Build for a buddy. 2wd SAS 84/1st gen truck
Old Apr 14, 2014 | 11:50 PM
  #101
Terrys87's Avatar
No suggestions about the lift, but I do like seeing a scrap piece of steel starting to look like parts needed. I am starting to see the big picture of what is going on. The day I get to own welder and cutter is going to be a joyous day. I like seeing how your project is going from paper to reality and quick at that. Tell the kids they are doing great!!!
Old Apr 15, 2014 | 06:03 AM
  #102
Gizler00's Avatar
Id want the extra inch!!!
Originally Posted by rustEDyota83
If you decided to go with hi-steer you might need that extra inch of clearance for your tie rod and drag link, I believe you need at least 3" of lift. Also to me it looks like the hanger would be stronger, you'd be able to weld more of an area than in the bottom pic. Your students are making some good progress!
I think that you guys have steered me in the right direction. We are going to go with the top pic setup. I want to be able to give him the option to do hi-steer later on.
The students are really doing a good job on this project. I am going to order the pins needed for the rear today or tomorrow and hopefully have all the suspension on and axles under permanently by next week.
Old Apr 15, 2014 | 06:06 AM
  #103
Gizler00's Avatar
Thanks Terry!! I really try hard to use up all of our resources first before going and getting more. There is so much stuff sitting around that you forget about over time, that you can use to make what you need.
I love having a welder and metal working tools. Even the simplest/most affordable welder will get basically any job done within reason. Most of the tools that we have are at the entry level end of things. I do however, dream about the day I can buy myself a nice new Millermatic welder, and a TIG welder!!
Old Apr 15, 2014 | 06:23 AM
  #104
rattlewagon's Avatar
A little drop in the front isnt bad, will help with pinion angle. All the kits come giving a 2" drop over stock (I think) One of those hangers looks cut a little close to the mounting hole? Look at the pic you posted to copy vs what got cut from the tube. You want to make them thick, they are prime rock anchors.
Old Apr 15, 2014 | 08:17 AM
  #105
85sr5excab's Avatar
It's too late now but what u could've done with the hanger is notch the tube to allow the hangers to sit on the the tube and then cap the exposed ends. It would give the entire hanger more strength but nevertheless what u have should be sufficient. I really wish I had the option of taking an automotive class when I was in high school. Lots of good stuff going on in ur class.
Old Apr 15, 2014 | 09:05 AM
  #106
Gizler00's Avatar
Thanks for the heads up. We can make new ones if need be. They have about 1/4 inch from the outside of the hole to the edge of the piece. But I will definitely remeasure
Old Apr 15, 2014 | 09:20 AM
  #107
Gizler00's Avatar
Its not too late. We have the top piece cut to full length, so we could still notch it out. I like the idea of that since it would make it stronger.
I hear you on the automotive classes. I wish I had the opportunity to do a project like this in HS. I think of the knowledge I would have right now if that was the case. But unfortunately, we did not even have the option to take an auto class.
Most of the students realize the opportunity they are getting by doing projects like this. So it pays off pretty good.
Old Apr 16, 2014 | 10:22 AM
  #108
Gizler00's Avatar
Update 4-16-14
This will be the last update for a few days since we are going on Easter break after today.
We ended up tacking the front hanger together enough to clamp to the front support and hang a spring to see where it would put us in relation to where we have to drill out the tubes.
I have the front hanger flush with the front of the support. This is going to have to go back further as flush with the front puts us to far forward for the stock length springs to work.
You can see in this pic what I mean about how the shackle angle would end up the wrong way for us if we went with the hanger being flush with the support.
Luckily we have a few frames here that I can use as a reference. If you look at the 84 frame, the centerline for the front bolt/pin is almost in line with the rear of the spring hanger.
We are going to have to move this back to achieve our proper angle for the shackle.
Please keep in mind that everything is simply mocked up and no finish welds are made. We still have some work to do on the front hanger but wanted to get an idea of where this setup would put us.
I really want to get the front springs hung by next week so that we can start plumbing the frame with fuel and brake lines. Also be able to set the engine in and mock up the mounts for the 4wd cross member that we have to make and weld to the frame.
