What is broken on YOUR Toyota
Old Nov 2, 2014 | 05:20 PM
  #1161
Yota4Runner86's Avatar
Ohhh Lordy where to start.. Rear window motor is on the way out, no heater, intermittent skipping, crappy brakes, and now thanks to a locked down tensioner pully no power steering till I can get one tomorrow( along with new heater core)
Old Nov 3, 2014 | 08:45 AM
  #1162
Roark's Avatar
Here we go:
No washer fluid reservoir due to a battery acid destroyed washer motor. AC compressor needs to be replaced. Tires are almost bald and dry rotted. Rear springs are nearly flat. Oil pan leaks a little oil. LOTS of dents.
But with under 165,000, she's got PLENTY of life yet.
Old Nov 9, 2014 | 10:49 AM
  #1163
Tenn87pickup's Avatar
The only two things:
The Bed
Ball Joint
Old Nov 9, 2014 | 11:24 AM
  #1164
muddmadness's Avatar
Need new water pump belt, windshield wipers, and a front end alignment if I can get someone to do it.
Old Nov 9, 2014 | 11:53 AM
  #1165
cmg72's Avatar
Thumbs down Broke or just annoying
I don't know that anything is broke but my brakes pull HARD to one side when applied. Also, my 4WD light is always on for some reason.
Old Nov 14, 2014 | 08:49 AM
  #1166
AppalachianOffRoader's Avatar
The clutch bracket, just right now :/
Old Nov 14, 2014 | 09:05 AM
  #1167
Oh crap, that sucks. But at least you know what it is, took me a few minutes.. Lol
Old Nov 14, 2014 | 09:10 AM
  #1168
Nothing to report broken only in in need of maintenance. Have a tie rod end knocking, my next apparent lesson in rock crawler repair. Just glad it's high steer instead of one that's tucked up inside a bunch of crap you really don't need to deal with.
Old Nov 15, 2014 | 05:58 AM
  #1169
It took me about 30 minutes of looking. I'm just glad it's something I can weld back together!
Old Nov 15, 2014 | 08:25 AM
  #1170
Welding is a skill I don't have yet but it's definitely on my list of things to learn. I have a wire feed welder its a Hobart my dad gave it to me, he was supposed to teach me but just never had the time. Lucky for me I have friends that know how to weld or my awesome little truck would be grounded.
Old Nov 16, 2014 | 07:53 AM
  #1171
chefdave's Avatar
No back brakes need drums and shoes on a duellly axle.
Tracking and wheel balance.
Find hole in rad filler neck as coolant goes out and air comes in. have replaced all pipes. have a good rad that seals.
New exhaust soon bad rust on all silencer joins
front shocks as very little damping.
Sure to find more if i start to dig for faults
Old Nov 23, 2014 | 11:08 AM
  #1172
c0mmon's Avatar
hood latch
Old Nov 23, 2014 | 12:26 PM
  #1173
Billy Ray Valentine's Avatar
Currently fighting one of many...This I'd my first differential issue..and I've got a lot of verticle play on the passenger side axle. The diff is out and the cover is off and I cant seem to figure out how to get the axle out..I looked for rings inside and out... Don't see anything... What am I missing?What is broken on YOUR Toyota-image.jpg
Old Nov 24, 2014 | 11:07 AM
  #1174
thefishguy77's Avatar
Just get some scrap steel and try welding. Make sure it's not galvanized. Or stainless. And go to town. Remember to keep moving. Don't stop and hold it in one place. If the wire gets "frozen" and you can move t. Break it off so you can grind away and start over. The secret to learning to weld is knowing how to grind. That being said I still suck at it. But I am getting better with practice. My buddy welds all my important stuff for me at the moment.
Edit. To mudmadness
Old Nov 24, 2014 | 12:34 PM
  #1175
millball's Avatar
Originally Posted by Billy Ray Valentine
Currently fighting one of many...This I'd my first differential issue..and I've got a lot of verticle play on the passenger side axle. The diff is out and the cover is off and I cant seem to figure out how to get the axle out..I looked for rings inside and out... Don't see anything... What am I missing?Attachment 100510
Put a couple bars or big screwdrivers behind the flange and pop it out.
There is an expansion ring that you can't see.
Old Nov 24, 2014 | 02:56 PM
  #1176
Fishguy: OK I will gather up some scrap and just go for it. Update on truck : replaced the u joint today with some help from some friends. It was a lot easier than I thought. The hardest part was getting the old one out. To be totally honest I watched mostly but I know now how to do it. All of the vibration and scary squeaks and rattles are gone my awesome little truck is back.
Old Nov 24, 2014 | 06:46 PM
  #1177
Awesome feeling to not have all those scary noises. And remember you can YouTube and "learn" just about anything including welding. Ish
Old Nov 24, 2014 | 06:57 PM
  #1178
It is awesome and I agree that YouTube is a great source for a lot but there are some things that are better learned from an experienced individual (s) that is one of the reasons I joined Yotatech. The collaborative of experience here can't be found anywhere else on the planet. I just hope that I will be able to share the knowledge that I have gained here with someone just like me. I asked for a Yotatech sticker for my truck for Christmas because without Yotatech I would have been lost in the progress with my truck. Thank you for your help and support Fish.
Old Nov 24, 2014 | 10:29 PM
  #1179
SNapper's Avatar
My speedometer doesn't work anymore. Parking brake cable broke. Windshield is cracked. And my front body panels have been destroyed and replaced a couple times from people and deer hitting me.
Old Nov 25, 2014 | 05:36 AM
  #1180
Deer hitting you.. Grin. You need deer repellent fenders. My windshield has a crack too all the way across the bottom. But I can see over the top of it, works for now.
