JDM Engine?
Old Apr 25, 2021 | 11:36 AM
mefizto's Avatar
5 Year Member
JDM Engine?
Greetings all,
I have been looking for a donor for 3.0 to 3.4 change, but have been unable to find one for either a reasonable price or lower mileage engine. Thus, I have again turned to researching JDM engines that seem to be plentiful. I remember that I had already asked, https://www.yotatech.com/forums/f160...-rules-297222/, however, the current search yields contradicting information, e.g.:
Cconfirmation:
"with 'JDM' engines, you are just using the Long block. So just the heads with block. You reuse your intake manifold, exhaust, and all of your sensors/injectors/ harness/ ECU."
"Use YOUR CURRENT harness and ECM, YOUR CURRENT oil pan and pickup and YOU SHOULD BE FINE. Keep all your sensors just in case the JDM ones don't work properly."
https://www.yotatech.com/forums/f2/s...ne-jdm-249288/
https://www.yotatech.com/forums/f2/j...e-help-284910/
But then I found:
" I picked up a JDM and just about all the front accessories are different including belts, pulleys, exhaust manifolds and throttle body throttle cable hook ups." https://www.yotatech.com/forums/f160...rences-294232/
"Yes you can replace your USDM motor with a JDM motor. You will need some parts off the USDM motor like the throttle body maybe some sensors ect, just swap over anythjng that is needed from your old motor"Yes you can replace your USDM motor with a JDM motor. You will need some parts off the USDM motor like the throttle body maybe some sensors ect, just swap over anythjng that is needed from your old motor. https://www.toyota-4runner.org/3rd-g...m-4runner.html
"Did you swap the injectors? The ones that came with my 2001 JDM Hiace engine were different from the 1996 4Runner engine. " https://www.toyota-4runner.org/3rd-g...swap-woes.html
And:
"So it seems that a post ‘99 engine would not get along with a pre ’99 ECU. But, the JDM engines are most always listed to fit ’96 to ’02 applications." https://www.yotatech.com/forums/f2/j...ectors-270261/
So, I was wondering if someone, who has used the JDM engine could comment, possibly with a year of the engine.
Kindest regards,
M
Old Aug 5, 2021 | 06:13 AM
davepeter73's Avatar
I’m looking for a good 3.0 for my 1990 pickup any help would be greatly appreciated
Old Aug 5, 2021 | 01:03 PM
wyoming9's Avatar
Red face
It really helps to know where you live shipping an engine 3000 miles is not cheap.
buy a engine you can hear run in person!!
Check the Part out Section on here for a 3.0
Check the other Toyota Forums as well.
Old Aug 8, 2021 | 09:45 AM
moto809's Avatar
5 Year Member
I got my JDM on ebay (I forget which store) for about $1200 last year if I remember right. It was guaranteed to have less than 65K miles on it and was basically turn key. Literally everything was on it, even the belts.
jerrykelch
3.4 Swaps
Mar 14, 2015 05:48 PM
fcmartin
Mar 28, 2013 03:34 AM
ubermoto
10
Dec 29, 2009 07:19 AM
240r
Apr 23, 2009 05:28 PM
thekevin
Mar 11, 2008 06:50 AM
