The OFFICIAL IFS "What size tire will fit" thread
Old Feb 13, 2010 | 06:05 PM
  #261
netmasta88's Avatar
Dc-1's on 2002 tundra?
hey guys, i was wondering if any of you have dick cepek dc 1's on ur tundras? ive been looking into getting a set for my 02 tundra sr5 access cab trd 4x4 . its bone stock. I was looking on tire rack and they say the rims will fit my truck, 16x8, with 4.09" backspacing. they say that i can get tires 265/70/16, but a lot of people say i can go with a 265/75/16, with no rubbing etc, my main concern is the backspacing, can anyone steer me the right direction?
here are the rims
http://www.tirerack.com/wheels/Wheel...All&sort=Price
Old Feb 13, 2010 | 08:10 PM
  #262
Levis Pennae's Avatar
'91 to '86 wheel backspacing
Would the aftermarket wheels from my 1991 Pickup fit onto a 1986 4Runner? The aftermarket wheels fit without any spacers or fender messaging.
Old Feb 13, 2010 | 09:33 PM
  #263
jim65wagon's Avatar
You should be fine as long as you stick with the 265/75 (or the 265/70). I ran 265/75 with the Wheelers steel rims (BS 3 3/4") no rub. I know several that run that size on stock rims with no problems either. It'll be fine...
Old Feb 14, 2010 | 04:21 AM
  #264
netmasta88's Avatar
k thanks a lot!!
Old Feb 14, 2010 | 10:41 AM
  #265
ToyoTech559's Avatar
i have a stock 88 4runner sr5. need to know if i can fit 33x12.5 tires?
rims are 15x8 with about 4.5 b/s
if anyone have this set up. i like to see a picture on there stock 4runner
Old Feb 15, 2010 | 10:07 AM
  #266
AxleIke's Avatar
Clarify "fit".
Do you mind cutting or pounding at all?
If so, then no. If you don't mind flattening the pinch weld on the back of the front fender, then it will fit with just a minor bit of rubbing at full stuff, on the inner plastic. If you remove the plastic, you'll probably not see much rubbing at all, but you'll get a bunch of crap all over your door hinges every time you drive in the mud, which can be a pain.
Old Feb 15, 2010 | 10:15 AM
  #267
4Crawler's Avatar
A pickup, but nearly stock:
- http://www.4x4wire.com/toyota/hottoy/west/
Old Feb 15, 2010 | 05:31 PM
  #268
Originally Posted by AxleIke
Clarify "fit".
both thank you. guess ill keep looking. i been looking for used rims and tires because i want a wider look. so i want rims/tires to stick out a little.
with backspacing. do i want 3.75 or 4 inch bs? which one would give a wider look?
Old Feb 15, 2010 | 05:40 PM
  #269
4Crawler's Avatar
Less backspacing = wider track:
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
Also requires more lift to fit a given size tire:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Feb 18, 2010 | 06:50 AM
  #270
tr447's Avatar
Will 32x11.5 tires with cragar soft 8 15x8 fit on my 94 4Runner no lift with no rubbing? Or will I need to trim.
Old Feb 18, 2010 | 08:42 AM
  #271
AxleIke's Avatar
You will likely need to pound the pinch weld flat, and trim a little of the plastic inner fender. If you like a narrower look, a 33x10.5 will fit nicely with less rubbing.
Old Feb 18, 2010 | 09:04 AM
  #272
tr447's Avatar
I've read that running 33x10.5 u should re-gear. I have 4.56 right now and with 31x10.5 it's slow already... But I guess 32x11.5 and 33x10.5 would have the same power loss. Would say running 1" spacers make the rubbing issue worse or less if I were running the 32x11.5? The wider tire is somewhat more appealing to me.
Old Feb 18, 2010 | 01:15 PM
  #273
tr447's Avatar
MY above post gear ratio is incorrect. I actually have 4.88's With 33x10.5 tires would i need to regear??
Old Feb 18, 2010 | 01:55 PM
  #274
AxleIke's Avatar
To answer your questions:
The spacers will make the rubbing worse.
You won't see all that much of a difference between the 32 and the 33. With the auto and 4.88's, you will feel quite slow either way. Regearing is a great option.
Old Feb 18, 2010 | 02:35 PM
  #275
tr447's Avatar
Thanks AxleIke. I'm just gonna go with some 31x10.5x15 bfgoodrich km2's for now and save money for more important things... like gears and lockers.
Old Feb 18, 2010 | 03:44 PM
  #276
Lumpy's Avatar
Just so you know, I had 31's when I got my 4Runner and now I have 33x12.50's and 4.88's. I did notice a bit of a difference but this is not my DD so I didn't mind so much. I'd get the 33's if I were you.
Old Feb 19, 2010 | 04:56 PM
  #277
thank. 3.5 will stick out more than 4.5
what kind of backspacing should i be looking at if i want a wider look? looking to get 15x8 rims with 31x10.50 tires
Old Feb 28, 2010 | 07:50 PM
  #278
joltin_jim11's Avatar
to all the gearheads out there: ive got an 86 with 30 x 9.5 on stock rims. (going fast in the desert was always my thing not rock crawling) do i need to regear? am i working engine too hard with the larger tires? ive had an engine issue or two when i load truck down with construction stuff (3 ladders on rack etc) and head to mexico to build little house for people..........what gearing would get me back to stock ratio?
beats the standard question of ? what size tire can i jam under my X thanks, JJ
Old Mar 1, 2010 | 01:31 AM
  #279
tr447's Avatar
I've been thinking about what you said... Your right I might as well go with the 33's they look so much better. But I think I'm going to stick with the 10.5 instead of 12.5. Do yours rub bad in the front?
Old Mar 9, 2010 | 01:04 PM
  #280
yourrealdad's Avatar
98 4runner with OME lift what tires?
After reading through this thread and others I just want to make sure I am correct on my assumptions. I have a 1998 4runner SR5 V6 4x4 I am looking into getting a OME 3" lift/suspension kit. I can run 265/75R16 no problem correct?
Would I be able to run 285/75R16 without any mods (besides the OME kit) and would there be any rub? Any need to re-gear?
And just for giggles, could I run the 265/75R16 on the stock 4runner?
Oh the wheels are the stock alloy 16" yota rims as far as BS is concerned.
Thank you and I hope I did what was needed so you all take it easy on me.
