The OFFICIAL IFS "What size tire will fit" thread
Old Apr 23, 2011 | 09:08 AM
  #401
frohbego's Avatar
I have the Sonoran Steel System 7.2 Suspension on my 2002 4Runner -
About: 2.5" Front & 3" Rear.
http://www.sonoransteel.com/index.ph...&products_id=4
I currently have on the BFGoodrich All-Terrain T/A KO Tires 265/75R16.
My question is can i go up to the next size BFGoodrich Mud-Terrain T/A KM 255/85/16?
Will they fit without any rubbing? I live in PA and wheel spacers are illegal. I have attached a few photos with my current tires.
With 255/85/16 tires can i get away without re-gearing?
Some photos of my current tires and the space i have right now -
http://4.bp.blogspot.com/-LwMrytalKi...NER-tires1.JPG
http://1.bp.blogspot.com/-dStLvnf8oU...NER-tires2.JPG
http://2.bp.blogspot.com/-IUYh7ILp7Q...NER-tires3.JPG
Thanks!
- JON
Old Apr 23, 2011 | 09:18 AM
  #402
4Crawler's Avatar
Best answer is to measure and see on the tire fitment:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
As noted, make up a little measuring block out of a scrap of wood or cardboard. The size will be 1/2 the added tire height and 1/2 the added tire width over what you now have. Why the 1/2 factor? Well tire diameter is twice the radius or distance from the center to the outside. So half the added height is below the axle and half above. Same idea on the width, half the added width is on the inside of the tire and half on the outside, measured off the wheel center line.
With block in hand, move it all over the face of the tread, edge to edge and find where the tight spots are with the fender and wheel well. For the front tires, try turning the wheels side to side and find the worst case condition with the edges of the tread the the wheel well and fender. And finally, try to flex the suspension by driving up on a curb or some ramps and turn the wheels to get an idea where rubbing might occur, if any. If you find adequate clearance all around, you should probably be fine with the new tires. If there is some minor rubbing, this may or may not be an issue, depending on the new tire and how true to size it is and even what it's shape is when mounted on your wheels. Some minor rubbing might be solved by doing some trimming/bending inside the wheel well, most often this involves the standing seam where the firewall and fender join in the back of the front wheel well. This is behind the plastic liner and is easily hammered flat to gain extra clearance.
Old Apr 24, 2011 | 09:50 AM
  #403
KatKrazy's Avatar
Has Toyota ever changed their wheel lug pattern? Specifically what I am looking at is buying a set of wheels and tires off a newer tacoma and wondering if they will bolt right on my 88 pickup. The tire size is confirmed to fit, it is just the wheel I want to make sure of. The purchase would be across country so I don't have the luxury of looking at them first.
Can anyone confirm? Thanks!
Old Apr 24, 2011 | 11:11 AM
  #404
ToyoTech559's Avatar
as far as i know all toyota 6 lugs off their trucks are the same lug pattern. what you need to make sure is the backspacing will clear your older truck.
Old Apr 24, 2011 | 11:31 AM
  #405
frohbego's Avatar
Can anyone post photos of 255/85/16 on their 4runner?
Where is the pinch weld located? Anyone have any photos of it pulled back.
Thanks everyone!
Old Apr 24, 2011 | 11:46 AM
  #406
4Crawler's Avatar
Pinch weld:
How-to:
http://www.expeditionswest.com/equip...bfg_mt_km.html
Old Apr 24, 2011 | 12:41 PM
  #407
KatKrazy's Avatar
Tech,
Describe this backspacing issue, or potential issue please? Are you talking about the tire hitting the fender because I have already made sure that won't happen.
Old Apr 24, 2011 | 12:47 PM
  #408
4Crawler's Avatar
Tech,
Backspacing affects inside clearance between wheel and suspension/frame:
- http://www.4crawler.com/Diesel/Tires.shtml#WHEELS
Good rule of thumb is to maintain close to stock b/s:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
Too much b/s and wheel hits suspension/steering/brakes/frame, too little and you push the tire out too far and increase likely hood of rubbing on the fender while turning.
Old May 23, 2011 | 07:59 AM
  #409
hungwin jza80's Avatar
Yet another fitment thread - Biggest Tires w/ 16x8 3.5" BS + 3-inch Lift?
Hey guys,
I've done quite a bit of searching both here and at T4R and I believe I answered my question, but wanted to check with the experts.
