Dash light
Old Feb 10, 2014 | 04:40 AM
Crazy_Guy97's Avatar
Dash light
My dash light in 86 yota 4x4 ain't working. I know nothing really bout wiring.But what could be the problem .:yo tarock::yo tarock:
Old Feb 10, 2014 | 08:14 AM
GasTurbine's Avatar
In the fuse box under the driver's side kick panel check the fuse at position (3,2) if setting origin at the bottom left. Or in other words the the middle fuse on the right most column.
Old Feb 10, 2014 | 09:47 AM
scope103's Avatar
I assume "dash light" means the lamps in the combination meter (instrument panel). These are powered through the TAIL fuse, which I show as the "upper" fuse on the right. http://personal.utulsa.edu/~nathan-b.../2powersou.pdf There is some variation in the fuse panel (mostly on the relays), so use the label to find the "TAIL" fuse.
Remember that all of the panel lamps work through the rheostat; make sure that is set to "full bright." And if that doesn't help, the rheostat is where I would look first.
Last, no matter how much or little you know "'bout" wiring, you're going to get nowhere without a meter. No reason to not have one. http://www.harborfreight.com/catalog...t?q=multimeter
Old Feb 10, 2014 | 09:57 AM
RAD4Runner's Avatar
+1
To All that Scope says ^^^
Old Feb 10, 2014 | 02:03 PM
GasTurbine's Avatar
I thought by dash light you meant the ones over the dash. My bad
Old Feb 10, 2014 | 02:35 PM
RAD4Runner's Avatar
Originally Posted by Crazy_Guy97
86 yota 4x4
86-88 4Runner/Pick-up 22R-E 4x4 fuses in Driver side kick panel:
IF tail lights do not work either, check tail fuse, check if Tail relay clicks when you turn tail lights on, and do these voltage checks:
IF tail lights work but dash lights do not, most likely something to do with path to rheostat, then to ground, OR a rheostat that's open.
Old Feb 14, 2014 | 09:50 AM
Ok dash light is working now .I half to replace two other fuse now.
Old Feb 14, 2014 | 11:00 AM
Gamefreakgc's Avatar
I'd be concerned on why so many fuses are blown? Did something short circuit? Did you attempt to install some extra lighting or a radio?
Old Feb 14, 2014 | 12:14 PM
RAD4Runner's Avatar
Why replace the fuses? You found them blown? Which fuse made it work? Are you sure it was a blown fuse? You could have touched an intermittent connection that made it work, but next time it moves you lose your lights again.
So what makes you sure that the fuses you are replacing will prevent this from happening again?
If you answer the questions above, that would be a step toward learning about wiring.
Old Feb 14, 2014 | 01:45 PM
Well this is a project truck so there was 6 fuses missing when i bought it. The wires look good so far i replaced 3 of the 6 fuses.
Old Feb 14, 2014 | 01:53 PM
I have no radio or extra lights.And as for yalls other i dont know how to answer em.
ashersullivan88yota
Jan 18, 2022 05:37 PM
ghostmoney
Jan 28, 2018 11:42 AM
AkitaDog
Sep 1, 2015 08:05 AM
ViperTT
Aug 14, 2015 05:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
