86 4runner wierd sound from rear
Old 04-13-2007, 04:05 PM
4bytruckin's Avatar
ok this is wierd and i can't locate the problem. over 20 mph i hear a loud whosh whosh..... almost rhithmic. starts at 20mph and keeps the same flow and time all the way to 50mph. (just got it, fastet i've gone) took apart brakes and knocked out rust . still does it. sounds the same no matter what speed. i hope i'm not screwed here.
Old 04-13-2007, 04:09 PM
NaeSLaS's Avatar
is it relative to drive speed, or transmission speed, or engine speed?
pop the engine in neutral and see if the noise continues.
also, any idea where from? front? rear? left? right? center?
Old 04-13-2007, 04:10 PM
LTrunner's Avatar
u-joint???
Old 04-13-2007, 09:11 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Hmmm....odd. Tempo doesn't change with speed? That rules out tires or anything that moves relative to velocity. Odd. Were you listening to Pink Floyd recently?
Old 04-14-2007, 05:09 AM
ZUK
ZUK's Avatar
What comes to mind is tire tread/sidewall separation.....
or a wheel bearing going dry...
Old 04-14-2007, 06:28 AM
usmarinerecon's Avatar
Wheel bearing. and they cost about 75 each. When you are in there you should replace the seals too. there are two per side. I had to get mine pressed out at a machine shop, that ran me 30 per side.
Old 04-14-2007, 08:20 AM
thook's Avatar
Tire's what I thought at first, too. But, wouldn't the tempo of the sound made change with speed? I figure a bad wheel bearing would to. Even then, wouldn't a wheel bearing "click" instead of "whoosh"?
Might take it to a tire shop you trust and have them look at it. A trained eye would help and it shouldn't cost you much for them to just look.
Old 04-14-2007, 08:33 AM
runnerfreak88's Avatar
did you have your heater on when i have mine on for some reason the engine sounds and heater sounds make this wierd whoosh ....whoosh...whoosh..whoosh.whooshwhooshwoosh....w hoosh
its not mechanical just the way the to sounds blend together
Old 04-14-2007, 09:07 AM
I noticed mine all at the same pitch. the sound didn't change due to speed. At first I thought it was the u-joints. So I replaced them...no..... it was the bearings. The sound was only there when I was accelerating or keeping constant throtle.
Old 04-14-2007, 09:48 AM
thook's Avatar
Hmm...and no clicking. Learn something new everyday. Thanks for the explanation.
Old 04-15-2007, 12:30 PM
4bytruckin's Avatar
yeah not rear brakes or u joints. i guess bearings are up next. also found blown wheel cylinder in rear. haven't changed yet . will change 2marrow get back if noise goes away
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 86 4runner wierd sound from rear
