Solenoid resistor heat?
Old Aug 27, 2013 | 03:31 PM
Guyechka's Avatar
Just how hot does the thing get? Is it safe to run wiring touching it?
Old Aug 27, 2013 | 10:06 PM
slow-mo's Avatar
Well, I'll be the first to ask, what are you talking about?
The starter solenoid?
The fan blower resistor?
I have not heard of a "solenoid resistor", unless it is specific to your 4Runner(s), or the EFI system.
Old Aug 27, 2013 | 11:29 PM
wyoming9's Avatar
Red face
I think they are talking about the injector resistor mounted to the right side inner fender .
I have no clue what a solenoid resistor is or what point it would serve.
It gets warm but it should not be to the point of burning the paint off.
Old Aug 28, 2013 | 04:49 AM
Guyechka's Avatar
Yes, the injector resistor. I had to look up its name, and "solenoid resistor" is what it was called. It's the solenoid with the cooling fins. I was rerouting some wiring and noticed Toyota was very careful to keep the bundle coming from the ecu well away. Plus, the last three inches of wiring going into the resistor are sheathed in heat resistant material like pyrometer wire. It occurred to me that anything with fins is going to get hot, but I couldn't find anything about just how hot or how distant any wiring ought to be.
Old Sep 24, 2013 | 08:22 AM
86bullet's Avatar
does anybody out there know how to test a injector resistor
Old Sep 25, 2013 | 09:17 AM
86bullet's Avatar
hot enough that you can smell wires burning after 10 - 15 minutes
Old Sep 25, 2013 | 09:21 AM
86bullet's Avatar
why is my main fuse and relay getting to hot to touch. please help!!!
Old Sep 25, 2013 | 10:33 AM
RAD4Runner's Avatar
Measure Current Through it and components it supplies
it is a resistor so look at FSM to see what its value should be, then measure with this
  • Measure current draw through it with this
  • Measure current draw to components it supplies, then
  • Compare with other owners'
Davebarbier
Nov 3, 2015 03:28 PM
pickle6415
Oct 19, 2015 08:08 AM
mreagen
Oct 5, 2015 04:27 PM
Obmi
Oct 4, 2015 11:30 AM
Matthew Perez
Sep 28, 2015 05:43 PM
