KawaZX636's 1983 Toyota Pickup Restoration
Old Apr 9, 2014 | 07:30 PM
  #581
kawazx636's Avatar
Dang Stephen, you are far too excited about the visor.
Corey what year Tacoma visors work well? Are they a direct fit or is there some modification required?
Old Apr 9, 2014 | 07:38 PM
  #582
kawazx636's Avatar
Corey, forgot to ask what you used to clean your inner fender liners. Mine have the same build up of grime and undercoating as yours did.
Old Apr 10, 2014 | 04:16 PM
  #583
slacker's Avatar
I have been looking back , and I can seem to find where I marked it down .
If my memory serves me , Tacoma was in the 96-99 area . I do know the 90's pick ups and 4 Runners will also work .
I believe I just removed my original hardware , and replaced it with the donors ..
good old fashion "elbow grease" .. I used a bar to knock off the big chunks and a screw driver for the little stuff .. once it was all clean , I used a scuff pad to prep . for paint .
also just rated your thread bud .. 5 Stars for you
Old Apr 10, 2014 | 09:09 PM
  #584
kawazx636's Avatar
I just ordered a bunch of Genuine Toyota new-old stock tonight! It's not really anything that I need right now but they were original and available so I snagged up the stuff that I knew I probably wouldn't be able to get later and it is important stuff that makes a difference in overall quality of my build. Here's what I got:
-Driver and passenger vent window seals
-Corner marker lenses (the clear ones on the headlight doors)
-Driver and passenger window reveal trim (goes on the base of the window on the outside of the door)
-Driver and passenger window run channel (runs around the window frame and guides the window up and down)
-Tailgate cable stays for my Tundra (I had one snap on me a couple weeks ago and I tweaked my tailgate slightly)
Again, all original Toyota parts! There are a few other parts available that I want, but they are less rare and he has a bunch still in stock. If anybody wants any of my old parts listed above let me know. They are all still good and definitely useable, just not quite up to my build standard.
Old Apr 13, 2014 | 08:54 AM
  #585
Erick561's Avatar
From: I ship from New London Connecticut I PriceMatch
lookin good
Old Apr 13, 2014 | 07:50 PM
  #586
kawazx636's Avatar
Got caught up fixing my wife's car this weekend. She whacked a curb and needed a new tire so I took care of that. Her struts were wearing out so i replaced them. While I was doing the struts, I noticed that the sway bar links were bad too so I replaced them as well. The allen head on the joint shaft was stripped out so I had to cut the links off with a die grinder. Total PITA since they are located in an awkward position.
I did do a little sand blasting today. Got the hood done and a little bit of one door before my water separator on my compressor decided to take a dump on me. My blaster kept getting clogged with the water in the line. I'll run out and get a new separator sometime this week.
Here's the hood (still no rust or PO BS repair surprises yet):
Old Apr 18, 2014 | 05:47 PM
  #587
kawazx636's Avatar
Got a bunch of stuff done this week, let's start with the fun stuff first.... PARTS DELIVERY!!! My son was pretty excited to open them up:
I got the vent window seals, corner marker lenses and tail gate cable stays for my Tundra. All original Toyota parts!
Took apart my vent windows. Took a picture for reference when re-assembling:
And shined up the chrome on the vent windows:
Cleaned up the windows too:
Removed the vent window frames:
And sandblasted them (I'm planning on powdercoating them):
Sandblasted the doors:
Had my little helper scraping off seam sealer - he wasn't very efficient, but he was happy trying to help so that's all that matters.
Got pretty much all of the exterior of the cab blasted:
All I have left to sandblast would be some of the engine bay, the interior and underneath the cab. Shouldn't be too bad since I have a lot of the nitty gritty done already. A little bit of seam sealer left to scrape off and it should go smoothly. By the way, if you ever get the notion to use rubberized undercoating, do the next owner a favor and DON'T!!! That stuff is a pain in the ass!!!!
In other news, I got a phone call from Corey on my bed. Should be ready to ship shortly so I dropped a check in the mail for the balance I owe him. SOOOOOO stoked to get the bed, can't wait!!!
Old Apr 18, 2014 | 09:03 PM
  #588
gillesdetrail's Avatar
It might be a bit too late, but to remove my undercoating I found it easy to remove by laying down a thick layer of aircraft paint remove, then after about 10 mins I used my grinder with a coarse brush and it came off like butter. I just found that out this week too. Your cab looks great sand blasted and it is very clean too, also nice to see you building memories with your kid working on the truck, priceless stuff!
Old Apr 18, 2014 | 10:33 PM
  #589
dropzone's Avatar
Fossilized
Price on the cab shipped to Portland, Oregon?
Old Apr 19, 2014 | 04:24 AM
  #590
Cab4you26's Avatar
Build is looking awesome. Can't wait to see it painted!
