Pre 84 Trucks 1st gen pickups
81 pickup multiple questions
Old Jan 24, 2013 | 10:17 AM
  #101
4Crawler's Avatar
Originally Posted by parkerst02
Ok thanks so i need to find a solid front axle with power steering
Yep, that is it. If you have any local fab. shops, they might have some laying around if they do crossover steering conversions on the older trucks. Part of that swap is removing the old p/s box and putting in the IFS box.
Old Jan 24, 2013 | 10:21 AM
  #102
parkerst02's Avatar
I'll go to a junk yard and pull one if they have one
Old Jan 24, 2013 | 12:19 PM
  #103
parkerst02's Avatar
Is it hard to get to the steering gear box with a v8 in it?
Old Jan 25, 2013 | 08:03 PM
  #104
travis_h's Avatar
The steering box is on the outside of the frame. Should be easy to get to know matter what engine you have. Here's mine and I have a v8.
Old Jan 25, 2013 | 09:47 PM
  #105
parkerst02's Avatar
ok thanks i was just making sure before i put motor in without power steering. I will be getting it next week sometime and hoping to get the motor and transmission in tomorrow
Old Jan 26, 2013 | 06:10 PM
  #106
parkerst02's Avatar
well my plans of having it running this weekend came to a screeching halt i have to wait til tuesday to get a new pilot bearing. the one that was in it was seized up good thing i checked it. another question travis on your motor mounts the stock 22r mounts have the mounting plate that sticks out off the frame did you have to cut them off or did you mount your mounts on them? I figured i have to cut them
Old Jan 26, 2013 | 06:16 PM
  #107
travis_h's Avatar
I cut them off and built new mounts.
Old Jan 26, 2013 | 07:03 PM
  #108
parkerst02's Avatar
Last day with the 22r in it
Old Jan 26, 2013 | 07:05 PM
  #109
parkerst02's Avatar
Yeah i figured i would have to i want to put transmission on motor slide it in and see how everything will fit and go ahead and weld the mounts on
Old Jan 27, 2013 | 12:02 PM
  #110
parkerst02's Avatar
What came out of it
One empty truck
Old Jan 27, 2013 | 03:00 PM
  #111
parkerst02's Avatar
can someone post some pics of the engine mount set up they use or measurements on the frame where they mounted them
Old Jan 27, 2013 | 04:06 PM
  #112
travis_h's Avatar
Here are mine I have in my truck they are the old chevy style mount with a single bolt comes up from the bottom to the center of the mount
Here are my brothers mounts that are a solid mount off the engine with a rubber bushing at the frame
Old Jan 27, 2013 | 04:25 PM
  #113
parkerst02's Avatar
That helps a lot i was having problems getting motor in to see where mounts go now i see what's going on
Old Jan 28, 2013 | 04:19 AM
  #114
parkerst02's Avatar
What's going in it
Old Jan 29, 2013 | 06:21 PM
  #115
parkerst02's Avatar
Well got my motor sat in before a storm came in now to see if the transmission will go in easy. Got a question how far back is your motor and how far forward did you move your radiator
Old Jan 31, 2013 | 06:34 PM
  #116
parkerst02's Avatar
Got motor and transmission in now so now i think its just the easy stuff left to do
Old Feb 6, 2013 | 05:10 AM
  #117
parkerst02's Avatar
so I'm having starter problems and hoping one of ya'll can help. wired the starter up and when i hooked the battery up it started running with out turning the key i thought the wire on the s terminal was staying hot i unhooked it and done it again is the solenoid bad because i bought it yesterday or could some of the wires in it be touching
Old Feb 6, 2013 | 06:06 AM
  #118
SCToy's Avatar
Mine did that with a stuck solenoid.
Old Feb 6, 2013 | 06:48 AM
  #119
parkerst02's Avatar
That's what I'm thinking can i fix it by tearing solinoid apart
Old Feb 6, 2013 | 06:56 AM
  #120
4Crawler's Avatar
Can't hurt, pull it apart for a look:
- http://www.4crawler.com/4x4/CheapTri...PlungerCleanup
Common problem causes are badly worn contacts or excessive dirt or grease inside causing the plunger to get stuck in the bore of the solenoid. But if the solenoid control wire is always hot, then find out why:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
