87 pickup starting problem
Old Feb 10, 2019 | 08:09 PM
Catey Hager's Avatar
Just drove a few miles and she was fine, parked and wouldn't start back up.
Battery is fully charged, replaced the starter, battery connections are clean and
tight, replaced the grounding wire, replaced the starter relays, and still won't
turn over or even click. Lights and radio turn on.
I have a hopeful hunch its something I'm missing that is small and simple, as
the truck has been running great up until now.
anyone?
Old Feb 10, 2019 | 11:30 PM
87-4runner's Avatar
Ignition switch?
try jumping starting it...
i know you said the battery is fully charged, but try jumping it... report the results
Old Feb 11, 2019 | 03:00 AM
snippits's Avatar
Is it an automatic or manual?
If it's manual, could be a bad clutch pedal ignition lock switch.
Old Feb 11, 2019 | 08:10 AM
Originally Posted by 87-4runner
Ignition switch?
Tried jumping it, and no luck
Old Feb 11, 2019 | 08:11 AM
It's an automatic
Old Feb 11, 2019 | 10:29 AM
87-4runner's Avatar
not what i was thinking it might be then ..
Old Feb 11, 2019 | 10:34 AM
87-4runner's Avatar
I'd start by taking the covers off the steering column and see if you have power at the switch... then leaving the switch...
others on the forum with electric savvy will chime in and help you test with a multimeter... where and what to test for... good luck
Old Feb 11, 2019 | 11:50 AM
RAD4Runner's Avatar
... still won't
I have a hopeful hunch its something I'm missing that is small and simple...
Yes it is small and simple. Toyota parts are bullet-proof. Those parts you replaced are most likely good. That's why problem remained after you replaced them. The problem is in the wiring, maybe a fuse.
It's an automatic
An not even a click of the circuit opening relay behind glovebox?
Toyota wired that truck and mine WRONG AT THE FACTORY, so After you verify voltages above and you ONLY get a click read this: https://www.yotatech.com/forums/f199...l#post52297396
Look at schematic below, and break out your multi-meter (pls see signature).
With good battery connected you should have 12V at A and B and C and AM1 and AM2.
Then you should get 12V at ACC, AT IG1, ST1, IG2, D, E, when you have Ign switch in respective position.
Let us know what you find.
Old Feb 13, 2019 | 08:31 PM
DIRT8IKE's Avatar
When you turn the key do you hear a small whirring sound while you have the key in the start position? If you do that's the fuel pump and I'd place a good chance on the fact that your neutral safety switch failed.
The same happened to me, but you can jump the neutral safety at the expense of your reverse lights
Old Feb 14, 2019 | 01:59 PM
RAD4Runner's Avatar
Duplicate post
Duplicate post
Old Feb 14, 2019 | 02:01 PM
RAD4Runner's Avatar
It's an automatic
Bad/excessively long wiring and absence of starter relay FROM FACTORY and possibly bad/dirty NSS.
Hellvision251
10
Jan 2, 2014 12:24 PM
Jeffrey87
Mar 18, 2012 10:20 PM
Anse
May 29, 2009 08:24 PM
instigator
Dec 8, 2006 01:59 PM
whitehackle26
Jul 16, 2004 08:43 PM
