Engine Swaps Swapping an engine in your Toy, here is where to learn how
3vze auto to manual
Old Sep 9, 2008 | 02:00 PM
jvc971's Avatar
3vze auto to manual
i just did the 3vze auto to manual trans swap.
all you need is;
clutch bracket
slave cylinder
master clutch cylinder
clutch line
manual tranny
crossmember
shifter sensor from auto tranny
clutch
flywheel
the stock ecu will work fine.
you will have to get the rear driveshaft cut and lenghtened because the auto tranny is 3in longer than the manual one.
Old Sep 9, 2008 | 02:02 PM
jvc971's Avatar
i am having a problem by the slace cylinder is not going far enough and my gears are grinding and my shifter doesnt have the shifter gromet that goes under it.
Old Sep 9, 2008 | 06:12 PM
jvc971's Avatar
ok i found out that its not the slave its that there was no tranny fluid in it. i am going to go buy and put some in it tomorrow and see if that made a difference
Old Sep 9, 2008 | 06:42 PM
fillsrunner4's Avatar
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
Pedal assembly too but thats a given. could always make your own too
Old Sep 10, 2008 | 11:37 AM
jvc971's Avatar
ok i bought a new
clutch
flywheel
slave cylinder
master slave cylinder and just put a gallon of tranny fluid in my 5spd. trans.
it is still grinding.
i have a pedal assembly out if a 87 toyota pickup 4cylinder in my 89 toyota v6 4runner.
any ideas what it is?
Old Sep 12, 2008 | 08:14 AM
Adam F's Avatar
What kind of "grinding" is it? Grinding between gears, or grinding all the time?
Could be that you damaged the gears from running it with no oil.
Could be that your clutch isnt fully engaging. You need to adjust the slave cylinder rod or clutch pedal to get full travel.
Old Sep 14, 2008 | 07:59 AM
jvc971's Avatar
it is grinding when trying to go into reverse but it wont go into first with the engine on. the clutch is fully adjusted out.
Old Jul 28, 2019 | 12:31 AM
Captskybax's Avatar
What was the cost estimate of the conversion?
Old Dec 31, 2023 | 05:27 AM
cmorla23's Avatar
Help after swap auto to manual transmission
all you need is;
clutch bracket
slave cylinder
clutch line
manual tranny
crossmember
clutch
flywheel
How can I put the cruise control and 4wd back into operation after swapping from auto to manual in a 3vz?
Despite having the electrical diagram, I have not been able to put these elements to work, help
AndYota
Aug 10, 2015 09:19 AM
jbandt
Aug 3, 2015 03:23 PM
TransAmBandit
Jul 28, 2015 11:30 PM
KBar
Jul 13, 2015 06:01 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
