92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Mar 29, 2010 | 04:15 PM
  #1601
92 TOY's Avatar
Originally Posted by Lumpy
Good deal...Ya lotta oozing, wiping, cleaning, oozing, cleaning, spraying...but worth it in the end.
am i happy i did it? yes i am.
thanks to you PITA's for convincing me to do that.
tomorrow's trick will be to try (operative word) to get the valves etc back together.
Old Mar 29, 2010 | 05:32 PM
  #1602
yotarob2005's Avatar
Looking good buddy,
My intake valves looked great also....and my exhaust valves...not so much, they looked like crap.
Old Mar 29, 2010 | 05:48 PM
  #1603
92 TOY's Avatar
Originally Posted by yotarob2005
Looking good buddy,
yeah, i'm guess and gathering that means nothing on the exhaust.
Old Mar 30, 2010 | 01:53 AM
  #1604
vital22re's Avatar
totally a bro
HI JERRY!!!
take those exhuast valve to a wire wheel and give them a good once over.
Old Mar 30, 2010 | 01:59 AM
  #1605
92 TOY's Avatar
morning......ya know it's just about 6am here.
I don't have a bench grinder......I've been wanting one of those for a while.
was going to try to booty-fab something up....maybe I will.
the valves seat very nicely now, I'm glad I let everyone talk me into doing that....was going to be one of those regretful things if I didn't.
Old Mar 30, 2010 | 04:19 AM
  #1606
92 TOY's Avatar
hehehee
Old Mar 30, 2010 | 04:50 AM
  #1607
92 TOY's Avatar
I totally ROCK!!!!!!
pics to follow.......
Old Mar 30, 2010 | 04:56 AM
  #1608
92 TOY's Avatar
started with this........
then i put lapping compound on it and smooshed it around....
they all ended up looking like this
took about 20 minutes to do all of them (wear glasses....oops..was not at 1st)
Old Mar 30, 2010 | 04:58 AM
  #1609
92 TOY's Avatar
next thing is to look through my box of gaskets to see if I have a "rear plate" gasket and a "front block off" gasket......
Old Mar 30, 2010 | 04:59 AM
  #1610
92 TOY's Avatar
i may just re-lap the valves, since I will be able to get a good suction on them now.......
Old Mar 30, 2010 | 05:30 AM
  #1611
Lumpy's Avatar
Lightbulb
Originally Posted by 92 TOY
hehehee
That is sweet!!!! You should market the bumper mount drill bracket!!!
Old Mar 30, 2010 | 05:34 AM
  #1612
92 TOY's Avatar
don't forget the "continuous on" fab, controlled safely from the plug.......hahahahaha
I'm just impressed i did the whole thing without injury....besides some compound in the eye.
Old Mar 30, 2010 | 05:36 AM
  #1613
92 TOY's Avatar
VALVE LAPPING COMPLETED 2ND TIME.......
thanks to all you guys for convincing me to do it too.
Old Mar 30, 2010 | 05:44 AM
  #1614
Lumpy's Avatar
Lookin much better...
Don't worry about that lil bit of compound in the eye...it will remove some of the old eye tissue and you will be able to see much better when it heals
Old Mar 30, 2010 | 05:45 AM
  #1615
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
So, when does reassembly begin?
Old Mar 30, 2010 | 05:49 AM
  #1616
92 TOY's Avatar
ahhhhh....good point.
going to TRY to re-assemble the head today....have to scrub the springs etc before putting them on.....then going to try my hand at doing the whole valve re-assembly thing.
Old Mar 30, 2010 | 05:51 AM
  #1617
92 TOY's Avatar
I think I may have found the gasket fro the rear plate........ going to run down and size it up....the plate is still on because I didn't want to fool around with it and not have a gasket.
as far as the "block-off plate" goes.....not immediately seeing a gasket....but i have a baggie of them on the roof of the truck.......why the roof? because nobody but me can reach them.
Old Mar 30, 2010 | 06:15 AM
  #1618
That is the right gasket for the rear plate....
My gasket set from ENGNBLDR did have a gasket for the "block-off plate" on the side of the head.
Old Mar 30, 2010 | 07:19 AM
  #1619
92 TOY's Avatar
well, that's not going to happen.....broke a bolt...
Old Mar 30, 2010 | 07:27 AM
  #1620
92 TOY's Avatar
But...what i did get done was.....
put 4 complete valves back in.
cleaned and cleaned the stuff.....I am soooooooo glad that I organized things the way I did......makes it very easy and safe to play with these parts.
few things....
-used a dixie cup to put some oil in for dipping purposes.
-used an 11mm socket on a 2'' extension for seating the valve seals.....and a little "persuasion".....my advice is ease it on with your fingers, then push it on with the socket / extension thing and the give it a few taps
-it is VERY EASY to get the springs lopsided after releasing them...2 of them seated askew and had to be adjusted.
-a little vaseline on those keepers makes them easier to work with and makes them "stick" where you want them to, prior to releasing the spring.
got each part squeaky clean and then dipped them in oil and just let them drip off the excess prior to installing.
as per the FSM, I gave each valve stem a little rap downward with a gentle tap and a paper towel to protect it.
Time to eat something......
