The OFFICIAL IFS "What size tire will fit" thread
Old Nov 28, 2009 | 07:11 AM
  #201
Ron Helmuth's Avatar
GA22re If your hub size is stock-even with your locking hubs-then as Waskilly says there would be no apparent reason these would not work.
Perhaps I am missing the point- is your concern regarding the backspacing of the 4runner rim? or clearing calipers or something?
pretty sure that cross hatch design pictured was a Toyota OEM rim for the earlier 4Runners- sure can't think of a reason it would not work on a DLX pickup if I am reading your posting correctly.
Simple enough to be sure....remove one of yours and bolt up one of his and check clearance and so on...and if not it should be easy enough to find another buyer...
perhaps you can find that seller's rim online and verify all the specs against your current rim setup to be 100% sure.
If they are 15 x 7 JJ or whatever it should all be good yes?
Old Nov 28, 2009 | 08:46 AM
  #202
GA22RE's Avatar
Thanks a lot for the replies. I'm thinking they will work as well. I had them on my 91 SR5. Now I am looking to find some for my DLX. Thanks again.
Old Dec 8, 2009 | 07:06 PM
  #203
TacoLover's Avatar
It's time to change the tires on my '07 Stock Taco D-Cab. Currently has 265/65/17's, I found a good deal on General Grabber AT2 265/70/17's.
Will they fit? Are they a good tire? I would appreciate any feedback and/or opinions.
Thanks.
Old Jan 1, 2010 | 06:30 PM
  #204
elkdog's Avatar
subscribed!
Old Jan 5, 2010 | 07:26 PM
  #205
bryanchatfield's Avatar
I have a stock 85 sr5 truck, and i am planning on doing a 2" body lift, and I want to know what tires i can run? Mainly i will drive it on the road, but occasionaly take it off. So any ideas as to what i can rub with the lift as opposed to stock?
  #206
I have a stock 85 sr5 truck, and i am planning on doing a 2" body lift, and I want to know what tires i can run? Mainly i will drive it on the road, but occasionaly take it off. So any ideas as to what i can run with the lift as opposed to stock?
Old Jan 5, 2010 | 07:47 PM
  #207
4Crawler's Avatar
31x10.50 or 32x11.50 should fit OK, a 33x10.50 would take some added work most likely.
Old Jan 5, 2010 | 07:52 PM
  #208
How much additional work do you think?
Old Jan 5, 2010 | 07:53 PM
  #209
lyncoo's Avatar
94 with 5in total susp. lift. 33x14.50 fit good and looks good
Old Jan 5, 2010 | 07:55 PM
  #210
lyncoo's Avatar
i got a buddy with a 87 w/ 3in body kit and 33x9.50s and fits fine
Old Jan 5, 2010 | 08:10 PM
  #211
4Crawler's Avatar
Fender trimming:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Or longer shackle, mild body lift, move front axle forward, etc. I had to do all the above to fit 33x9.50s w/ a 3.5" susp. lift:
- http://www.4crawler.com/4x4/4R_suspension.shtml#Epilog
Main issue with the solid front axle is the axle moves backwards under compression because the spring shackle swings backwards (and unfortunately Toyota, in it's infinite wisdom, placed the front wheels too far back in the wheel well opening):
Note that on IFS trucks, the front wheels only move up and down as the suspension cycles, while on solid front axles, it moves down (and forward) and up (and back). What this means is that on IFS, a 31x10.50 fits perfectly on stock suspension, while on a solid axle, a 31x10.50 tire will rub on the back of the front wheel well.
Old Jan 5, 2010 | 08:12 PM
  #212
bak3rme's Avatar
i have 1999 4runner, stock, no life, with running boards. i have 265/70 right now but i wanna see how much of a difference 265/75 would make (with no lift) are there pictures floating around here showing the difference?
Old Jan 5, 2010 | 08:20 PM
  #213
4Crawler's Avatar
Only a 1" taller tire (31.6" vs. 30.6") so not a lot of difference, 1/2" extra ground clearance.
Old Jan 13, 2010 | 01:38 PM
  #214
Oktoberyzing's Avatar
i have a 3 inch body lift and a 5 inch suspension lift goin on soon, what size tires can i turn?
Old Jan 21, 2010 | 03:40 PM
  #215
anybody have an idea on my previous post??
Old Jan 21, 2010 | 03:46 PM
  #216
Lumpy's Avatar
Big...
I is this going on your 82 or 94? I have a 95 runner and I could stuff 33x12.50's without a lift. IMO you don't need 8" of lift and big shoes...but what do I know. You can probably run 38's or so but you have to worry about gearing as well. Hmmmmm did you think of that? They might fit but can you turn them.
Do you have a 3.0 or a 22re, auto or manual? it all makes a difference.
I'm assuming this is on the 94.
Old Jan 21, 2010 | 04:18 PM
  #217
goin in my 94 4 cyl. haha and yes i know about the gears and when i get through buildin the motor for it it will have between 200 and 400 horses, depending on which motor i decide to put in it(another built 22re or my 305)
Old Jan 25, 2010 | 11:46 AM
  #218
jibhonk's Avatar
so i have a stock suspension 98 4runner but i'm planning on putting a 3 and 1/2 in lift with a 1 inch body lift. will i clear 37's? i also know i will need to regear. what will i need to convert to 5.29 gears? i'm a newb so be easy
Old Jan 25, 2010 | 12:15 PM
  #219
DeathCougar's Avatar
My email alerted me to what you originally posted....slip of the button Jib?
Old Jan 25, 2010 | 02:50 PM
  #220
jibhonk's Avatar
no i went to get a drink and left the computer up with my friends around...you shoulda saw my facebook status -_-
