What is broken on YOUR Toyota
Old Nov 25, 2014 | 03:11 PM
  #1181
thefishguy77's Avatar
If the deer hits me do I get to keep it?
Old Nov 25, 2014 | 03:12 PM
  #1182
Anytime mud
Old Nov 25, 2014 | 05:24 PM
  #1183
muddmadness's Avatar
I think so fish if no one sees you.. Lol
Old Nov 26, 2014 | 07:26 AM
  #1184
Billy Ray Valentine's Avatar
is there supposed to become sort of sleeve inside this carrier bearing? The axle doesn't even touch it there are some metal deposits stuck to the axel but the bearing looks good but like I said it it doesn't touch the bearing at all..has 3/8 of verticle movement. This all started with a horrible vibration in fromt at 55 and worsened when touched the brakes... Once slowed down it went away..didn't do it every time, about every third time I get up to speed...all u joints are good, front bearings are a little loose it seems both sides are same. I can fix it just not sure hpw much play is supposed to be there..with front bearing to for that matter.What is broken on YOUR Toyota-image.jpg
Old Nov 26, 2014 | 07:32 AM
  #1185
Old Dec 3, 2014 | 05:29 AM
  #1186
Littlemuddy's Avatar
91 Toyota Hilux
My feet get dripped on when it rains(cab leaks)
Tailgate is stuck closed, can't get it to open
Blower motor doesn't stay on
Rust spot in the back of the bed
Wheelbearings and rotors(i have replacement parts but who wants to work on trucks in the snow)
Brake caliper on passenger side stuck
Truck has 304,000 miles and counting. Ha!
Old Dec 3, 2014 | 07:40 AM
  #1187
Originally Posted by Littlemuddy
91 Toyota Hilux My feet get dripped on when it rains(cab leaks) Tailgate is stuck closed, can't get it to open Blower motor doesn't stay on Rust spot in the back of the bed Wheelbearings and rotors(i have replacement parts but who wants to work on trucks in the snow) Brake caliper on passenger side stuck Truck has 304,000 miles and counting. Ha!
The only thing I would do in the snow is wheel bearings and breaks. I have seen tires leave the car when wheel bearings seized. And for breaks in the snow when I'm trying to fix broken thingz I just put new rotors and calipers on. After install I get a 1/2 rack and a friend to bleed them. The beer helps me ignore the cold.
Old Dec 11, 2014 | 03:04 PM
  #1188
I'm not sure yet, when I shift into 2nd gear it goes cathunk pretty sure it shouldn't do that.
Old Dec 11, 2014 | 03:10 PM
  #1189
warmonger88's Avatar
It's not completely broken, but my wipers only work on stupid slow.
Old Dec 12, 2014 | 09:48 AM
  #1190
88yotaaaa's Avatar
Hey guys I haven't figured how to work this whole forum thing.. But I have an 88 yota with 22re the truck starts but it's running on 2 cylinders the plugs and wires are good, has plenty of fire. But the cold start injector has it's wires cut and I don't know where they are suppose to go, but if I touch a hot wire to the cold start injector the motor picks the two dead cylinders up and runs fine but of coarse if I held the wires on it it would flood out can anybody tell me what my problem is?
Old Dec 21, 2014 | 08:26 PM
  #1191
You might want to post this question in the newbie section. This sections is not looked at as much. More than likely someone in the newbie section will be able to give you a wiring diagram. Also jump your diagnostic ports and see what codes it is throwing. Good luck.
Old Dec 22, 2014 | 08:00 AM
  #1192
redbayredneck's Avatar
sounds to me like the injectors for those two cylinders aren't working
Old Dec 22, 2014 | 11:27 AM
  #1193
Redyota1's Avatar
WELL IM NEE TO TOYOTAS and working on vehicles period. I bought a 94 pickup. 22re. LOVE THE TRUCK! Last night I was riding in the woods while hunting. Got to a little mudhole I put in second gear gas on it. The truck made it through the mud hole but then stalled out and wouldn't start back up. I TOOK THE DISTIBUTOR OFF AND NOTICED THERE WAS COPPER AND WHITE FRINGE LIKE MATERIAL ALL TWISTED UP. Truck is still not running. But will turn over. Anybody have any ideas what the copper and white fringe like material is? WHAT DO I NEED TO DO TO GET THIS BAD BOY BACK RUNNING!!
Old Dec 22, 2014 | 12:27 PM
  #1194
Start by either cleaning the cap and rotor or since its new to you. If you can spend the money just put a tune up on it. Cap plugs and rotor. Avoid Bosch. Use denso if you can afford it and ngk if on a tight budget. Welcome to yotatech. And keep us posted.
Old Dec 22, 2014 | 12:51 PM
  #1195
Redyota1's Avatar
I'm thinking I need to change the whole distributor since the copper and white "wire/fringe" was wrapped all around the rotor on the inside
Old Dec 22, 2014 | 12:55 PM
  #1196
Redyota1's Avatar
Does anyone know what that wire is?
Old Dec 30, 2014 | 06:22 PM
  #1197
toytaco98's Avatar
98 toy taco taillights
i have a 98 toyota tacoma i was having an issue with my passenger side brake light not working with the lights on but now im having the issue that neither taillight works with the lights on but the brake light a
that didnt work now does any ideas?
Old Jan 21, 2015 | 10:52 AM
  #1198
Mystery involving antifreeze bubbling out of the radiator cap with or without the heater on. Temperature Gage not working either.
Old Jan 21, 2015 | 10:55 AM
  #1199
Toytaco are you blowing fuses, did you check for a bad ground somewhere.
Old Jan 21, 2015 | 11:01 AM
  #1200
millball's Avatar
Not good, possible blown headgasket.
