Side marker lights not working
2000 Toyota 4runner
The left and front side marker lights are not working. Brand new bulbs. The fuse seems to be fine....is this the correct fuse (Head (Hi RH, Head Hi LH)?
Honestly not sure if they have ever worked. All other lights work fine
Doing research on the web they say that it is tied into the 10 amp tail fuse. It looked fine, switched with a brand new 10 amp fuse........same thing no left or right side markers. I am going to look for corrosion in the sockets tomorrow and look at the power coming out of those sockets.
Ok. Tail lights are working.
akwheeler I am a simple man.............thank you for the simple solution! I turned to the headlights to one click. The side marker lights are on. Good news. Maybe I am a total nut, but aren't the side marker lights supposed to blink with the turn signal? I guess that is what I have spent time on. Didn't even think about the side marker light being on when the lights were on.
Thanks folks, I feel better already!
Side marker lights Should not blink
Don't ask your vehicle to do something it was not made for............I thought my marker lights would blink when i flipped the turn signal. Not the case. Unless you modify it like somebody else mentioned.
socal85
Apr 18, 2017 09:17 AM
BestToyer
Dec 5, 2002 06:09 PM
MonkeyElvis
Nov 11, 2002 03:50 AM
