The OFFICIAL IFS "What size tire will fit" thread
Old Mar 29, 2010 | 05:14 PM
  #301
llbish's Avatar
P275/65R18 will they fit an 2004 Tacoma??
Have a good price on a set of wheels and tires, P275/65R18, but I don't know if they will fit my 2004, 4wd Tacoma.
Anyone have any experience using bigger wheels on one?
Thanks!
Old Mar 29, 2010 | 08:36 PM
  #302
whutface's Avatar
Time for new tires!
I've pretty much narrowed it down to one of these. I currently have 285/75/16 BFG Mud Terrains.
So Another set of the same for 223 each
http://www.tirerack.com/tires/tires....omCompare1=yes
Or The General Grabber AT2's for only 171 each and their a little bigger 195/75
What do you guys think? OF have any other suggestions?
If i got the cheaper General's i might have some money left over for a rear locker...
Old Mar 29, 2010 | 08:57 PM
  #303
Elton's Avatar
how often do you think you will need mud tires ?
Old Mar 29, 2010 | 09:02 PM
  #304
yotaman85's Avatar
BFG for the win.
Old Mar 29, 2010 | 09:12 PM
  #305
camo31_10.50's Avatar
nowadays..i don't NEED a mud terrain very often...but when i do...i DO!
the places i go sometimes are absolutely horrible..
i'd rather have something and not need it, than need something and not have it..
of course if you actually know hot to drive a 4wd vehicle..A/T's will do JUST fine!!!
i on the other hand need some mud terrains lol..although i might grab a set of 31" A/T's for my new 4runner (it's got 4.56 gears) for mileage reasons.
but this summer i'm working the pipeline all over oklahoma..and those pipeline right-of-ways are absolutely thrashed..NO way that an A/T would make it 10 ft on that red clay lol swampers is the only way to go
so this summer i might pick up a set of 33x13.50 IROK radials for the 4runner...decent street manners if they are checked on often..should get some decent mileage out of them..and they should handle the pipeline very well
Old Mar 30, 2010 | 12:00 AM
  #306
Matt16's Avatar
The reviews suggest the Generals are a better tire. I've heard a bit how quality control used to not be so good with General, and people were getting tires that were out of round and having to ship them back on their dime (one disadvantage of buying online). The Generals would be my pick I think still because they are a bit more aggressive and I think they might be heavier built (I think they weigh more than the BFG).
Lockers are really important on an IFS rig, so I'd try and get one in. Lockers will do more for you than tires in a lot of situations (dare i say most?) and they won't impact mpgs.
Old Mar 30, 2010 | 08:24 AM
  #307
Colonel Angus's Avatar
1.5" Daystar OR 2.5" Daystar for 265/75s
I'm settling on 265/75s as opposed to the awesome 255/85s. I don't want to have to regear and trim pinch welds, fenders, bumpers, etc.
So, my question to you guys is.....
What do you think will look the best? The 1.5" or the 2.5"? If I did the 2.5" would I need to drop the differential? Also, if I got the 2.5" with 265/75s....will I wish that I had got the 255/85s?
Let me know what you think and post pics if you get 'em.
Thanks folks!!!!
p.s It's a '99 4x4 Limited.
Old Apr 1, 2010 | 08:17 AM
  #308
4runnin616's Avatar
What size tires & rims can I run....
hi!
I have a 99 4runner with a 3 inch Toytec lift...I want to upgrade to 33/12.5/15 tires...does anyone know if they will for sure fit? im not going to be doing any crazy off roading. its mostly just for looks.
And also, what rims do i get to go with them...backspacing etc. im new to all this so please help!!!
Old Apr 1, 2010 | 08:43 AM
  #309
MaK92-4RnR's Avatar
my brother did the same lift but went with 32x11.5/15. honestly, you can do 33x12.50s. they will fit. but the problem is what rims do you want? my brother had a problem with rims because he bought 15x8 steelies with 3.75 backspacing. they fit the lug pattern but didn't clear the brake caliper so he has to run wheel spacers until he finds rim that fit correctly.
also, what lb. coils did you get? 650?
Old Apr 1, 2010 | 09:02 AM
  #310
4runnin616's Avatar
this is the rim i want... http://www.summitracing.com/parts/CRR-3975812/
i just dont know the measurments to get so they fit.
im not sure what lb coils they are. all they say are medium load. front are OME 883 and rear are OME 891 if that helps any.
