how does this work?
Old May 26, 2008 | 09:57 PM
94toy4x4fever's Avatar
how does this work?
ok egr on 22re. How does the exhaust get from thoes two little tubes on the manifold to the egr valve it self? I fallowed the pipe around the back of the head but cant quiet figure it out. Pics would be sweet!
Old May 26, 2008 | 11:04 PM
thook's Avatar
The exhaust comes up from the lower side on the block/crankcase and up into the downtube of the EGR valve.
What two little tubes are you talking about? The rubber vacuum hoses? Exhaust doesn't come through those. They operate the valve via vacuum routing.
Here's a diagram of how it works for Fed. and Can. emissions.
http://personal.utulsa.edu/~nathan-b...18egrsyste.pdf
Yours would be Fed. unless you have a California vehicle.
Old May 27, 2008 | 06:39 AM
no the metal tubes coming off my header! Then it wraps around the back of the head
Old May 27, 2008 | 05:06 PM
thook's Avatar
Oh...that e'splains it. Sorry..... the later developments of emissions equipment tend to escape me sometimes.
Well, hopefully someone else will chime. I'm not terribly familiar with post '92 vehicles.
Old May 27, 2008 | 05:29 PM
anyone else?
Old May 27, 2008 | 06:19 PM
AH64ID's Avatar
It gets dumped into the aft end of the intake manifold.
Old May 27, 2008 | 07:53 PM
yep thats what I thought! Thank man!!! Oh and what is the AFT?
Old May 27, 2008 | 08:03 PM
myyota's Avatar
AFT = Rear. Those tubes on your exhaust manifold are air injection tubes.
Not all 22RE`s have those air injection tubes., my 86 4Runner doesn`t have them.
Old May 27, 2008 | 10:09 PM
ok so these air injection tubes has nothing to do with the EGR right. How does the air injection work? Should my air injection tubes have carbon build up on them?
Old May 27, 2008 | 10:26 PM
or should i say in them!
Old May 28, 2008 | 03:37 AM
AH64ID's Avatar
Well they are a form of EGR, the exhaust flows thru them to the intake, so yes there will be carbon inside them... Other than that I never did too much tinkering with mine, it worked and wasn't an issue.
Old May 28, 2008 | 06:44 AM
ok now Im confused! One guy is telling me that air goes threw the pair valve then threw the tubes on the back of the head now dumping into the air injection tubes! And another guy is telling be something different. How does this flow?
Old May 28, 2008 | 09:44 PM
yes no mabye so?
ashersullivan88yota
Jan 18, 2022 05:37 PM
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
madxman21
Jul 9, 2015 10:26 AM