Old Apr 21, 2014 | 06:07 AM
  #591
kawazx636's Avatar
I think there is a different mutant breed of undercoating on this thing. I tried aircraft stripper on it before and it wouldn't even penetrate it! I used a product called Strip it Dry which is the same stuff that I have always used to remove powder coating from my motorcycle wheels so I could polish or chrome them so I know it is high quality stuff. On this undercoating it would just goop up the surface and leave behind everything else beneath. Good ole elbow grease, razors and chisels are the only thing getting the job done on this.
$3,500? Or whatever Corey plans on putting his fiberglass cab reproductions on the market for.... LOL Nice try Rob!
Old Apr 21, 2014 | 06:14 AM
  #592
Erick561's Avatar
I have a cab on sale for only $100
Old Apr 21, 2014 | 10:14 PM
  #593
kawazx636's Avatar
More parts came in this weekend. Toyota original window channels/seals and the outside window reveal trim:
Also powdercoated the vent window frames tonight:
And of course I had to put at least one back together, so after fiddling with the new vent window seal for about a hour I got one of the vent windows assembled:
Still have the driver side to do, but just to warn anybody looking to refurb their vent windows, I would HIGHLY recommend getting the frames powdercoated or chromed. The new seals are pretty tough to get in the frame channels and I imagine that if I just painted them they would have been fairly scratched up in the end. Powdercoat is tough as nails so I had no worries. Now, if only I had some painted doors to install them on....
Old Apr 22, 2014 | 03:37 AM
  #594
83 trail rig's Avatar
Ok Dave who do I make this 3,500 dollar check for the cab out to you or your wife
Old Apr 22, 2014 | 05:50 AM
  #595
kawazx636's Avatar
^He gots jokes! LOL I'm sure she would gladly accept the check if it would get any part of my truck out of her life. I try not to let my wife know how much I actually spend on my truck - that would likely cause a divorce! At this point she still thinks that I am slightly over budget at about $4,500... I have that in my chassis alone! My rule of thumb is to take what ever the actual cost is and divide it by 3; however, I may have to start dividing by 4 soon!
Old Apr 22, 2014 | 06:14 AM
  #596
I have done the same with my vw's back in the day till she decided to get interested in them also she brought one home and started shopping for parts she said it's going to cost her over ten grand to fix it up and I and my father had her convinced they where cheap to fix up lol
When she passed I got rid of all my vw's and parts which I had been collecting since high school two years ago I decided to do my favorite pickup bought it drove it tore it apart research and slowly build this almost daily driver/go almost anywhere trail truck / I am hoping to do an across country thing when it's finished meet up with the local 4wheel community along the way also in mind was a good camera for video logs and laptop
Ps tundra goes for recall next week undercoat lol and I still haven't done my wheel bearings
Old Apr 22, 2014 | 08:29 AM
  #597
kawazx636's Avatar
Unless your truck really needs it, I wouldn't do the recall. The dealership just slaps that stuff on there, looks like crap and it took over a week to dry. I picked it up the day after I dropped it off and it was pretty much still dripping off the frame! And forget about parking it in a garage for a couple weeks because that stuff STINKS! They also apparently had to lift my tranny to get the top side of the cross member because when I picked it up the tranny mount bolts were barely threaded on and my transmission was sliding all over the place when I was driving! I was so pissed, that I went back to the dealership and raised hell. They said "we'll tighten everything down for you." I said "no need to, I already did it, but this is EXACTLY why I am the only one that ever works on my vehicles!" Slammed the door and left. This comes right after my wife took her Camry in for diagnostics on a steering noise because I didn't have time to fix it. I told them that the noise was coming from the pivot bearing bushing in the upper strut mount. They came back saying that it was the sway bar end links and that they would replace them for $110 in parts and $210 for 2 hours of labor (We had already paid $110 for the diagnostic service). I said FU, you guys are ridiculous and left. Got home, checked the links and they were worn so I replaced them. I had my wife time me to show how far off the dealer's time estimate was...wait for it...wait for it... EXACTLY 28 minutes and 31 seconds to do both links, in my driveway, with one jack AND I actually had to cut one off with a die grinder because it was seized on! I guess they figure in a 90 minute break during each service. Then the noise was still there (because the links weren't the problem like I had told them) so I popped out the struts and removed the caps to find out the the pivot bushings on both sides weren't seated properly when the DEALERSHIP did the warranty work on the strut replacements about a year ago. The wife timed this one too... 1 hour 23 minutes to remove both struts, compress both springs, re-seat both bushings and re-assemble. Perhaps I should get a job at the dealership???
Old Apr 22, 2014 | 01:55 PM
  #598
Having that job would ruin your work ethics
Old Apr 22, 2014 | 02:58 PM
  #599
84 yota dude's Avatar
Nice job on those vent windows! How do you restore the chrome to get that shine?
Old Apr 22, 2014 | 05:55 PM
  #600
rustED's Avatar
Nice work on the cab and doors, its gotta be nice to start with bare metal when getting prepared to prep for body work and paint. Vent windows turned out sweet too!
