Plastic-y coating on shift lever
Old 07-28-2008, 06:51 AM
83's Avatar
It was already stripped off a bit, and when I dropped the transmission out a couple weeks ago, it got really torn up, so I pulled the rest off. Now I'm just figuring I'll rattle can it black, but...is that rubbery coating a heat insulator? Will it be an issue at all to just paint it or will it get pretty hot? Thanks.
Old 07-28-2008, 07:22 AM
4Crawler's Avatar
It probably helps with the heat a little, the shifter does get fairly warm with high speed driving. Paint is probably OK, or pick up a foot or so of heat shrink tubing and slide that over the shifter and shrink it in place. That is what I use on my shifter extensions.
Old 07-28-2008, 08:22 AM
83's Avatar
Ah, shrink tubing. Where is it sold? Thank you!
Old 07-28-2008, 08:33 AM
4Crawler's Avatar
Electronics or electrical supply stores.
Could also try some of that brush or spray on insulation or tool grip stuff, sort of a heavy vinyl paint.
Old 07-28-2008, 08:42 AM
eighty5yota's Avatar
if you want a real trick and protective look, get some hot melt vinyl and tape the threads up a bit.
the stuff is used for making the rubber coating on hand tools.
any color you want also
Old 07-28-2008, 10:39 AM
83's Avatar
Ok great, thanks a lot. I'll look around and see what I can find.
Old 07-28-2008, 11:25 AM
dirtoyboy's Avatar
just slap some paint on it and call it good! thats what i would do
Old 07-28-2008, 11:36 AM
83's Avatar
It may come to that. I'm finally really starting to get impatient here and just want to drive my truck again!!
Get my check yet? I think it went out Friday. Hopefully you'll get it today. Interiors coming along!! Just wish I could find a full instrument cluster for it.
Old 07-28-2008, 12:04 PM
dirtoyboy's Avatar
nope not yet! I might have some clusters laying around too if you're interested ....looking sharp so far!
Old 07-28-2008, 01:23 PM
83's Avatar
I am interested. They've got to be for what I'm guessing is a late model '83. I want one with a tach and trip meter. I got an 82 cluster with this dash pad and steering wheel, but it doesn't plug in to my truck...they changed the connections. Talked with a guy on this site who says he has a cluster that came from an '83 and it doesn't work with mine either...So if you've got one, let me know. Here's a photo. Top is mine, bottom is all other '79-82, and possibly a bit into 83.
I'd love it if the older ones worked in my truck, I like they way they look better than mine...
Thanks! I like the way it's looking too. I like the shade contrast with the lighter dash pad. My old one was the same dark brown as the bottom end of the dash. And I had the lame (in my opinion) looking stock base model steering wheel. Plus no fake woody stuff on my original dash. : )
ashamsuddin
17
01-13-2023 03:17 AM
punks_is_4x4
02-26-2016 04:29 PM
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Plastic-y coating on shift lever
