What is broken on YOUR Toyota
Old Jul 31, 2012 | 11:32 AM
  #961
SPARKS89's Avatar
I'm not saying aftermarket parts can't be used either. Lord knows I've used them almost exclusively since I started working on cars and trucks. It's just ironic that this one didn't after that conversation we had about it last week. You sure you don't work for Toyota???? haha, j/k
I've been through all that several times making sure I wasn't doing something wrong. I don't have the exact size feelers, but I've got some that are close enough. I did take the throttle body off and clean it up good (without the new TPS on). The idle stop screw and dashpot are where they should be and I know I'm using the feeler gauges in the right place. I've been driving with the sensor unplugged since the end of last week waiting on the new part.
Here's the link to my thread on it. Let me know what you might come up with from it.....
https://www.yotatech.com/forums/f116...switch-256641/
Old Aug 27, 2012 | 04:28 PM
  #962
Tmo77's Avatar
-I have rusty chrome bumpers with holes all around my '95 runner. Do the cheaper aftermarket replacements tend to fit like the originals, or is that a gamble? I was told the seams with those should look pretty good.
Also
-Dead lighter socket
-Dead dome light housing
-Half dead rear wiper motor
But only 107k original, so I'm still smilin'
Old Aug 27, 2012 | 05:24 PM
  #963
nathanmyers's Avatar
TMO... If you want just a stock look you might be able to find something that isn't rusted in the junkyard or whatever. That's what I would do but then again I live in the west where clean 4 runners are a dime a dozen.
anyway what has died on mine.
antenna. I know this is very common and will be replaced with a different whip soon.
doesn't run like it should when cold starting. still trying to figure this out
small exhaust leak or injector ticking. I don't know yet but I think it is exhaust. valves are all adjusted correctly so I'm not worried.
windows don't work very well but this is common as well
trans front seal is not a very good seal anymore. goes through about a quart every month. It's my own way of doing a trans flush. The EPA probably doesn't like it very much though.
Old Aug 28, 2012 | 08:29 AM
  #964
StewsRunner's Avatar
Apparently this now,
Prior to this my needle was a bit jumpy so i'm thinking maybe the cable behind the dash is dried or cracked.
Old Aug 28, 2012 | 03:14 PM
  #965
Tmo77's Avatar
Junk yard picking
Good point. Stock is all I want, and there's at least one yard i need to hit since it's relatively close by. Most of the 4runners that i see have at least some rust, so it's tough to imagine anything rust-free sitting around waiting to be picked. Still, gotta get off my butt and check the yards just in case...thanks
Old Aug 28, 2012 | 03:29 PM
  #966
no problem... good luck.
Old Aug 28, 2012 | 03:37 PM
  #967
Team420's Avatar
A whole list of things!!
94:
Tailgate & glass (wife dont know how to set ebrake)
Homemade angle iron bumper (also caused by lack of ebrake)
Transfer case (they dont like draggin logs thru 3' of snow with tire chains and no oil)
2 brake lines
Master cyl,
Needs a shifter seat & bushing
Rear diff howls a lil
Leaks motor oil like a sieve
Vacuum leak caused by oil leak
Rear o2 sensor ( although i bypassed that)
Drivers side caliper
Loads of body cancer
Yep... i think thats it
93:
Rear diff is toast,
Rear brake lines,
O2 sensor
Keyless entry, and alarm system
Think thats all for now :-)
Old Aug 28, 2012 | 05:31 PM
  #968
pair_of_8s's Avatar
Could it be? After 326k Miles, The rear-end is finally going out. I'll have to drive my 2wd '88 for awhile. Sure glad I had a spare toyota laying around.
Old Aug 31, 2012 | 06:35 PM
  #969
ksti's Avatar
Originally Posted by ksti
Nothing big, just this. The wife brought up the trash cans today, the object was closer. I think I'll break her's
Just about 10 minutes ago. My wifey brought up trash cans again. This is the second time now. She's in the house laughing!!. I'll order 2 this time, but told her she better order 1 for hers!
And just to add insult to injury, in my haste to get back to Yotatech this happened DOH!. It hurts!
Old Sep 18, 2012 | 04:51 PM
  #970
lobukbuild's Avatar
ummm!? all of it.... yep its official ive broken everything at on piont or another. ps. including the roof during a flop. pss. come to think of it my wipers have never let me down.
Old Sep 19, 2012 | 08:35 AM
  #971
Texas's Avatar
You name it and I need to fix it on a 77 FJ-40 I just picked up. Some knucklehead believed that body filler would fix any thing, that bolts were optional, and so was most of the wiring.
The one thing I cant figure out is how to fix the e-brake. I have adjusted the back brakes, and the cable under the dash but still no luck. Does anyone know what to do next, because I have two books and no info about the transfer case brake drum?
Thanks, Kirk
Old Sep 19, 2012 | 09:34 AM
  #972
93Xtra-Cab's Avatar
Thet just means you're not trying hard enough
Old Sep 19, 2012 | 10:07 AM
  #973
88Pickup's Avatar
Rear slider window lock is broke
1 Headlight dim
Re-spray K&N filter
That's about it.
Old Sep 19, 2012 | 10:11 AM
  #974
Hieb's Avatar
Leaking rear differential
Old Sep 19, 2012 | 10:12 AM
  #975
Hieb's Avatar
Unadjustable driver seat
  #976
Hieb's Avatar
Split passenger air vent. Letting in outside air.
Old Sep 19, 2012 | 10:13 AM
  #977
Hieb's Avatar
Bent frame at hitch
Old Sep 19, 2012 | 10:14 AM
  #978
Hieb's Avatar
Mismatched front left fender
Old Sep 19, 2012 | 01:26 PM
  #979
Thanks, Kirk
awesome truck... one of the 40 series will be my next car of choice. I see that you are new here? welcome to yotatech. you will probably want to get on ih8mud if you haven't. they are really the guys that know the 40 series. yotatech is more directed at toyota pickups and 4runners.
Old Sep 20, 2012 | 06:58 AM
  #980
redbayredneck's Avatar
Two Toyota's
1985 Pickup:
Body rusted all over, bed rusted out
Auto hubs don't work
Exhaust rusted through in a few places
Leaking windshield
Moldy Carpet
Auto Antenna broke (replaced with non-power antenna)
Switch on Driver side door for Passenger window is missing cover
Missing Work light
Torn driver seat
2008 Tundra:
-Front bumper pushed in about half an inch on passenger side due to making contact with a Nissan
-Hitch is Broke from pulling(aka: Snatching) a truck out this weekend
-Need new Cabin Air Filter
-Cracked Hub cap on driver side front wheel
-Tailgate is Dented on the inside from carrying my 3-wheeler in the bed
