The OFFICIAL IFS "What size tire will fit" thread
Old Dec 25, 2011 | 06:39 AM
  #441
astynx's Avatar
Are there any Toyota OEM wheels with a 3.75" backspacing? I'm thinking about a Rough Country Suspension Lift Kit- about $800. They say you need to upgrade wheels ( for 33 x 12.50 tires ) with this backspacing. I was hoping I didn't have to extra expense of new wheels. Thanks.
Old Jan 2, 2012 | 01:12 PM
  #442
33X12.5X15 on 15X8's 4" BS , yes they rub , but they look good
Size:  132.8 KBName:  miscnov2011104.jpg
Old Jan 15, 2012 | 09:34 PM
  #443
l3igl3ang's Avatar
Hi how about 35s can this be done on just a 3" sup lift?
Old Feb 16, 2012 | 06:45 AM
  #444
jhouse225's Avatar
17 inch FJ Wheels on 2000 Tacoma, need help with tires
I just bought a set of 17 inch FJ wheels, and I need to get some tires. I currently have 31x10.50 R15 tires, so I've calculated that I need 265/65/17 or 265/70/17 tires to keep about the same diameter. I don't have any lift on the truck, so I think I need to keep the overall diameter about the same. I found a good deal on a set of 245/75/17's, but I don't know what will work the best without rubbing. I think these will be a little wider, but I also think the backspace on the FJ wheels is different. I think my stock rims are 7 inches wide, and I think the FJ wheels are 7.5. I'm getting confused with all the conversions. I figured someone on here with experience with these rims on gen 1 Tacomas could offer some advice.
Old Feb 16, 2012 | 07:34 PM
  #445
ToyoTech559's Avatar
265/70R17 is wider than 245/75R17
1st number is the width in MM
2nd number is the % of the 1st number = height * 70% of 265 is the height of tire
3rd number well you know is rim size
Old Feb 16, 2012 | 08:52 PM
  #446
James Woods's Avatar
They can be done on no lift, just depends on how much cutting and hammering you want to do, but yes they should fit.
Old Feb 16, 2012 | 09:05 PM
  #447
BoredOutnJackdUp's Avatar
Im confident i could run 35x12.5s right now. Just havent found a good enough deal on em.
Old Feb 23, 2012 | 10:21 AM
  #448
1989FourRunnin's Avatar
Hey all I was wandering if 31x10.50x15 would be too much for the Gimbles on my '89 4runner??
Old Feb 23, 2012 | 06:23 PM
  #449
Post
***EDIT*** I have these already on and was wandering if I continue with a new pair if it would be too much for the gimble joints to handle when in 4WD??
Old Feb 23, 2012 | 06:40 PM
  #450
It will be fine on what ever the hell you're talking about haha
Old Feb 23, 2012 | 07:00 PM
  #451
Lol well after looking up the correct terminology I guess I mean the Spider bearings and the universal joints.
Old Feb 23, 2012 | 07:05 PM
  #452
Yeah. they should be just fine with 31s. ive been running 33x12.5s almost a year and havent had a single problem.
Old Feb 24, 2012 | 12:02 AM
  #453
xxxtreme22r's Avatar
EDIT: dang there was another page, haha. Oh well, at least some of you guys know what a gimble joint is though now.
Some of these things came factory with 31 x 10.50's from the factory, your fine.
Oh and the joint your talking about is normally called a Universal or Cardon joint in vehicle world. I suppose in the industrial world you can call it a gimble joint though.
Gimble Joint
Cardon/Universal Joint THe joint all the way on the left is also called a Double Cardon or CV joint
Not to be confused with this CV joint which is a drive axle not a driveshaft like above.
Old Feb 24, 2012 | 09:38 AM
  #454
Talking
Gimble Joint
Thanks for the extra information and quick replies! Yea it is about the only term I could think of at the moment lol.
Old Mar 29, 2012 | 05:49 AM
  #455
markfagus's Avatar
Question Wheel fitment?
Guys, will the wheels off a 2000 Tacoma fit ok on a 88 4Runner? I dont think it will be an issue at all just want to make sure they fit over the locking hubs ok?
thanks
Mark
Old Mar 31, 2012 | 08:18 PM
  #456
DocLee's Avatar
I suppose I could search for hours on end and possibly piece together the answer to my question, but I chose to go the lazy route and just ask altogether. I have a 95 4x4 ext cab. I am purchasing a set of 2008 Tacoma 16x7 inch factory aluminum wheels to replace my 15x7 steelies. I plan to buy 265/75/16s from treadwright. I will be lifting my truck about 1.5" prior to this install. Am I going to need wheel spacers due to the difference in backspacing or will I be okay? Thanks for accomodating my late night laziness.
Old Mar 31, 2012 | 08:21 PM
  #457
You'll need at least 6 inch wheel spacers.
And about 9 inches of lift to clear those.
And a v8 swap to move the truck.
Old Mar 31, 2012 | 08:27 PM
  #458
DocLee's Avatar
Very funny. Seriously though, I figure I will need about 1 inch wheel spacers right?
Old Mar 31, 2012 | 08:43 PM
  #459
Well the first thing you need to figure out is will it fit over your hubs.
And im not positive of the back spacing, but yes you could possibly need wheel spacers.
Put them on and see if it rubs is really the only way to know.
Letting it rub for a week or two wont hurt anything.
Old Mar 31, 2012 | 09:13 PM
  #460
DocLee's Avatar
Gotcha. Thanks for the advice. I may just sell them and buy something else. I'm getting them super cheap so I can't get burned on the deal.
