how does this work?
how does this work?
ok egr on 22re. How does the exhaust get from thoes two little tubes on the manifold to the egr valve it self? I fallowed the pipe around the back of the head but cant quiet figure it out. Pics would be sweet!
The exhaust comes up from the lower side on the block/crankcase and up into the downtube of the EGR valve.
What two little tubes are you talking about? The rubber vacuum hoses? Exhaust doesn't come through those. They operate the valve via vacuum routing.
Here's a diagram of how it works for Fed. and Can. emissions.
http://personal.utulsa.edu/~nathan-b...18egrsyste.pdf
Yours would be Fed. unless you have a California vehicle.
Oh...that e'splains it. Sorry..... the later developments of emissions equipment tend to escape me sometimes.
Well, hopefully someone else will chime. I'm not terribly familiar with post '92 vehicles.
AFT = Rear. Those tubes on your exhaust manifold are air injection tubes.
Not all 22RE`s have those air injection tubes., my 86 4Runner doesn`t have them.
Well they are a form of EGR, the exhaust flows thru them to the intake, so yes there will be carbon inside them... Other than that I never did too much tinkering with mine, it worked and wasn't an issue.
ok now Im confused! One guy is telling me that air goes threw the pair valve then threw the tubes on the back of the head now dumping into the air injection tubes! And another guy is telling be something different. How does this flow?
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