Old Apr 2, 2010 | 01:39 PM
  #311
^99runner^'s Avatar
others on this website have ran those. just do a quick search. you need 6x5.5 lug pattern though for the yota
Old Apr 2, 2010 | 02:07 PM
  #312
VSU_4runnin's Avatar
1. SEARCH!!!!!!!!!!! there are so many will 33's fit threads its not even funny
2. ask the people who your getting the tire from what rim youll need.
Old Apr 3, 2010 | 10:33 AM
  #313
tiger's Avatar
well from what ive learned guys putting 12.50 and even 11.50 on stock rims is really a no no it can make premature tire wear and some tire manufacters wont warrenty the tire 10.50 is as big as you should go on a 7 inch rim 11.50 calls for 7.5 to 9 and 12.50 calls foe a 8.5 to 10.50 it can be done and put on those rims but you should check into getting wider rims later on
Old Apr 6, 2010 | 01:16 PM
  #314
carolinarunner's Avatar
Can i fit 12.50 tires on my 99 4runner without a wheel spacer?
ok, so im currently running 11.50 tires on my 99 runner. im about to step up to 35x12.50's. Am i gonna need a wheel spacer? Or what kind of back spacing? Thenks for the help guys and gals!
Old Apr 7, 2010 | 01:27 PM
  #315
AxleIke's Avatar
Not sure about the new trucks, but a lot will depend on what rim you want to run.
The smaller your back spacing, the farther out your tire sits, and the more it will rub. Same thing with a spacer.
I'm running stock rims on my 87, but I had to modify the A-arm a lot. However, I only had to trim the fenders a very minor amount. Depends on what you want to do.
Old Apr 14, 2010 | 08:12 PM
  #316
DeadWrong's Avatar
new truck
I just got a new to me 92 extended cab a few weeks ago. I'm extremely pumped about it. I've been wanting a toyota since I was 15.
I bought it for 2400 if anyone is interested to know. 166,000 on the 22re now.
The truck has a 3" body lift and is running 32 11.50's on it with no rubbing under any conditions, the inner fender was trimmed out but the the pinch weld is not pounded/trimmed down.
After days of reading through the forums,
I ordered a rear locker, a spartan, believe its made by yukon.. I'll be putting it in this Sunday.
Also from the information I've acquired from yota tech, I've decided to move up to 33's on my next tire change (which won't be too far in the future as the alignment ate up the front tires pretty bad before I replaced idler pitman and had it realigned).
Out of curiostiy, and it is probably a stupid question, but how do I know what backspacing my wheels are?
Anyway, what I haven't decided is what width tire I should go with. Either a 10.50 or a 12.50.? I'm not worried about fitting, I don't mind trimming or swinging a hammer a little. What I really want is everyone's opinion about is how either will perform. I see mostly mud holes and mud hill climbs some biggish steps over roots and etc(clay sometimes) and some deep snow during the winters.
Also i was wondering about suggestions about types of tires I should buy, The truck has wild country's on it right now, Schwab specials as I understand. I am fairly impressed with them so far (and the truck itself I'm sure has quite a bit to do with it), I would like something with at least as aggressive tread as the current tires. I'm not looking to break the bank buying tires if I don't have to though. Anyway any opinions would be greatly appreciated! Thanks everyone!
One more picture cause I'm still excited about having a yota.
Old Apr 14, 2010 | 08:18 PM
  #317
4Crawler's Avatar
Easy enough:
Old Apr 14, 2010 | 08:22 PM
  #318
DeadWrong's Avatar
Thanks! I knew it was a stupid question! Any opinions on new tires?
Old Apr 15, 2010 | 03:59 PM
  #319
tiger's Avatar
hey deadwrong mub or allterrains when it comes to mud i swear by swampers they have several different brands when it comes to a all terrain ill prob get a lot of for this but i got nitto dune grapplers on a 1500 dodge they have actually impressed me they arent the best as far as mud but snow rain ice they r pretty good and my friend on a chevy 3/4 ton got 44,000 out of his i got 15,000 so far and they r in good shape but i rotate them every oil change hope this helps i run swamper truxis mx on my toy
Old Apr 15, 2010 | 04:35 PM
  #320
DeadWrong's Avatar
Thanks a lot for your input! I like the trxus swampers! they might be a little more than I wanna spend though, and I've been leaning toward a 10.50 Do they come in that size? I didn't find any from my quick search.