Truck:
'01 Sport with OEM Sport/Limited flares
Suspension:
ToyTec Ultimate Lift with OME 890 rear coils.
Wheels:
16x8.0 -25 offset (3.5" backspacing).
Tires:
Based on what I've read, I'm trying to stay away from Load Range Es, so I'm down to a few choices... I put my assessment underneath each tire - PLEASE correct me if I'm wrong.
1. BFG All-Terrain T/A KO in 285/75R16
- Known good fitment
2. BFG All-Terrain T/A KO in 295/75R16
- Should fit based on feedback that I've received due to my lower backspacing/offset.
3. BFG Mud-Terrain T/A KM2s in 305/70R16
- Will rub without a body lift. In general, this tire would require modifications to the pinch weld(s) and fender flares. I didn't see anything specific as to whether or not the front and rear bumpers would rub.
I'd love to go with Tire #3, but not at the expense of hacking up my truck. I've done that enough with the fenders on my cars.
Thanks!!!
Old May 28, 2011 | 07:02 PM
  #410
Drgoodspd's Avatar
I think this may be the correct thread to post this on.... I have YET to find pics (and i have SCOURED the internet) of a STOCK suspension, 3rd Gen 4Runner, with 265/75/16.... WITH SPIDERTRAX wheel spacers..3rd GEN 4RUNNER w/ WHEEL SPACERS... i DID it.. HERE are the pics. I skipped pics of installation, we all know how to put wheel spacers on right?
BEFORE
AFTER
AFTER
BEFORE
Old Jun 14, 2011 | 06:04 PM
  #411
kmcmahon93's Avatar
i have a 91 pickup have had as big as 33/12.50/15s or 31/13.50/15s on it no problem at all. im looking to get some new wheels and tires thinking the bfg wanglers 35/13.50/20s. i have a 3" body lift and going to crank up the front as high as i can and level the truck with blocks in the rear. should the 35/13.50/20s on 20x10s b/s 4.79 offset -18 fit?
Old Jun 15, 2011 | 06:07 PM
  #412
idk about tire size fitting. but your BL should help. anyways for the rear, should look into the zuk mod for a lift
Old Jun 15, 2011 | 06:24 PM
  #413
kmcmahon93's Avatar
zuk mod? not sure what that is. im getting the tacoma fyberglass front fenders hood and grill for the long travel suspention too.
Old Jun 15, 2011 | 06:31 PM
  #414
its where you install a coil spring in between the rear upper and lower bump stop. its a much better way of lifting imo than blocks. plus you get a better ride and can handle more load weight wise
a few guys have done it on here, heres a link to one as an example
https://www.yotatech.com/forums/f116...photos-207564/
at the very bottom are a few more done a little differently
http://gearinstalls.com/
heres how i did mine
https://www.yotatech.com/forums/f116...prings-232169/
Old Jun 15, 2011 | 06:46 PM
  #415
4Crawler's Avatar
Measure and see:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
But that is a pretty wide wheel/tire combo and width is as much of an issue as height. A buddy of mine had a '92 pickup w/ 4" bracket lift and needed to add a 2" body lift on top of that to clear 35x12.50s on 8" rims.
Old Jun 16, 2011 | 11:20 AM
  #416
kmcmahon93's Avatar
nevermind the 35s. i have 08 tundra stock wheels im going to try to put on. they are 18x9s b/s is 7", will those clear im geussing the adapter will be 1" spacer too. then 31x10.50x18 toyo a/t. i already ordered 14" 150lbs coils for the zuk mod.
Old Jun 17, 2011 | 07:45 PM
  #417
kmcmahon93's Avatar
adapters are expensive! drop that plan, got a set of 36x12.50"s that im going to try to get on the truck. i have 3 inch body lift and 14" 150lbs springs for the zuk mod and cranking the torsion bars way up. what do you think about the tires fitting?
Old Jul 5, 2011 | 11:17 AM
  #418
m4rkenyux's Avatar
nice ride Drgoodspd
Old Jul 8, 2011 | 05:54 PM
  #419
Drgoodspd's Avatar
Originally Posted by m4rkenyux
nice ride Drgoodspd
Thank you very much....
Old Jul 11, 2011 | 04:04 PM
  #420
knight5790's Avatar
I have a 98 stock 4runner 4wd SR5and have the opportunity to buy some wheels and tires off a 2007 tacoma, these are the tires, 265/70/r17 BF Goodrich All terrain, will they fit with out having to have a other work done such as spacers or anything?
