87 pickup starting problem
Just drove a few miles and she was fine, parked and wouldn't start back up.
Battery is fully charged, replaced the starter, battery connections are clean and tight, replaced the grounding wire, replaced the starter relays, and still won't turn over or even click. Lights and radio turn on. I have a hopeful hunch its something I'm missing that is small and simple, as the truck has been running great up until now. anyone? |
Ignition switch?
try jumping starting it... i know you said the battery is fully charged, but try jumping it... report the results |
Is it an automatic or manual?
If it's manual, could be a bad clutch pedal ignition lock switch. |
Originally Posted by 87-4runner
(Post 52418062)
Ignition switch?
try jumping starting it... i know you said the battery is fully charged, but try jumping it... report the results Tried jumping it, and no luck |
It's an automatic
Originally Posted by Catey Hager
(Post 52418103)
I'd start by taking the covers off the steering column and see if you have power at the switch... then leaving the switch...
others on the forum with electric savvy will chime in and help you test with a multimeter... where and what to test for... good luck |
(Post 52418053)
... still won't
turn over or even click. Lights and radio turn on. I have a hopeful hunch its something I'm missing that is small and simple...
(Post 52418104)
It's an automatic
Toyota wired that truck and mine WRONG AT THE FACTORY, so After you verify voltages above and you ONLY get a click read this: https://www.yotatech.com/forums/f199...l#post52297396 Look at schematic below, and break out your multi-meter (pls see signature). With good battery connected you should have 12V at A and B and C and AM1 and AM2. Then you should get 12V at ACC, AT IG1, ST1, IG2, D, E, when you have Ign switch in respective position. Let us know what you find. https://lh3.googleusercontent.com/p2...A=w799-h664-no |
When you turn the key do you hear a small whirring sound while you have the key in the start position? If you do that's the fuel pump and I'd place a good chance on the fact that your neutral safety switch failed.
The same happened to me, but you can jump the neutral safety at the expense of your reverse lights |
Duplicate post
Duplicate post
(Post 52418104)
It's an automatic
https://lh3.googleusercontent.com/fH...=w1291-h776-no |
