dome light part
Old Jul 5, 2018 | 04:57 PM
Spread5150's Avatar
5 Year Member
dome light part
I am looking for a replacement domelight for the 94 pickup. Did a few different searches on the forum and the only part numbers I found are for older models and then complaints of people who stated they bought a part that didn't fit.
For the 1994 Toyota pickup 4x4 what is the dome light led replacement ? A link to one would be great ...
Old Jul 5, 2018 | 06:13 PM
scope103's Avatar
81240-89103-S7 The last two characters are the trim color (S7 is light gray).
https://www.ebay.com/itm/8124089103S...-/182443542783
Old Jul 5, 2018 | 07:31 PM
dropzone's Avatar
Fossilized
I gave up on factory dome lights and tweaked it
Originally Posted by dropzone
I am in the same boat, hard to believe it has been a year already. It sat in the driveway too long.
This little guy is my grandson. I was in the military when my kids were little. Missed a few birthdays and them learning to walk. The Lord sort of gave my a 2nd chance with the grandkid so figure I will make time.
From what I have read they give about 3" of lift. Not sure of the spring rate. 85toyman is running a similar set up I plan on running. His set up is clearing 35's with out issue. This thing will see the axles, front springs and tires from the Trekker
Old dome light switch gave up the ghost, tried soldering it but that lasted about a week. Dug into the parts stash and decided to make a small upgrade in brightNess
Attachment 112326
I may use the Duplicolor interior paint I have to make the housing color match but this will do for now.
Night shot of the new dome light
Attachment 112322
with the rear cargo lights and courtesy lights
Attachment 112323
Old Jul 5, 2018 | 09:39 PM
Spread5150's Avatar
5 Year Member
Thanks for the reply. I meant the bulb woops
Old Jul 6, 2018 | 06:23 AM
scope103's Avatar
Just the bulb??! It's a standard Festoon bulb, available at any auto parts store. (Measure it first; they come in different lengths.)
However, I recommend https://www.aliexpress.com/item/FEST...812695346.html The extended life shouldn't mean anything to you (I'll bet you're replacing the original bulb), but these are both brighter and whiter.
Old Jul 6, 2018 | 11:22 AM
Spread5150's Avatar
5 Year Member
Can you just do the drop in LED or is any other modification needed ?
Old Jul 6, 2018 | 01:45 PM
RAD4Runner's Avatar
The ones Scope linked to above are drop-ins. Worst case, I had to put insulative reflector tape in fixture to make sure that if the circuit board swivels nothing will short.
I got mine from https://www.superbrightleds.com/. More expensive but excellent customer service, although with such small-value items, OK to risk it with cheaper Chinese companies.
I still found the LED replacement anemic so I added manually-switched LED strip - option to use same as Dropzone's above- and my stock dome light is now used as my red nightlight.
Old Jul 6, 2018 | 07:18 PM
Spread5150's Avatar
5 Year Member
I ordered one from super bright as suggested. I will report back with a photo
Old Jul 13, 2018 | 08:26 PM
Spread5150's Avatar
5 Year Member
Old Jul 13, 2018 | 08:28 PM
Spread5150's Avatar
5 Year Member
This is the drop in led light from the website as suggested. Seems to be more than enough light for me. I took this in a dark garage. The ambient light is from a nearby stairway. Good buy ! Thanks for the suggestion
Old Jul 13, 2018 | 09:00 PM
scope103's Avatar
Man, now you gotta clean the upholstery!
Old Jul 14, 2018 | 04:31 AM
Discombobulated's Avatar
Does the extended cab have one in the front or is that the only interior light?
Old Jul 14, 2018 | 05:04 AM
Spread5150's Avatar
5 Year Member
That’s the only one.
The seats in mine are pretty good. There is a coffee stain shown. I have the drivers side rip everyone does. Can’t find a seat with out it. Might just have them redone
Old Jul 14, 2018 | 06:41 AM
RAD4Runner's Avatar
NAH, just put a stock incandescent bulb back. LOL!
Old Jul 14, 2018 | 07:29 AM
scope103's Avatar
Mine has the pair of "map lights" around the interior rear view mirror.
It appears to be a "model" issue; I have the SR5 extended cab.
Old Jul 14, 2018 | 07:40 AM
gotcha, mine is a dlx single cab so it just had the single festoon bulb on the mirror, so I got the SR5 dual bulb one from the yard. One of the best upgrades I did holes are there you just have to slice a little bit of the headliner to mount it, but man I was excited!!!
Old Jul 15, 2018 | 11:34 AM
dropzone's Avatar
Fossilized
since the attachments didn't show up on my post.
I used a 9W LED rock light to fix my domelight issues
one of the best tweaks I have made
weathernaut
May 8, 2016 03:32 PM
CamTom12
Apr 20, 2014 07:22 AM
khetu
Jan 4, 2008 12:45 PM
fmg23
Dec 29, 2005 04:54 PM
