Post your GAS MILEAGE!!
Old Jan 6, 2012 | 09:49 AM
  #1101
truckman1966's Avatar
Originally Posted by YotaBoy83
Oh and also will I tune the carb the exact same way I would before?
yep.
Old Jan 6, 2012 | 07:11 PM
  #1102
babyjack's Avatar
91 4x4/Manual 22RE 33"...21 mpg
Old Jan 6, 2012 | 08:37 PM
  #1103
2strokeTRush's Avatar
1997 Tacoma Xtra cab 2.7 four cycle. 31inch all terrain. 5speed manual. 21 mpg 50% highway 50% city.
Old Jan 6, 2012 | 10:17 PM
  #1104
YotaBoy83's Avatar
So I figured out what might be my problem with low mpg and low power. My vacuum advance is bad because it won't hold a vacuum at all
Old Jan 9, 2012 | 12:26 PM
  #1105
XtraSlow_XtraCab's Avatar
I concur. Vacuum leak + less advance on the ignition timing will do that.
Old Jan 9, 2012 | 12:41 PM
  #1106
pholife's Avatar
3.0 3vze
15mpg
Old Jan 9, 2012 | 06:08 PM
  #1107
alltracman78's Avatar
91 3VZE 254K miles, all stock.
4WD DLX, manual trans.
~ 19 MPG, mixed city/hiway.
Old Jan 9, 2012 | 06:12 PM
  #1108
americanmcss's Avatar
Updated...
87 SR5 ex cab 171K OBX header w/ cheapo thrush muffler and 235-70 R15 BFG all terrains and I get 22mpg mix of city and highway....and thats with 10% ethanol winter mix gas. AMSoil 10w-30 in the engine, AMSoil MT-4 in the trans, and Mobil 1 GL 5 in the t-case and difs. Starting my e-fan conversion this weekend and looking into an AFM swap to get that number a little higher.
Old Jan 10, 2012 | 07:27 PM
  #1109
YotaBoy83's Avatar
My truck is running way better now and I've gone 25 miles and the gauge has barely moved but it falls on it's ass in 3rd gear and feels under powered but that's a 22r for ya. And I know it's kinda off topic but when my truck sits and cools down it takes a few seconds for the oil pressure to build up like 3 seconds. But if it's still warm it goes right up. Does this sound okay? And yes my oil filter has the anti drain back valve. Could it be because of winter and I'm running 10w-30 and Lucas in it?
Old Jan 10, 2012 | 07:39 PM
  #1110
Teuf's Avatar
Try a 5/30 syn blend, ( valvoline ) see what happens. I am sure your pressure is o its probably just the gauge.
I run 5/40 full syn Rotela
  #1111
Teuf's Avatar
OK I meant (OK) not O.
Old Jan 10, 2012 | 08:03 PM
  #1112
YotaBoy83's Avatar
Yeah I might try that. And the gauge is a sunpro mechanical gauge if that helps and it's routed after the oil filter. And I run the Lucas because it quiets down the valves a lot
Old Jan 10, 2012 | 08:05 PM
  #1113
YotaBoy83's Avatar
Oh and I hear a very slight difference in the motor when the pressure goes up. And will this happening hurt my motor?
Old Jan 10, 2012 | 08:11 PM
  #1114
Teuf's Avatar
Well thats natural. Toyota 22r's n 22re's are Kinda noisy. Oil flow = cooling and lubrication, so a light start up oil is best in my opinion.
Old Jan 10, 2012 | 08:43 PM
  #1115
YotaBoy83's Avatar
Alright i'll step down to 5w30 when needed and step back up to 10w30 in the summer
Old Jan 17, 2012 | 02:28 PM
  #1116
JohnVH's Avatar
city driving I get 16+
Old Jan 17, 2012 | 03:15 PM
  #1117
Black_1985_SR5's Avatar
85 4runner 22re auto 32's 4.30s i get 15mpg
Old Jan 17, 2012 | 03:26 PM
  #1118
1993yoter's Avatar
18-20, mainly 4th and 5th gear driving around here. 5spd 93 22r on 31s.
Old Jan 23, 2012 | 02:30 PM
  #1119
Hellvision251's Avatar
92 extended cab pickup v6 3.0 with 31x10.5. And a flow master exhaust I get around 14 highway and I'm guessing probably 10 or 11 city? If anyone has any info on how to better gas mileage..... Please share. By the way 14mpg hwy is doing 55-60mph.
Old Jan 23, 2012 | 02:43 PM
  #1120
YotaBoy83's Avatar
Maybe do a tune up with some better ignition parts for a hotter spark or possibly regear for those 31's I get about the same with my 22r and same tire size.
