Sponsored by: CARiD
my sticks touch
Old Feb 2, 2011 | 06:35 PM
OL' YELLA's Avatar
my sticks touch
i just got a new to me 93 toyota 4x4 single cab with a 3 inch body lift and my trans shifter hits my 4x4 shifter when its in 4lo its good as long as im in first but if i shift into 2nd when i pull it down it hits the 4x4 lever and knocks it into neutal i have taken the boots off and looked and nothing seems to be binding what could wrong
Old Feb 2, 2011 | 06:40 PM
Tofer's Avatar
Sponsor
i think thats due to the body lift...
Old Feb 2, 2011 | 07:13 PM
myyota's Avatar
Its either from the body lift, or one of the shifters is installed backwards.
Old Feb 2, 2011 | 07:33 PM
SpecialScottie's Avatar
You could always take the shifter out and bend it a bit
Old Feb 2, 2011 | 07:59 PM
2DoorRunner's Avatar
Guessing its the t-case shifter is installed backwards.
Old Feb 2, 2011 | 08:21 PM
Birdbrain's Avatar
I didnt even know that was possible Jack, if i remember correctly, that shifter goes in one way.
Body lift wouldnt due it either i think... as the sticks hit each other, not the hole in the cab...
Could it be the Previous Owner bend the piss out of one?
Old Feb 2, 2011 | 08:31 PM
I seem to remember reading about it Off to google to check
EDIT:
Seems like its possible to me. The part on the bottom looks like it would be the same either way. I will keep searching. To bad i dont have my 4runner here otherwise i could just go check
Old Feb 2, 2011 | 08:45 PM
Got proof! If Rodger says it, it must be true And you had me thinking i was going crazy! I knew i had read that somewhere.
https://www.yotatech.com/forums/f116...ase-v6-101113/
Old Feb 2, 2011 | 09:17 PM
MudHippy's Avatar
O.k., let me clarify:
1. It's not the BL. True. Not sure where that rumor started. I know because I have a 3" BL, and no issues.
2. You can't bolt the transfer case shifter in 180° off(the bolt holes won't line up). BUT, you can install the shifter in the mounting bracket 180° off. Which would cause the same effect.
3. Mine JUST BARELY don't touch with tranny in reverse and t-case in 2H. I can make them touch if I want to. And that's just how they are. They're not bent in the least.
As is shown here.
88 3VZE, if that matters.
Old Feb 2, 2011 | 09:21 PM
Originally Posted by MudHippy
you can install the shifter in the mounting bracket 180° off..
Yeah thats exactly what i was trying to say.
Old Feb 3, 2011 | 06:50 AM
4Crawler's Avatar
Some of the t-case shifter bases are symmetrical and can be flipped around 180*. The V6 t-case is one that is not symmetrical, you can see some of the various shifter bases on the page below:
- http://www.4crawler.com/4x4/ForSale/...shtml#Ordering
And yes, a body lift in and of itself won't affect the levers touching, after all if you pulled the body off altogether, the shifters would still touch (if they touched before). But, if someone cut the shifters and welded in extensions, and did not check for clearance after doing so, that could be the cause of the problem. Bending is the fix. I think Marlin bends the shifters in the truck, with a length of pipe slipped over the shifter and bends until they clear.
Old Feb 3, 2011 | 07:02 AM
NicCantDecide's Avatar
You can install it backwards, I've done it haha
That's why I always check the movement before I bolt it all down now. Easy fix tho.
primordialbeast117
Dec 19, 2015 12:23 PM
4banginRunner
Nov 13, 2015 05:23 AM
irv
Sep 29, 2015 01:04 PM
Odin
Sep 26, 2015 06:56 PM
Rcbc92
Sep 26, 2015 03:00 PM
