Dropzone's 1981 Trekker Build-Up Thread
Old Jan 8, 2009 | 09:59 PM
  #201
Al's Chop Shop's Avatar
well....!!!!!
Al
Old Jan 9, 2009 | 08:24 AM
  #202
Ron's 85's Avatar
Originally Posted by Sonofmayhem
Nice, but weak numbers, i will be on number 5 in a total of 3 years
you got are 3.4 in your 1st gen truck? do show!
Old Jan 9, 2009 | 06:05 PM
  #203
nosfanatic2006's Avatar
GORGEOUS truck!!! My second dream Toyota
Old Jan 12, 2009 | 01:59 PM
  #204
dropzone's Avatar
Fossilized
Thanks!
Originally Posted by Al's Chop Shop
well....!!!!!
Al
I headed down to Mt. Angel to see how Derek was doing on my truck..its been awhile but the price for what he is doing is worth the wait...He said I should be able to pick it up next week, we'll see but fingers are crossed.
he was just in the process of starting on the rear suspension when I showed up:
One of his other customers had a brand new set of 36x13.50 Iroks, I think that is the size I am gonna go with:
Transfer case picked up two more sticks. Rotating the input shaft and having the out put shaft turn 11 (2.28*4.7) times was a good feeling with the transfer cases in double low
The local U-Pull It's had a 50% off sale on all self service parts so for $50 I now have Matching front and rear seats:
These are out of a mid 90's montero, the front seats offer some more support (better side bolsters) and are as narrow as my old Integra seats so they should not interfere with the planned internal cage.
On the way back from Mt. Angel picked up some of the steel I will need to make the universal seat brackets work with the Montero seats. The stock Mitsubishi brackets would put the seat about 3" too high. Also in the pic is a set of heated seat inserts I hope to be able to make work, guess I am just getting old...but should make a winter wheeling run a little more pleasant
Old Jan 12, 2009 | 03:14 PM
  #205
dannomite's Avatar
Where does one aquire a set of seat heaters? I live in northern BC in Canada. We have had well over 30 days of -30C and a lot of those days have had wind to boot. So seat heaters would be nice.
Old Jan 13, 2009 | 02:33 AM
  #206
Make him hurry! I need to see more
Old Jan 13, 2009 | 07:39 PM
  #207
dropzone's Avatar
Fossilized
found those on ebay...hooked them up to 12v, they seem to work as advertised..and the heated surface seems to be comparable to the heated seats in my Tahoe...
ran into a little snag: no spring bolts or bushings, either Trail-gear didn't include them or I misplaced them (probably the case) so had to order them so 4 bolts and 8 bushings should have'em in a couple of days...fingers are still crossed for a monday pick up...coming back on a trailer instead of the tow dolley this time
Last edited by dropzone; Jan 13, 2009 at 07:43 PM. Reason: added ebay link for seats...
Old Jan 18, 2009 | 09:28 AM
  #208
sweet!!! :thumbsup:
Al
Old Jan 25, 2009 | 03:56 PM
  #209
dropzone's Avatar
Fossilized
well, that monday passed...emailed to see if maybe I can pick the truck up this week..was waiting on the front drive shaft to come back
I was down a couple of weeks ago to check on it.
nothing big, but here is what you have left when 2 transfer cases become duals
between the donor case everything was in pretty good shape. i was worried about my $50 donor TC being junk but everything on the inside seemed to be good to go...
i am thinking about maybe finding an extra stock case and stock length rear drive shaft in case i every grenade anything...
Old Jan 26, 2009 | 01:51 AM
  #210
*tries to sit and wait patiently*
Old Jan 26, 2009 | 06:07 AM
  #211
dropzone's Avatar
Fossilized
try it being me.
i think I am driving Derek nuts with my 'when will my truck be done' messages...
Old Jan 29, 2009 | 12:28 AM
  #212
dropzone's Avatar
Fossilized
rear bumper is off the truck from installing the rear springs, thinking about adding some reinforcement from the mounting brackets to the reciever something like this:
Old Feb 3, 2009 | 03:54 PM
  #213
dropzone's Avatar
Fossilized
Well I was finally able to head down to pick up the trekker. Took longer than expected but for what I paid for the amount of work I am very happy.
--All the bare metal has been cleaned and painted after the pics were taken..
What was accomplished:
-Rebuild front end, ARP studs, front aussie locker installed, FJ rotors and V-6 Calipers, front diff armor, truss and knuckle gusset kit
-dual cases 2.28 in front case, 4.7 in rear case and Front Range Off Road Twin stick, Bud Build crossmember..
-5" T-G rear springs installed
-Front Shaft lengthened and rear shaft shortened
I really like using axle strap tie downs vs. the chain binders I have used in the past hauling.
The truck sit a little high in the back, but T-G springs have a reputation of settling...if not I can pull a leaf:
Derek fabbed up a new upper rear shock mount:
Front end all done. I had some steering issues, turned out when I put the pitman arm on I was a few splines off...Derek fixed that:
Front shocks, hoops and bump stomps:
no backing plates:
Duals in:
I am very happy with Derek at Revenge Fab's work...need to take it on a shake down run. A little trip around the block everything seems to work.
Thanks for Brian at Wab-Fab for giving me some great deals on parts.
To do list before major wheeling trip:
-Change all gear box oil
-Tune up, fresh fuel filter and fresh gas: it has been sitting for over 8 months so
-install seats
-rubber boots around the shifters...might need to dog leg the front TC selector
Wish List:
-Longfield axles and hubrings
-5.29's
-36 or 37" Iroks
-full cage
probably gonna need an exhaust, do a manual proportioning valve to eliminate the LSPV and other misc stuff...but for the most part the major junk is done
Old Feb 3, 2009 | 04:01 PM
  #214
waskillywabbit's Avatar
Looks bling bling. Your new bling shipped today.
Old Feb 3, 2009 | 04:06 PM
  #215
dropzone's Avatar
Fossilized
Thank you sir
Old Feb 3, 2009 | 04:54 PM
  #216
scuba's Avatar
I was hoping thats what this update was ...Looks good man !!! Now its just the little things..
Old Feb 3, 2009 | 05:11 PM
  #217
texcat101's Avatar
Swweeeeeet! You are gonna love it.... even more!
Old Feb 5, 2009 | 01:34 AM
  #218
dropzone's Avatar
Fossilized
yep, lots of those
Originally Posted by slacker
lookin' good Robb ....
thanks corey
it is nice to have it back in the driveway..cleaning out the garage so I can get back to work on all the little crap. Shake down run is planned for the 21st.
2wd in double low I did not even feel it when I drove up over the fender of my trailer and destroyed it idled right over
Old Feb 5, 2009 | 04:22 AM
  #219
Mmm. Looks delicious! So when are you going to fly us all out there for a ride?
Old Feb 6, 2009 | 06:09 PM
  #220
dropzone's Avatar
Fossilized
probably never but will be at the 2009 Oregon Yotatech Run at Brown's camp in June.
