86 4runner wierd sound from rear
Old Apr 13, 2007 | 04:05 PM
4bytruckin's Avatar
ok this is wierd and i can't locate the problem. over 20 mph i hear a loud whosh whosh..... almost rhithmic. starts at 20mph and keeps the same flow and time all the way to 50mph. (just got it, fastet i've gone) took apart brakes and knocked out rust . still does it. sounds the same no matter what speed. i hope i'm not screwed here.
Old Apr 13, 2007 | 04:09 PM
NaeSLaS's Avatar
is it relative to drive speed, or transmission speed, or engine speed?
pop the engine in neutral and see if the noise continues.
also, any idea where from? front? rear? left? right? center?
Old Apr 13, 2007 | 04:10 PM
LTrunner's Avatar
u-joint???
Old Apr 13, 2007 | 09:11 PM
thook's Avatar
Hmmm....odd. Tempo doesn't change with speed? That rules out tires or anything that moves relative to velocity. Odd. Were you listening to Pink Floyd recently?
Old Apr 14, 2007 | 05:09 AM
ZUK's Avatar
ZUK
What comes to mind is tire tread/sidewall separation.....
or a wheel bearing going dry...
Old Apr 14, 2007 | 06:28 AM
usmarinerecon's Avatar
Wheel bearing. and they cost about 75 each. When you are in there you should replace the seals too. there are two per side. I had to get mine pressed out at a machine shop, that ran me 30 per side.
Old Apr 14, 2007 | 08:20 AM
thook's Avatar
Tire's what I thought at first, too. But, wouldn't the tempo of the sound made change with speed? I figure a bad wheel bearing would to. Even then, wouldn't a wheel bearing "click" instead of "whoosh"?
Might take it to a tire shop you trust and have them look at it. A trained eye would help and it shouldn't cost you much for them to just look.
Old Apr 14, 2007 | 08:33 AM
runnerfreak88's Avatar
did you have your heater on when i have mine on for some reason the engine sounds and heater sounds make this wierd whoosh ....whoosh...whoosh..whoosh.whooshwhooshwoosh....w hoosh
its not mechanical just the way the to sounds blend together
Old Apr 14, 2007 | 09:07 AM
I noticed mine all at the same pitch. the sound didn't change due to speed. At first I thought it was the u-joints. So I replaced them...no..... it was the bearings. The sound was only there when I was accelerating or keeping constant throtle.
Old Apr 14, 2007 | 09:48 AM
thook's Avatar
Hmm...and no clicking. Learn something new everyday. Thanks for the explanation.
Old Apr 15, 2007 | 12:30 PM
4bytruckin's Avatar
yeah not rear brakes or u joints. i guess bearings are up next. also found blown wheel cylinder in rear. haven't changed yet . will change 2marrow get back if noise goes away
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
