
Update! 2/20/15
CRAZY NEWS!! The truck is going to be in Omaha World of Wheels Car Show next weekend. February 27-March 1
I will give more info as I get it.