Getting closer but still feel like miles away since this suspension is taking forever it seems like.
Let me know what you guys think.
Old Apr 22, 2014 | 02:34 PM
  #109
Gizler00's Avatar
Got some more done today. I have the drivers side drilled out and the tube is slid into the frame. I am going to drill out the passenger side in the morning.
I want to do like chris( kornhuskerwizard ) said, and get some conduit to run through and make sure we are level and square before welding.
I had some trouble on the outside old. The pilot but slipped a little, causing the hole to be more to one side. So I stopped, filled the indent with weld, made a new set punch indent for drilling, and finished the hole. It is very hard to get the holes lined up perfect with the hole saw bit.
I had to do a bit of work with a file just to get the tube to slide through just right. I know that I will have to make some final adjustments to get it perfect.
Attached Thumbnails Build for a buddy. 2wd SAS 84/1st gen truck-image-3363426607.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-1818412722.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-689928484.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-3612134736.jpg
Old Apr 22, 2014 | 02:36 PM
  #110
Gizler00's Avatar
Another pic
Attached Thumbnails Build for a buddy. 2wd SAS 84/1st gen truck-image-3141246181.jpg
Old Apr 22, 2014 | 07:25 PM
  #111
rustED's Avatar
Nice work on cutting out the hole for the frame tubes! I tried using a hole saw when I did my SAS and gave up after snapping 2 bits in about 30 seconds, lol.
Old Apr 22, 2014 | 07:29 PM
  #112
^ This.
Old Apr 22, 2014 | 08:46 PM
  #113
Gizler00's Avatar
I took my time and drilled the pilot hole first then attached the hole saw to the drill. It was a little sketchy going through, but this 2wd frame does not have the inner ribs that some of the older 4wd frames have that people experience drilling through.
I have to do some more filing, check for square and level and burn them in.
Thanks for the compliments guys.
Old Apr 22, 2014 | 11:18 PM
  #114
Terrys87's Avatar
Looks like a clean job on it and it looks good. Great job on that.
Old Apr 23, 2014 | 12:19 AM
  #115
rustED's Avatar
I was going to ask you about that, I was wondering if the 2wd frames had that inner rib reinforcement running through the middle, those are a major PITA!
Old Apr 23, 2014 | 05:46 AM
  #116
Gizler00's Avatar
HAHA yeah Chris (kornhuskerwizard) said it about broke his wrists when the hole saw hit the rib in his frame!! So I was bracing for it to happen the whole time!
Old Apr 23, 2014 | 01:11 PM
  #117
Gizler00's Avatar
Well we successfully got the tubes through the frame. We do not have them tack welded yet, but I am planning on doing that tomorrow.
I used the advice of others that suggested getting a piece of 1 inch EMT conduit to run from tube to tube on the frame rails. I put a level on the tube, and it is almost perfect.
We temporarily hung the front springs to see where we are going to mount the front hanger and get everything burned in.
You can see right now in the one pic the difference between here the eyelet meets the front hanger.
What I need to figure out is how much shackle angle I want/need before we burn it all in. Any suggestions??? I'm open to all advice.
Thanks for looking guys
Attached Thumbnails Build for a buddy. 2wd SAS 84/1st gen truck-image-2466019862.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-4284643745.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-2030818067.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-2127200870.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-3860425099.jpg
Build for a buddy. 2wd SAS 84/1st gen truck-image-3452457506.jpg   Build for a buddy. 2wd SAS 84/1st gen truck-image-1882551071.jpg
Old Apr 23, 2014 | 02:00 PM
  #118
kornhuskerwizard's Avatar
Great work! Holes look nice! Tell the guys theyre doing a great job also!Sorry about your welder.
Old Apr 24, 2014 | 04:55 AM
  #119
Gizler00's Avatar
Thanks chris! It feels like its taking forever for us to get a little bit of work done. I am hoping today to have the front axle in place and see what we are going to do for steering. I also want to start pulling the engine from the 81 pickup and fitting it in the frame.
Old Apr 24, 2014 | 09:45 PM
  #120
Atleast i can vouge the engine ran good and tranny and tcase worked as well other than the tranny bushings seemed worn out.I think once you get the suspension and steering done the rest will be down hill.
