3vze auto to manual
3vze auto to manual
i just did the 3vze auto to manual trans swap.
all you need is;
clutch bracket
slave cylinder
master clutch cylinder
clutch line
manual tranny
crossmember
shifter sensor from auto tranny
clutch
flywheel
the stock ecu will work fine.
you will have to get the rear driveshaft cut and lenghtened because the auto tranny is 3in longer than the manual one.
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
ok i bought a new
clutch
flywheel
slave cylinder
master slave cylinder and just put a gallon of tranny fluid in my 5spd. trans.
it is still grinding.
i have a pedal assembly out if a 87 toyota pickup 4cylinder in my 89 toyota v6 4runner.
any ideas what it is?
clutch
flywheel
slave cylinder
What kind of "grinding" is it? Grinding between gears, or grinding all the time?
Could be that you damaged the gears from running it with no oil.
Could be that your clutch isnt fully engaging. You need to adjust the slave cylinder rod or clutch pedal to get full travel.
Help after swap auto to manual transmission
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
Despite having the electrical diagram, I have not been able to put these elements to work, help
TransAmBandit
Jul 28, 2015 11:30 PM
